Old 12-26-2011, 07:55 PM   #1
jcc007
jcc007 is on a distinguished road
2006 ION-2 Quad Coupe
Happy 2003 Saturn vue V6 transmission fluid change
I have a 2003 Saturn vue v6 engine, and I do allot of the work myself.. I change my own oil and use Mobil1 5w30 high mileage since the vehicle has 183,000 mile on it.. How do you change the transmission fluid in this vehicle? My chilton manual says I dont need to change it, but there is a delay by a second or two when I shift gears, and with the high mileage I know it needs to change. If anyone knows of a youtube video or a step by step instructions, would be great! Thanks JCC
Add to jcc007's Reputation
Rate the quality of this post and help jcc007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcc007 is offline   Reply With Quote
Old 12-26-2011, 09:04 PM   #2
Chazberry
Chazberry's Avatar
Default Re: 2003 Saturn vue V6 transmission fluid change
This thread should have everything you need to know . . .
http://www.saturnfans.com/forums/sho...d.php?t=153950
Add to Chazberry's Reputation
Old 12-28-2011, 08:11 AM   #3
VTchemist
VTchemist's Avatar
I too own a 2003. Saturn changed the service interval from 100,000 to 50,000 miles for the 2003 V6 automatic.
Not sure if you have a FWD or a AWD. If you have the AWD, you will need to change the RDM fluid and the PTU fluid.
Recommended service for the RDM and PTU was 90,000 miles. Most posters here do it more frequently.
There are some good threads on the site for the RDM. A few folks have tried the PTU fluid change.
Hope this helps.
Add to VTchemist's Reputation
Rate the quality of this post and help VTchemist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-28-2011, 09:54 AM   #4
jcc007
Hope this helps.
Hi,
I have a FWD.. Since I have a FWD do you know what type of fluid I should use and also where is the fill cap located at? I looked in my chilton repair guide and it doesnt specifically tell me where it is located at. Thanks.. JCC
Old 12-28-2011, 11:07 AM   #5
far2grumpy
far2grumpy's Avatar
Originally Posted by jcc007 View Post
Hi,
See attached GM service manual extract.
Extract lists fluid type, quantity and fill location (dipstick hole).
If your fluid is very old you may want to change several times - perhaps at 100 mile intervals.
Old 12-28-2011, 11:14 AM   #6
jcc007
Thank you for the PDF, I just printed it out and noticed its for the AWD.. I have the FWD Vue. If possible can you post a pdf for the FWD? Also My dipstick is not visible on this vehicle, I heard that I have to remove the battery compartment to access it.
Thank you for your help.. JCC
Old 12-28-2011, 11:31 AM   #7
far2grumpy
far2grumpy's Avatar
Ah so, I checked a newer version of FSM and it appears FWD trans needs 4.29 quart to refill.
The FWD file is too large to post. I'll email if you PM an address.
I don't have a 3.0 and couldn't advise what needs to be removed to access dipstick.
Did you visit the link provided by Chazberry (post # 2) of this thread?
Old 12-28-2011, 11:38 AM   #8
jcc007
Awesome! Here is my email address James.Crowton007@gmail.com
Yes I did read Chazberrys post in this thread but its refering to the AWD and not the FWD.. Allot of my questions were getting answered but was too the AWD and not the FWD.
Thanks, a million I really appreciate it allot! :-)
Old 12-28-2011, 11:59 AM   #9
far2grumpy
far2grumpy's Avatar
I'm assuming the 3.0 AT is similar to 3.5 transmission which means you'll not notice any topside hardware differences between FWD and AWD - other than need to add extra 16 oz of ATF.
The AWD prop-shaft adapts to the PTU which is attached to transmission case on lower-front-inner side.
BTW - I reduced dpi for FWD transmission fluid change extract and will attach for other members future use.
Old 12-28-2011, 12:16 PM   #10
jcc007
Do you know where the dipstick or fill cap is located on the FWD? I read that I might have to remove the battery and the battery holster to access it. I looked and looked and still cant find it. I heard its really buried inside the vehicle on the drivers side. If you can upload a picture or pdf of where it is, that would be great. Thanks, James
Old 12-28-2011, 12:39 PM   #11
far2grumpy
far2grumpy's Avatar
I've attached another FSM extract - if thats the torque converter housing it means the dipstick is near engine.
Best bet is to check Chazberry photos in post # 3 of this thread:
http://www.saturnfans.com/forums/sho...d.php?t=158509
Old 12-28-2011, 01:11 PM   #12
Chazberry
Chazberry's Avatar
This post has a pic of the dipstick - it's a little right of the oil filter canister. These pics are of my FWD '03. There is no fill cap - you have to slowly fill through the dipstick tube.
http://www.saturnfans.com/forums/sho...08&postcount=3
Old 12-28-2011, 01:58 PM   #13
jcc007
Chazberry Thank you for the pictures, I can now easily find the right drain plug and Ill look for the dipstick this weekend. Also Im going to pick up ATF Type-IV from the dealership, but with my vehicle being 183,000 do you recommend getting a high mileage ATF type-IV first? If so what brand?
Thanks, James
Old 12-28-2011, 02:16 PM   #14
jcc007
Thanks, James
I called my local dealership and he said that I can use Dextron 6 in it..
Old 12-28-2011, 03:16 PM   #15
Chazberry
Chazberry's Avatar
Many folks here using MaxLife. Valvoline says it exceeds Dexron VI and can replace just about anything, including T-IV . . .
http://www.valvoline.com/pdf/maxlife_atf.pdf
Old 12-29-2011, 06:29 AM   #16
Rivernut
Rivernut will become famous soon enough
Rivernut's Avatar
I have an '03 3.0 liter V6 AWD with 196,000 miles. I changed all three fluids at about 90,000 and haven't changed them since. I used Mobil1 tranny fluid for the automatic tranny. Dipstick is a tiny blue plastic thing on the right, way down and hard to reach. I may have used needle nose vice-grips to help reach it. I think I used a long skinny funnel, maybe a piece of hose over tube and end of funnel. The capacity may be less if you don't drain the torque converter. Never had any tranny, transfer case issues. The rear module was noisy and replaced under warranty, been fine since.
Add to Rivernut's Reputation
Rate the quality of this post and help Rivernut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rivernut is offline   Reply With Quote
Old 12-29-2011, 10:16 AM   #17
jcc007
Chazberry, I wish I could shake your hand, I want to thank you for taking time to answering my questions. Thanks to you, I found my Dipstick for the transmission. When you told me to look near my oil filter I did and I saw it and it was so filthy I couldnt recognize it!! Im going to change my transmission this friday, but I want to know. Can you tell me how I can drain the torque converter while I drain the transmission? Im afraid to see the fluid in my transmission, when I drain it. Im going to the store and see if I can get valvoline max life transmission fluid
Old 12-29-2011, 10:18 AM   #18
jcc007
How did you drain the Torque converter? Can you upload a photo of what hose I need to take off to drain it?
Old 12-29-2011, 10:51 AM   #19
jcc007
Far2grumpy, Thank you for uploading the Pdfs on how to locate and find the transmission dipstick and how to drain the transmission as well. I easily found it last night when I got home from work. Tomorrow Im going to change the transmission fluid tomorrow with Valvoline max life. But when I drain it Im going to let it drain till no drips are coming out, make sure all the old fluid is removed.
Thanks, James
Old 12-29-2011, 11:45 AM   #20
Chazberry
Chazberry's Avatar
I wouldn't worry about that. The pic of my draining fluid shows what it looked like after changing it for the first time at about 100k - pretty dark, but I haven't had any driveability issues. Yours will probably look pretty nasty if this is your first fluid change. If your tranny shifts fine after the drain/fill, maybe do it again after a few k miles.
Btw - how many miles on this VUE when you got it? Was the 100k service (Timing Belt, Water Pump, Spark Plugs) definitely done? Original T'stat in there?
Sounds like maybe you need Cam Cover Gaskets, too.
2003 SAturn Vue Transmission Fluid Service broons1 Vue General 26 02-25-2013 04:38 PM
2007 Saturn Vue Automatic Transmission Fluid Change greensaturn How-To Library 9 12-31-2012 01:04 AM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 05:57 AM
2003 Saturn Ion Transmission Fluid rchiarito Ion Tech 4 04-05-2008 10:40 AM
2003 Saturn VUE Manual Transmission Fluid sinhlee Vue Tech 3 10-03-2007 08:25 PM
