Go Back Forums > Categories > General Saturn Discussion
Old 12-25-2011, 12:54 PM   #1
OrionRed is on a distinguished road
Wrench Question after I've replaced my ignition switch
2006 ION 3 - had the cold day won't start problem for a few years before finding out about it here.
I have replaced the switch, done the re-learn thing and it's running great.
My question is about the fit of the replacement switch. The old switch came out easy enough. I had to gently wiggle it a bit with the key in the RUN position.
However, the new switch seemed to not want to go into the slot very easily. I lined it up right, had the key in the same position, but the plunger in the center seemed to give a LOT more resistance than the old (original) switch. If I didn't press down on it, the switch wanted to float about 2mm out of the socket.
When I turn the key, it has the slightest catch at each position, but I can still turn it without forcing it.
Was there a big step I missed somewhere in there?
Add to OrionRed's Reputation
Rate the quality of this post and help OrionRed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OrionRed is offline   Reply With Quote Sponsored Links
OK replaced ignition switch, still won't start, PLEASE HELP bmc61897 S-Series General 13 02-10-2010 12:10 PM
Replaced Ignition Switch + Housing - Now it won't start! unccjester S-Series Tech 5 06-18-2008 10:50 PM
Replaced Ignition Switch Didn't need to relearn passlock Ronster Ion Tech 4 05-03-2007 07:30 AM
Ignition Switch Replaced dlczrx Ion Tech 0 12-16-2006 05:52 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
Copyright ©2000 - 2018, vBulletin Solutions, Inc. The Saturn Enthusiasts Site.
