Old 01-19-2012, 10:17 PM   #1
seanriker
seanriker is on a distinguished road
Default Won't Start
So my Ion has had some starting issues of late. I replaced the battery based on the results of my load test. Didn't fix it.
I got an ignition switch and spent the half hour resetting the Passlock. The lock symbol is gone, but no cigar. Nothing happens, I don't even hear the fuel pump.
The LCD says "Power Str" and "Coolant". I scanned it with my OBD II and it found no faults. I don't see any plugs I might have bumped during the replacement of my switch.
Any ideas? I need to get to work tomorrow... Thanks in advance.
Add to seanriker's Reputation
Rate the quality of this post and help seanriker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
seanriker is offline   Reply With Quote
Old 01-20-2012, 12:13 AM   #2
bern
2004 ION-2 Sedan
Default Re: Won't Start
Check BCM for both current and history codes. you may have to use a tech-2 scan tool.
Add to bern's Reputation
Old 01-20-2012, 06:32 PM   #3
seanriker
I figured it out. The BWD Ignition Switch didn't work. I bought an ACDelco and opened the box and the switch was in pieces, cheap. The only switch that worked was a Duralast.
For some reason the BWD will confuse the BCM and throw out errors.
Old 01-20-2012, 06:55 PM   #4
^ ^ That's simply incredible!? ^ ^
Old 01-21-2012, 07:38 AM   #5
Werks11
Werks11 is on a distinguished road
simply
Add to Werks11's Reputation
Rate the quality of this post and help Werks11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Werks11 is offline   Reply With Quote
02 LW300 P0343, no start/hard start, noise. JC316 L-Series Tech 2 11-29-2011 07:09 PM
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 10:27 PM
Cold start fine, warm start takes a couple of tries FredM S-Series Tech 5 09-05-2008 04:03 PM
1999 SL2 Wont Start/Hard to Start in Hot Weather BlueOgre S-Series Tech 9 06-28-2007 05:36 AM
2000 saturnls2 wont start w;key only w/remote start PLEASE HELP(CAR STILL DRIVABLE!) mymimi75 L-Series Tech 1 08-18-2006 10:50 AM
