Old 12-27-2011, 03:14 AM   #1
shaxs
shaxs is on a distinguished road
Default Running cable for backup camera & tapping into reverse lights for backup sensors
I will be installing a backup camera on my wife's 2007 vue. I will be using a license plate model. So I need to run the wire through the backdoor and all the way up to the front. What would be the best way to do this?
Also, I will be installing this backup sensor http://www.amazon.com/gp/product/B002XUXUTS/ which is also attached to the license plate area. I want to hook these up to the reverse light wire so it only comes on when the car is in reverse. Does anyone have any suggestions or tips for doing this as well?
Add to shaxs's Reputation
Rate the quality of this post and help shaxs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shaxs is offline   Reply With Quote
Old 12-29-2011, 04:27 PM   #2
shaxs
Default Re: Running cable for backup camera & tapping into reverse lights for backup sensors
Does anyone have any information on how to remove the inside covering to the back door? Also which wire do I need to tap into to get constant power for the camera and which is the reverse light wire to tap into to get power only in reverse for the backup sensors?
Old 12-29-2011, 04:53 PM   #3
far2grumpy
far2grumpy's Avatar
shaxs ... I have service manual extracts to remove the rear hatch trim panel. Too large to post but I'll email if you PM address.
You appear to be SOL finding a "hot" wire near rear of Vue for camera power ... you'll need to run from one of front fuse boxes.
I've attached back-up light schematic - remove either rear lamp assy (check owners manual for bulb replacement) to locate light-green wire.
Routing the back-up signal and power wiring to camera will be a challenge. Keep in mind ... anything worth doing goes better with a few suds.
Old 12-29-2011, 05:37 PM   #4
shaxs
Thanks for your feedback. I can build a computer like no other but messing with car electronics makes me nervous!
I was looking at my wife's vue and I see there are license plates bulbs that seem to be on at all times. Can I hook into their power or no?
Old 12-29-2011, 07:05 PM   #5
Not to spoil your enthusiasm for wanting safety with a back-up camera system but are you sure the one you linked to is a camera system? I see a back-up sensor - that means just a radar like sensor with a small horn to beep at adults, children or animals. A flashing light would be visible to deaf people. On the same page is another system that's marked as a camera system. Perhaps that's what you want as it shows the little monitor to observe the rear view camera from.
With f2g's pdf's, you should be able to use the rear back up lights as power to turn on the camera system. Wiring for accessory power (switched ON only when ignition is ON) may require running a separate power wire from one of the switched fuses located in your Vue - defroster, radio, rear wiper, etc..
Old 12-29-2011, 07:07 PM   #6
shaxs
Im adding both sensors and a camera. I found a license plate camera rated well that fits in between the sensors on the license play backer.
I assume I should run the video cable on the opposite side of the car from any power and amp power lines correct?
Oh and that backup sensor has a speaker in the car to tell the driver when they are approaching obstacles. Not really for use to people outside the car.
Old 12-29-2011, 10:10 PM   #7
I see now. As far as running video cabling, I'm no expert on this and if this were my set up I would run the shortest distance between camera and display with little regard to anything electrical/electronic. The difficulty I see is where to tear up the interior for the least amount of effort to run the cabling. My 2-cents worth is essentially powering it up immediately with everything laid out before tearing the interior apart just to see it work and then decide on where the cabling should run. Other than the console area's highest concentration of electronics, having OnStar and/or GPS puts these two things in the over head area and away from the console, leaving the rest of the floor and sides for power wiring. Power wiring shouldn't be an issue. Its presumed the video cable is the shielded type unless there's a less expensive wiring scheme using net work cables or something similar that doesn't have a thin aluminum sheet or wire braid for rf shielding under the vinyl insulation. Most aftermarket add-ons may instruct you to route wiring away from electrical/electronic cabling but if not then there shouldn't be any concerns. As with any mods, treading lightly and laying cable where its wanted should also allow you to run the engine and everything else electronic while trying out the back up camera several times to ensure the cabling isn't picking up any interference nor feeding it back to any electronics - its a two-way street with electronics. Finalizing everything and having the engine/electronics running with the back up camera on before putting everything back together to hide all your work goes a long way to ensure this doesn't need revisiting while everything is all apart for any rearrangement. Sort of like the wife wants the chair there while you want it here - don't put anything back together until the camera works with the engine running as in its normal state but with all the interior parts removed for cable placement. Once its determined that everything works and Murphy won't stab you in the back, reassemble everything and enjoy backing up into objects that you can now see.
Old 01-04-2012, 02:53 AM   #8
shaxs
Alright! I got the camera installed. Found a "hot" wire in the license plate lights. Tapped into that just fine.
I also found the reverse wire in the back of my car and hooked up my parking sensors. I also found a black wire in the same area and assumed that was a ground and hooked into that. I am having problems with the sensors though. Is it right to assume that black wires = ground?
Here are some pictures:
https://picasaweb.google.com/lh/phot...eat=directlink
I also used my handy dandy test light to find the reverse wire closer to the dash so I can hook the reverse wire trigger from the headunit.
Old 01-04-2012, 07:01 AM   #9
Usually, black is ground but its better to use either a test light or meter to find ground; test light connected to a HOT wire and the probe touching ground wires. Same for a meter; one probe connected to 12v and the other probe touching ground connected wires. The source of 12v needs a ground and will turn on the light or display 12v on the meter. Or drill and use a self tapping screw into sheet metal for a ground.
Old 01-04-2012, 01:27 PM   #10
shaxs
Thanks I will double check today and see if I do have a grounding problem. I am pretty sure, however, I just have a defective unit which is a pain in the but to uninstall and send back. If that is the case, I may leave off the backup sensors.
Old 01-04-2012, 11:42 PM   #11
far2grumpy
far2grumpy's Avatar
shaxs ... you're becoming a auto wiring whiz.
I have two or three thoughts - do the parking sensors expect positive or negative trigger when tied to back-up lighting circuit. It'd be +12 on your Vue.
The only 12V source I could see in rear-hatch is red/blk wire from BCM to the door ajar switch. Many times this voltage is from a small IC and is not really designed for much more than .25 amps. The camera probably does not pull much current but if your hatch ajar lamp comes on - and stays on - it'll be a bad sign.
I checked diagrams for turn signals, parking, brake and back-up lights and the grounds for all are black wire.
Old 01-05-2012, 01:18 AM   #12
shaxs
Todays update:
Wired the reverse wire close to the dash to the head unit. The backup camera now comes on automatically whenever the car is put into reverse and it switched back to whatever was on the screen after it goes into park. I did blow a fuse at one point to the backup lights. Had to change the fuse under the hood. I didnt have the connection at the head unit taped off while testing and it may have grounded against metal or something.
I ran the video wire up the back pillar and put it under the headliner all the way to the front a-pillar on the passenger side. I was able to use a flathead screwdriver to kind of push it up under the headliner without taking it down. I unfortunately snapped one of the pegs and clips off the top trim piece at the roof and liftgate area. I super glued it back on as it was a clean cut. I hope it holds when I re-install the trim.
I installed the bluetooth mic in the driver side a-pillar at the top where it meets the headliner. Tested it out and my wife says it sounds great. We will see how it sounds once she is going 65 on the highway.
Now back to the backup sensors. Using my multimeter, I was able to ascertain I did tap into a ground wire. I was showing my neighbor (who was also out working on his truck at the time hah) what the issue was. We both agree it is porbably a bad connection in the factory plug (something that came that way from factory). At this point, I am thinking of uninstalling, returning, and forgetting about sensors. With a backup camera, it should be enough. It was a PAIN to wire up this sensor (and camera). I had to remove the exterior liftgate chrome trim to run wires from the license plate area into the suv. That required removing/loosening the rear wiper motor. So its not really something I want to do too often. Here is a video I took to show the manufacturer of what the issue is exactly: http://youtu.be/Ka3XEuZJJQM.
Old 01-05-2012, 02:34 AM   #13
shaxs
FYI incase anyone is interested, these are the install directions: http://www.nvisionsafety.com/doc/601...structions.pdf
I have installed as specified. Just have the wonky connection as shown in the video.
Old 01-05-2012, 05:40 PM   #14
shaxs
I called tech support and they were less than useless. I think the guy might have been stoned. Not sure. Didnt even understand/know the product. Hes going to send me a new cable.... Okay...
Oh well. My wife wants her car back so it looks like I will be taking off the sensors completely and doing without them.
Old 03-05-2012, 09:08 PM   #15
GaryNewhouse
GaryNewhouse is on a distinguished road
Am trying a similar camera in a 2008 vue....
It's a license plate rig and am having a problem getting plastic lift gate trim/panel off so I can route wiring....two screws and handhold screw don't seem enough to free it....any ideas?
Add to GaryNewhouse's Reputation
Rate the quality of this post and help GaryNewhouse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GaryNewhouse is offline   Reply With Quote
Old 03-05-2012, 11:04 PM   #16
far2grumpy
far2grumpy's Avatar
Will any of the attached help? Let me know if you need others.
Old 03-10-2012, 10:07 AM   #17
GaryNewhouse
Beautiful Thanks
QUOTE=far2grumpy;1852944]Will any of the attached help? Let me know if you need others.[/QUOTE]
Old 10-15-2016, 12:23 AM   #18
Georgie
Georgie is on a distinguished road
Todays update:
I know this is an old thread but I hope someone else can chime in.
I'm about to try and install a backup camera on my 07 AWD V6 Vue this weekend.
My Pioneer head unit (4100NEX) has a "reverse trigger" cable, did you find where to plug that one in to? Can you share where in the dash is it located or what color cable I'm looking for?
As for the back, the OP mentioned he was able to plug the red and black cables to the license plate light cables but then blew a fuse. Should I try and hook up to the reverse light instead?
Thanks guys!
Add to Georgie's Reputation
Rate the quality of this post and help Georgie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Georgie is offline   Reply With Quote
Old 10-19-2016, 12:13 PM   #19
kej53
kej53 is on a distinguished road
I recently installed a Pioneer AVH4200NEX in my 2007 VUE. Like your unit mine also has a reverse wire coming from the Pioneer wiring harness. There is a light green wire that comes from the rear reverse lights. I tapped into it behind the drivers side kick panel. I mounted the license plate type camera and ran the wire from the rear hatch to the front of the car. I can explain in more detail if you PM me at club55_14@hotmail.com
Add to kej53's Reputation
Rate the quality of this post and help kej53 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kej53 is offline   Reply With Quote
Old 08-02-2018, 02:07 PM   #20
Veritas
Veritas is on a distinguished road
2007 VUE 2.2L
Thumbs Up Re: Running cable for backup camera & tapping into reverse lights for backup sensors
Hello all, upping an old thread. I am going to be putting a Boss BN965BLC Nav unit in my '07 Saturn. It has the backup camera license plate mount, going to see if I can get that wired up. The info in this thread is very helpful.
Add to Veritas's Reputation
Rate the quality of this post and help Veritas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Veritas is offline   Reply With Quote
Backup (Reverse) lights not working Kenk L-Series General 4 02-25-2012 02:42 PM
Backup camera install location? slonoma98 Vue Mods 4 06-30-2011 09:49 PM
Backup Camera XRL Vue Mods 1 03-24-2010 04:34 PM
Backup Camera on New Nav Vas Outlook General 4 01-20-2008 04:21 PM
Backup sensors Boodah Aura General 11 01-17-2008 08:38 PM
