Old 12-16-2011, 01:28 AM   #1
Smokeater
Smokeater is on a distinguished road
1996 SL1
Dazed Low beams stay on
I have a 1996 Satun SL1. The low beams stay on with the key out of the ignition. If ypu turn on the high beams the low beams do stay on. When the this occured the DRLs quite working. Every now and then when I push in the clutch pedal in the DRL indicator will come on. I have removed the DLR relay and the lights stay on. I have checked fuses and they are good. I searched in this section and could not find anything. The high beams do work, I have to drive with them on because I disconnected the low beams. Any suggestions would be greatly appreciated.
Smokeater is offline   Reply With Quote
Old 12-16-2011, 01:48 AM   #2
Default Re: Low beams stay on
yes, go into my photo gallery and there is a schematic for the lights. The lights are switched on the ground side of the circuit. Most likely physical place for the problem is the light stalk, lever combination switch.
Headlight Schematic part-1 and part-2 are the drawings you are looking for. Select them and then under options select print and print them out so you can read and draw on them.
<-----Photo Gallery link
Old 12-16-2011, 11:26 AM   #3
Smokeater
1996 SL1
Default Wiring
Awesome thanks! I will print the schematic out and trace the wires this weekend.
Old 12-16-2011, 12:04 PM   #4
bluesl2
bluesl2's Avatar
You may want to look at the wires right behind the headlamp sockets, sometimes the wires chafe on the headlamp brackets.
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 12:06 PM
Hi and Lo Beams on together... urban Ion Mods 16 12-04-2008 06:58 PM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 05:10 PM
Fog lights to stay on when high beams are on Dave19yz S-Series Tech 12 12-26-2007 06:46 PM
96 SC2 headlights pop up, hi beams work, lo beams don't pantero21 S-Series General 5 05-06-2006 04:46 AM
