Old 12-30-2011, 09:05 PM   #1
Dukenukemx
Dukenukemx will become famous soon enough
Dukenukemx's Avatar
Default Lots of play with new struts
Put two new KYB struts in the front of my Saturn, and there's a lot of play with the upper portion. When I put the strut on, the upper bolt is tighten all the way, but there's still a gap between the strut and the car. I can't tighten the bolt anymore. I didn't change the strut mount, but it didn't look bad to me.
The car sits just fine, but there's a half inch gap between the strut and the plate that's suppose to hold the strut to the car. It's like this on both sides.
Is this OK? Is the bolt too big that came with the strut? There's a bolt for the strut and a bolt to hold the strut to the car. Both bolts are literally on top of each other, and that's why I can't tighten it much more.
Stock (for now) 2000 Saturn LS2
Add to Dukenukemx's Reputation
Rate the quality of this post and help Dukenukemx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dukenukemx is offline   Reply With Quote
Old 12-31-2011, 10:02 AM   #2
Dukenukemx
Dukenukemx's Avatar
Default Re: Lots of play with new struts
This morning I used the old bolt from the old strut, and the gap shrank. I don't get what I could have done wrong. The old bolt was smaller in height.
Old 01-08-2012, 08:22 AM   #3
KLS1P
KLS1P is on a distinguished road
2004 L-Series 3.0L Sedan
A new strut bearing / upper mount will help reduce the gap. A small gap is normal.
Add to KLS1P's Reputation
Rate the quality of this post and help KLS1P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KLS1P is offline   Reply With Quote
My Play toy and my DD richbrad08 S-Series General 6 07-22-2011 03:04 AM
Using lots of oil yoopers S-Series General 4 08-24-2009 08:37 PM
Gas Peddle Too Much Play BobbyBeans S-Series Tech 6 06-08-2009 09:35 AM
End play and rod cap Q inplansight S-Series Tech 3 06-26-2007 10:27 PM
aftermarket struts by sprint (xs struts) s-series SL2sleeper S-Series Mods 3 08-19-2006 08:24 AM
