Old 01-07-2012, 10:38 PM   #1
turbojoe
turbojoe is on a distinguished road
Default where can i buy a clutch release fork for a 99 sl2
Broke mine and cant find one in the jk yard..who sells em?
1999 Staturn SL2 5spd dohc..130,000 stock
Add to turbojoe's Reputation
Rate the quality of this post and help turbojoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbojoe is offline   Reply With Quote
Old 01-07-2012, 10:59 PM   #2
off-track
off-track's Avatar
Default Re: where can i buy a clutch release fork for a 99 sl2
I'm thinking GM dealer only (if they are still available)? Otherwise, someone here might have one?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 01-07-2012, 11:04 PM   #3
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
You need to explain how you broke a clutch fork before I go down to the garage to look . The damn thing is a solid piece of steel.
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 01-08-2012, 12:16 AM   #4
Yep, should be a good story.... (popcorn)
Old 01-08-2012, 10:01 AM   #5
turbojoe
Ha..well when i bought the car it was bent already..how it got that way ill never know..but i tried to straighten it and put it all back together with a new clutch kit and hydrolic system but it broke..
Old 01-08-2012, 10:21 AM   #6
Guess I could sell one of mine.
The fork is the part that clips in on one side, goes around the input shaft (with a release bearing slid on) and then the slave cylinder push's it? Just want to make sure I'm not being a dumbass...
$30 shipped? I can take a picture of it if you want first.
Old 03-27-2012, 10:19 PM   #7
GPCBAKER
GPCBAKER is on a distinguished road
Went to my friendly Chevy dealer today to buy a clutch release fork. The Chevy dealer is where I buy all of my Saturn parts. The dealer said the fork was a discontinued item and no longer available.
Now ----why was I in need of a clutch fork you ask? Simple, the one I removed from my 96 SW2 was "worn out". Yes, I said worn out.
If reference were made to my earlier posts you would find my recent clutch problems were that I had a problem performing the WIRE TEST. Reason being the clutch fork had somehow disengaged from the throw out bearing and dropped downward not allowing the slave cylinder push rod to engage it straight forward toward the dimple in the fork. The drop caused the fork to wear on the bottom edge of the fork against the pressure plate. This caused the throwout bearing to ride against the pressure plate fingers at an angle wearing deep grooves in the pressure plate. I know - all of this sounds near impossible but the fork was ground down real good on it's bottom side. Enough for me to want to replace it. I had replaced the complete hydraulics earlier and hope it's still good.
I may have some welding done where the metal was worn away and reuse the one I have. Ed
1999 SL2, My first Saturn. GONE
1996 SW2, My second Saturn
Add to GPCBAKER's Reputation
Rate the quality of this post and help GPCBAKER reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GPCBAKER is offline   Reply With Quote
Old 03-28-2012, 01:06 PM   #8
svitak33
svitak33 is on a distinguished road
Try rockautodotcom
It wouldnt let me post the url
Add to svitak33's Reputation
Rate the quality of this post and help svitak33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
svitak33 is offline   Reply With Quote
Old 03-28-2012, 05:43 PM   #9
RockAuto does not sell them. You will have to find one in a dead manual trans car as they are all the same it should not be a monumental task. Everytime a manual transmission blows the diff pin it births another spare clutch fork.
97 sc2 clutch fork ? thekeeperspike S-Series General 0 06-13-2011 08:29 PM
Clutch Release Fork Swap Cessna S-Series Tech 1 08-17-2010 08:26 AM
Clutch release fork- FSM specs. anyone? MikeNW S-Series Tech 27 07-22-2008 03:53 PM
Clutch Fork related to clutch problems? MikeNW S-Series Tech 0 06-25-2008 12:27 AM
Clutch Release Fork rschouest S-Series General 4 03-04-2005 04:03 AM
