Old 01-02-2012, 04:26 PM   #1
alram
alram is on a distinguished road
alram's Avatar
2004 VUE 3.5L
Question where is oxygen sensor (bank1 sensor 1)
and can i replace it myself?
thanks in advance
Al
Add to alram's Reputation
Rate the quality of this post and help alram reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alram is offline   Reply With Quote
Old 01-02-2012, 05:13 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: where is oxygen sensor (bank1 sensor 1)
Four or six cylinder?
If V6 - bank 1, sensor 1 would be nearest dash and before catalytic converter.
If 4-cyl - would be sensor before cat.
Might be able to provide an illustration if you post engine.
O2 sensors are almost always user replaceable, but change is easier might be easier using a sensor socket.
Old 01-02-2012, 05:17 PM   #3
alram
alram's Avatar
2004 VUE 3.5L
thanks I was trying to edit the post but the edit button is not shown.
vue 2004 6 cyl. front wheel drive
Old 01-02-2012, 05:22 PM   #4
far2grumpy
far2grumpy's Avatar
alram - copy that - I was trying to edit mine too.
The attachment mentions bank 1, sensor 2 but if you look at drawing - go to item number 1. I can find a better drawing if it'll be less confusing.
Old 01-02-2012, 05:31 PM   #5
far2grumpy
far2grumpy's Avatar
Darn ... see if this attachment makes any more sense.
I also attached a drawing for special sensor tool - they're available at most auto parts stores.
Old 01-03-2012, 10:49 AM   #6
alram
alram's Avatar
2004 VUE 3.5L
thanks a lot...you're the man
i'll try this weekend, right now is too cold
Old 01-03-2012, 11:25 AM   #7
alram
alram's Avatar
2004 VUE 3.5L
By the way...they sell cheap 4 wire universal sensors, can I use it?
looks like mine is a 5 wire (very expensive), what's the difference?.
Can you explain or direct me to where I can learn about it?
Thanks again
Al
Old 01-03-2012, 11:45 AM   #8
far2grumpy
far2grumpy's Avatar
Thanks again
Al
I've used inexpensive sensors and they often outlast the warranty, but not always.
Upstream (Sensor 1) sensors can be twice as expensive as downstream (Sensor 2) because they lead an active life.
I just checked at RockAuto.com - one of my favorite INTERNET parts places - and they have one brand sensor for $80 - plus shipping and the next higher quality is $120.
Many universals will require you to splice wiring to reuse the existing engine wiring connectors. Splicing can be safely done - I'm an expert with 50 years aircraft experience - and I choose to not splice sensor wiring.
Old 01-03-2012, 02:09 PM   #9
alram
alram's Avatar
2004 VUE 3.5L
I splice wires before but I always use solder. The splice will add a little bit of impedance to the line but I wonder if is enough to affect the operation of the sensor.
How about the difference between 4 and 5 wires? at this point I think is more important to me to know the difference.
Old 01-03-2012, 03:44 PM   #10
far2grumpy
far2grumpy's Avatar
alram ... see attached sensor schematic extracted from service manual. The upstream sensor (1) has seven wires and downstream (2) has four.
Make sure you're looking at correct replacement device.
Old 01-03-2012, 05:09 PM   #11
alram
alram's Avatar
2004 VUE 3.5L
WOW....looks like I'm going to have to spend some money for the correct part.
many thanks again
Old 01-03-2012, 07:31 PM   #12
RobertGary1
Yea, definitely do not splice a universal in, the splice will eventually fail. Either solder the universal connector on or just pay the price for the OEM style. Personally, I find the OEM is worth it. You can change the sensor with OEM in about 15 minutes without much more effort than to simply plug the new connector in.
-Robert
many thanks again
Old 01-14-2014, 12:28 PM   #13
mwinns13
mwinns13 is on a distinguished road
2008 VUE 3.6L
Do you happen to have a diagram for the O2 sensor locations on a 2008 Saturn Vue XR with a 3.6L engine?
I've been looking all over the internet and have found more info on these forums than anywhere else.
Thank you.
Add to mwinns13's Reputation
Rate the quality of this post and help mwinns13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mwinns13 is offline   Reply With Quote
Old 01-14-2014, 01:36 PM   #14
far2grumpy
far2grumpy's Avatar
Thank you.
I've attached two service manual extracts for 3.6 bank 1 and bank 2 HO2S sensors.
Bank 1 is three cylinders nearest the firewall (windshield) side of engine and sensor 1 is before (upstream) catalytic converter and sensor 2 (downstream) is after.
Bank 2 is nearest radiator - sensor 1 before cat - sensor 2 - after cat.
These are rough extracts - sensor replacement files are more informative but are too large to post - I'll email if you PM address (left click on my screen name).
Old 01-16-2014, 01:33 PM   #15
mwinns13
2008 VUE 3.6L
Thank you very much, your post is the only correct answer I've received.
Old 03-26-2018, 11:47 AM   #16
Kkugel
Kkugel is on a distinguished road
Hi all,
I have a 2006 Saturn Vue, 2.2L 4CYL. I have a check engine light. Codes: P1133, P0033, P0133, P0135, P0137(i think).
My code reader references HOS2 Bank 1 for all of these codes.
I donít have my list in front of me but some of these reference a low voltage state and a heater failure. I believe this is all related to the sensor itself.
I need to know if someone can send me a picture of teh HOS2 bank 1 sensor location and if there is another sensor (downstream maybe?) where it is.
I replaced the O2 sensor that is on the back (meaning the rear side of engine facing the firewall) that looks like it is plugged in just after the exhaust manifold. Is this the bank 1? I purchased it from Oreilly. I think its a bosh, canít remember.
Any help would be appreciated. Thanks
KK
Add to Kkugel's Reputation
Rate the quality of this post and help Kkugel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kkugel is offline   Reply With Quote
Old 03-26-2018, 12:42 PM   #17
Beasleylou
Beasleylou is on a distinguished road
You access sensor 1 from the top. It is in the exhaust manifold facing the drivers side.
Sensor 2 is accessed from below. Iirc it faces the passenger side.
Add to Beasleylou's Reputation
Rate the quality of this post and help Beasleylou reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Beasleylou is offline   Reply With Quote
Old 03-28-2018, 06:07 AM   #18
Kkugel
Thanks!
New problem. I have replaced teh upstream O2 sensor and that fixed teh p0135 code. New code popped up now: P0172 (too rich). I have replaced the mass air sensor and the sensor in the charcoal canister. Any help would be appreciated. This is driving me nuts.
Old 03-28-2018, 06:09 AM   #19
Kkugel
2006 Vue...2.2 Cly
Old 03-28-2018, 11:12 AM   #20
Beasleylou
There is no MAF in that engine. Perhaps you replaced the MAP?
Rich condition...
Youíve dealt with the o2 and MAP...
Check airway next. filter, etc.
Then ignition. plugs, coils, icm, etc.
Then fuel system. Pressure, injectors, etc.
If you have a scan tool, check that engine coolant temperature seen by the ecu appears accurate. Should equal ambient after long park over night, etc.
oxygen sensor ns087 S-Series Tech 29 02-17-2014 07:50 AM
Oxygen Sensor TXSaturn02 S-Series Tech 4 11-17-2010 02:35 PM
Heated four-wire sensor oxygen sensor dbaier S-Series Tech 13 01-26-2008 03:45 PM
SES, Oxygen Sensor, Bank 1 Sensor 1 Shadowless L-Series General 3 09-03-2007 08:23 AM
p0137 bank1 sensor 2 irondiezl3 S-Series Tech 2 02-28-2007 07:07 PM
