Old 01-13-2012, 02:54 PM   #1
keelerpd
keelerpd is on a distinguished road
Default Poor fuel mileage 2.2 L Ecotec
All,
I have heard great things about this engine and car (ION). I drive a 2004 ION 5sp manual to work. I drive about 75 mph and don't do jackrabbit starts. The car has 114K miles on it and the oil is always full and clean. I have observed mileage from 27 to 29 mpg with 29 being the top I have ever gotten with it. I drive almost all highway miles and got 351 miles out of the last tank of gas. I realize that this may be in the "normal" range but I wanted to ask the forum what they have seen. Should I expect better mileage? What can I check if this is not as good as I should see.
My SL2 with a 1.9 with 272K miles delivered 33 mpg everyday!
Ideas?
Thanks in advance.
2004 ION 3 - LE - 114K miles
1999 SL2 - Owned since new, 272K miles (ALAS Sold)
1964 Chevelle - restoring
1965 Chevelle 2 dr post - driver
Add to keelerpd's Reputation
Rate the quality of this post and help keelerpd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keelerpd is offline   Reply With Quote
Old 01-13-2012, 03:28 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Poor fuel mileage 2.2 L Ecotec
Look for my thread about suggested pm by engine and year. You are getting low mileage for an ion.I drive a few miles back and forth to work each day, so the engine doesn't warm up, in city driving, and I still get 27.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 01-13-2012, 04:38 PM   #3
keelerpd
Upon poking around under the hood, I noticed an empty harness plug...it is on the left side in front of the radiator. It is odd. This car didn't have an easy life before me, but it does run well. I ran some Lucas fuel injector cleaner through it and I prolly should replace the fuel filter too.
I will try to get a pic of the plug tonight...not saying that it is anything, but I want to be sure.
Old 01-13-2012, 04:55 PM   #4
2006 ion2
2007 ION-2 Sedan
It's a mystery plug. Dealers don't know what it is
2007 Saturn Ion 2
Old 01-13-2012, 11:10 PM   #5
keelerpd
So you know the plug I am talking about? There isn't supposed to be anything plugged into it? Like I said, this car was treated the best before I got it. Tomorrow I am going to clean the IAC and TPS and TB and change oil...Also replace plugs with AC Delco plugs and I have put injector cleaner into this tank. I probably need to replace the fuel filter as it probably hasn't ever been changed.
The car has 114K on it. Anything else you can think of that would impact mileage? I have new tires all the way around at correct pressure also.
THanks in advance,
Old 01-14-2012, 10:08 AM   #6
2006 ion2
2007 ION-2 Sedan
it does nothing. look up my thread on this topic.
2007 Saturn Ion 2
Old 01-26-2012, 09:02 AM   #7
keelerpd
Well...I have checked and replaced plugs on my ecotec. I noticed that there were NGK plugs in it before and it now has the correct AC Delco plugs in it for the 2.2 Ecotec, AC part number 41-405. The threaded part of the plug on the correct plugs was about 1.5 inches LONGER than the NGK plugs, so I thought "oh this should make it get better mileage" as I figured that the spark from the plug wasn't even in the combustion chamber. I did call two different auto places to be sure that the plugs were the right ones and they both gave me the same number.
Now the car gets WORSE mileage...the calculated mileage on the last tank was just over 25 ON THE HIGHWAY.
HELP HELP HELP...What can I check. There are NO SES lights on (that I can see). I have a scanner, I just haven't scanned it yet for background codes.
The car seems to run fine, no misses or anything, the mileage just sux. This is quite a step backward from my SL2 which achieved 33 easily all day with 272K miles on it.
Thanks in advance....
Old 01-26-2012, 10:04 AM   #8
2006 ion2
2007 ION-2 Sedan
did you do everything I suggested in my thread?
2007 Saturn Ion 2
Old 01-26-2012, 10:21 AM   #9
keelerpd
I went back and read the thread again and I need to pull off the throttle body and clean the IAC and TPS. I would imagine the the TB is pretty gunked up, but could this cause this big of a drop?
Old 01-26-2012, 11:00 AM   #10
2006 ion2
2007 ION-2 Sedan
yes, it possibly could. you might want to try everything preventative in that thread, even if you don't think it applies because of your mileage.
2007 Saturn Ion 2
Old 12-29-2017, 09:48 PM   #11
03ioncoupe
03ioncoupe is on a distinguished road
I have a 2003 Ion quad coupe 2.2l ecotec with the cvt transmission
. Im getting about 10 miles to the gallon for some reason.. I just rebuilt the tranny an timing chain an changed spark plugs an air filter..I bought the car from an auction in July an it hasn't been driven since 2015 cause that was the last time it was tabed..so just need to know what to do to fix the bad gas mileage cause there's no check engine light an it runs mint an is Hella quite a smooth..
Add to 03ioncoupe's Reputation
Rate the quality of this post and help 03ioncoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
03ioncoupe is offline   Reply With Quote
Old 12-29-2017, 11:38 PM   #12
duece9s
duece9s is on a distinguished road
2006 ION-2 Sedan
my best is 478 miles (twice, 37.5mpg) i noticed switching to full synthetic i gained about 2mpg.
http://www.fuelly.com/car/saturn/ion...blueion/652913
06 ion 109k
12" L7/mids/tweets
Stock batt + XP950 in the back
29.9 avg mpg/23k miles
37.6 best mpg/478 miles
Add to duece9s's Reputation
Rate the quality of this post and help duece9s reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
duece9s is offline   Reply With Quote
Old 12-30-2017, 02:15 AM   #13
pierrot
pierrot's Avatar
Welcome to SaturnFans, 03ioncoupe! In general, it's not good for a car to sit without being driven for an extended period of time, as it appears is the case with your Ion Coupe. Gasoline can become like a varnish throughout the fuel delivery system if it remains in a vehicle not driven regularly, or if a gasoline stabilizer additive is not poured into the tank prior to long term storage.
I can't be certain as to why you're experiencing very poor fuel economy. Questions: do you experience sluggish acceleration and, conversely, uncommonly rapid deceleration? Do you experience unusually high RPM during acceleration which stays that way when cruising, or does it feel "normal"?
Now, your car has the CVT which - if you don't already know - was a disaster for Saturn and GM. These were warranteed and replaced with a regular automatic transmission. Whether or not your car's transmission can be replaced as a warranty item would have to be answered by contacting GM online, or by telephone.
284,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Poor fuel mileage (I've already covered all the basics) PlasticCarsRock S-Series Tech 91 09-29-2011 06:55 PM
Poor little Ecotec 2.2L C.A.I. Lusiphur220 Vue Mods 5 04-27-2010 09:26 PM
Ls2 poor fuel mileage??? HELP Terribleoneride L-Series Tech 9 10-29-2009 08:09 PM
Poor Fuel Mileage amyseverson Aura General 46 01-02-2008 11:23 PM
Continued hessitations and poor fuel mileage - need more help please hitekrednek S-Series Tech 31 08-07-2006 05:41 AM
