Old 01-08-2012, 03:14 PM   #1
paulclawson3
paulclawson3 is on a distinguished road
2001 SW2
Default Help, key stuck in ignition
Key stuck in ignition how do I get out. Stuck at 'push'
01 Saturn SW2 DOHC (SILVER), auto trans, 96,XXX miles, no signs of burning oil yet. (Wife's Car)
98 Saturn SC2 DOHC (RED), auto trans, burning 1qt. per 300miles, w/ 176,XXX miles
Add to paulclawson3's Reputation
Rate the quality of this post and help paulclawson3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulclawson3 is offline   Reply With Quote
Old 01-08-2012, 03:24 PM   #2
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
Default Re: Help, key stuck in ignition
Try to turn back to ON first, Make sure the steering wheel lock isnt engaged. DON'T OVER FORCE IT. If you cannot get it out, WD40 to loosen the old dirt and grease then relube.
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
Add to simkid5614's Reputation
Rate the quality of this post and help simkid5614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
simkid5614 is offline   Reply With Quote
Old 01-08-2012, 03:32 PM   #3
paulclawson3
2001 SW2
Im stuck in a mcdonalds parking lot, steering wheel not locked up I have no wd40, this happened before, its a matter of jiggling it out
Old 01-08-2012, 03:51 PM   #4
paulclawson3
2001 SW2
Low cell phone batt., still cant get out
Old 01-08-2012, 05:00 PM   #5
Saturn-R
Saturn-R is on a distinguished road
Saturn-R's Avatar
2002 SC1
McDonalds; always a bad idea for various reasons. Here's one more. Wonder how he made out...
2002 Silver SC1, 5spd
248,00KM
154,100Mi
Best MPG: 38.3/7.37L per 100 KM, mixed driving
Add to Saturn-R's Reputation
Rate the quality of this post and help Saturn-R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-R is offline   Reply With Quote
Old 01-08-2012, 05:02 PM   #6
simkid5614
simkid5614's Avatar
This may sound strange, I've actually pulled my key before I've made it to lock. I've had to reinsert it and get it To ACC before i could get it back to LOCK and remove it.
Old 01-08-2012, 05:43 PM   #7
paulclawson3
2001 SW2
I cant get it to lock or acc, or run, nothing. Stuck on push. Vicegrips maybe my only hope
Old 01-08-2012, 06:21 PM   #8
Saturn-R
Saturn-R's Avatar
2002 SC1
When you actually get the key out, make a copy then file the origional down a bit. That MAY let it come out easier in the future. And of course clean and relube the ignition cylinder.
248,00KM
154,100Mi
Old 01-08-2012, 07:14 PM   #9
The last from paulclawson3 @ 05:16 PM:
I got it out used vice grips and pushed in gently and it went to lock and came out, car still works, runs, drives, thank you. I havent downloaded the manual yet I have a macintosh and the zip folder needs me to install a new driver. I will install at worlk on PC windows.... If rotors are rusty could I sandblast them? Or maybe use a grinder? The mesh one? I still need to install battery cables on a 04 dodge caravan sxt.....no good forums
Old 01-09-2012, 12:11 PM   #10
A good chrysler minivan forum, think I got the link from someone here
http://forum.chryslerminivan.net/for...vans-2001-2007
Old 01-10-2012, 09:21 PM   #11
paulclawson3
2001 SW2
Thumbs Up Re: Help, key stuck in ignition
Thank you guys, when you re-lube do I take out something to lube?
Old 01-10-2012, 09:32 PM   #12
Just spray it out with contact cleaner, use an entire can or until it runs out clean. Take the lower cover off the column first though. And put a couple bath towels on the floor. Then after that dries out dust in a small amount of powdered mica. No oil, silicone, grease, graphite etc or you will have another stuck key. You can buy powdered mica at a gun shop that sells reloading supplies.
Old 01-10-2012, 09:34 PM   #13
TXSaturn02
TXSaturn02's Avatar
I've always just 'pumped' graphite (available at most hardware stores) into lock cylinders. It has always worked well for me. OldNuc tends to recommend some sort of 'powdered mica' IIRC, which is used for firearms, I think he said.
New owner As of 01/01/18: 225,000 Miles
As of 03/20/18: 46,135 Miles
Old 01-11-2012, 08:45 AM   #14
Powdered mica is used in lots of places, concrete mold release, cosmetics, paint, and a high pressure dry lubricant, high temperature lubricant, and probably many more. The benefit is it does not clump up or absorb moisture.
Key stuck in ignition bitz_dv S-Series General 1 07-14-2007 06:32 AM
Key stuck in ignition Ziek Aura General 6 10-13-2006 04:22 PM
Key stuck in ignition Maui Jim S-Series Tech 11 10-06-2006 12:36 PM
Ignition Key Stuck mtxo Vue Tech 1 12-03-2005 09:18 AM
Key stuck in ignition grownbratt1 S-Series Tech 3 10-13-2005 10:22 AM
