Old 12-17-2011, 01:00 PM   #1
mak3000
mak3000 is on a distinguished road
Default Low Coolant warning light keeps flashing
Hello all,
1999 Saturn SL1 w/119K miles, auto transmission
I have a question. The red low temperature and coolant light keeps flashing yet all the fluids are topped and new thermostat,engine coolant sensor were replaced.The coolant was drained also. The car runs just fine. No leaks no smoke.Could it be one of the sensors? And where is it located at? Any ideas ? I really appericiate your support.Thank you.
Add to mak3000's Reputation
Rate the quality of this post and help mak3000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mak3000 is offline   Reply With Quote
Old 12-17-2011, 01:42 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: Low Coolant warning light keeps flashing
Are you getting any SES codes? Might need a new thermostat, especially if you've never replaced it.
New owner As of 01/01/18: 225,000 Miles
As of 05/10/18: 48,065 Miles
Old 12-17-2011, 01:54 PM   #3
Cheyne
Cheyne will become famous soon enough
2000 SL2
The coolant level sensor is stuck. See this richpin video:
http://www.youtube.com/watch?v=-5814yr2p_Y
Add to Cheyne's Reputation
Old 12-17-2011, 03:21 PM   #4
mak3000
The thermostat is newly replaced. I have cleaned out the reservoir also. No codes.Thanks.
Old 12-17-2011, 03:34 PM   #5
When you cleaned out the reservoir, were you able to hear the float moving inside it?
Add to madpogue's Reputation
Old 12-17-2011, 04:27 PM   #6
mak3000
I cleaned it out today. I heard it when I shook it but not sure if it was ok.
Old 12-18-2011, 01:01 AM   #7
holydiver
holydiver is on a distinguished road
holydiver's Avatar
2002 L-Series 2.2L Sedan
The best thing to do (and I did this...works like a charm) is remove the overflow tank, take it into the house and put a little dish soap in it. Cover the holes and shake vigorously. This will clean out the $h1t in there. Reinstall it and it should be like new.
'96 Saturn SL2 5-Speed, 141k, Rebuilt Engine (My Toy)
'96 Saturn SL2 Automatic, 187k (The Project)
'02 Saturn L200 2.2L Auto, 119k (Dad's Car)
Add to holydiver's Reputation
Rate the quality of this post and help holydiver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
holydiver is offline   Reply With Quote
Old 12-18-2011, 08:51 AM   #8
2NDSOUT
2NDSOUT's Avatar
1999 SL
As a precaution, if you have already cleaned the overflow tank, and the T-stat was replaced; it may be time to check both the driver's side top of the radiator (For the infamous hairline crack), and also check the water pump. If you see coolant (or dried coolant remnants) underneath the passenger side of the car, you may have a very slow leaking starting from the water pump. If the radiator is leaking, the whole radiator will need to be replaced.
They are fairly easy to replace, and a new water pump will run roughly about $25-$50, while a new radiator will run anywhere between $85-$150, based on the brand.
Welcome to the forum.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 12-18-2011, 07:13 PM   #9
mak3000
Thank you very much guys.
Old 12-20-2011, 05:34 PM   #10
mak3000
I have just checked the radiator and jackpot ! I have a leak coming from the top of the radiator from the driver side.Should I try "stop leak" or just get the radiator changed?Thanks Again.
Old 12-20-2011, 06:12 PM   #11
TXSaturn02
TXSaturn02's Avatar
No No No
Yes.
Old 12-20-2011, 06:12 PM   #12
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Get the radiator changed.
When my end tank cracked (they all do right around 10-12 years), then my expansion tank cracked, then my water pump seized.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 12-20-2011, 06:16 PM   #13
hit_n_run
hit_n_run is on a distinguished road
I think I'm right there with you. Radiator is brand new (from previous owner) but I've had to replace the coolant reservoir, and now I'm hearing an intermittent loud squealing noise from the water pump area.
This could also explain the coolant light coming on every now and then.
To the OP, glad you found your problem. Just REPLACE the radiator. It takes a whole 20 mins if you have a decent socket set and mediocre mechanical skills.
Add to hit_n_run's Reputation
Rate the quality of this post and help hit_n_run reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hit_n_run is offline   Reply With Quote
Old 12-20-2011, 08:37 PM   #14
adventureoflink
adventureoflink's Avatar
And when you do get it changed, make sure you use the Silla or Delphi replacements. Both can be found on amazon.com
if Andy from AMR Enginnerring is still in the fabrication biz, contact him. he makes/made a metal radiator for the S-series, 1994-2002
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 12-20-2011, 09:45 PM   #15
off-track
off-track's Avatar
Classic sign of a tensioner nearing end of life.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 12-20-2011, 11:07 PM   #16
2NDSOUT
2NDSOUT's Avatar
1999 SL
Could also be the Serp Belt needing to be replaced as well..
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 12-21-2011, 01:17 AM   #17
adventureoflink
or it could be the alternator, power steering pump, A/C compressor, and/or *gasp* even the crankshaft pulley
best you can do is take off the belt and inspect it for cracks/imperfections and spin all your drive belt accessories by hand to find the noise(s)...
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 12-21-2011, 09:44 AM   #18
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
If the tensioner is at the end of its life, probably safe to assume the belt has had a long life as well and should be replaced with the tensioner. At least, that's what I'd do.
Not a Saturn.
Old 12-29-2011, 11:28 PM   #19
mak3000
Problem solved ! I have changed the coolant reservoir tank. The light don't flash anymore. What a relief...
Old 12-30-2011, 07:04 AM   #20
Signmaster
Signmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to behold
I thought the leak was in your radiator?
I've thought about changing my coolant reservoir as a precaution/appearance issue. It's all yellowed and faded and next to the new looking washer fluid reservoir it seems fragile and looks horrible.
Low coolant and temp warning light flashing briefly when cold outside shallow S-Series General 24 08-26-2014 03:41 AM
Coolant Warning Light Flashing LoganSan S-Series General 41 11-18-2011 05:29 PM
AWD warning light flashing ski2moro 2008 Vue 7 02-06-2009 10:04 PM
Flashing warning light above coolant temp gauge SLoneDC S-Series Tech 15 04-06-2007 06:32 PM
FLashing Low Coolant/High Temperature Warning jndalton S-Series Tech 16 10-28-2005 02:36 PM
