Old 12-13-2011, 02:32 PM   #1
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Wrench How to Convert Marker Lights to LED
I've been getting my SL2 ready for safety inspections, so I was checking the lights. I noticed that one of the marker lights was out. Turns out the wire had corroded and the bulb broke in the socket, so I couldn't simply put in a new bulb. That's where I got this idea.
Tools:Knife or thin screwdriver to separate the lens halves.
Items:Flex LED, Amber 8" (it's a pair of 4" strips), silicone sealant to hold the lens together afterwards.
If you do break a lens, you can get it here.
Sorry about the picture quality. This was an older phone.
First, I took both lenses and separated them. This is very tough to do without breaking something! Be careful!
After I cleaned the inside of the lens, I inserted the LEDs in the lens. I ran the wires out the hole where the socket used to mount. I'd recommend sealing that hole to prevent moisture from getting in.
Then I put the lens back together and installed them.
This is before (obviously this is the working one),
and this is after,
It was definitely brighter, and the best part is, no more bulb burnout!
I plan on eventually doing the turn signal hack, where these lights blink with the turn signals.
What do you guys think? First mod and first how-to ever!
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 12-13-2011, 06:58 PM   #2
Default Re: How to Convert Marker Lights to LED
This might be a dumb question, but why not just use the wedge style LED that plugs in with no modification?
http://www.superbrightleds.com/cgi-b...ini-wedge.html
Should be either of the first two.
edit: Oh, I see. Your's has more length inside the reflector then the bulb style. Makes me think you need a longer strip to fill the whole thing...
Old 12-13-2011, 07:48 PM   #3
sallydriver
1993 SW2
Well, my socket was corroded beyond repair. That's the main reason.
Plus, I like the look of the light source being spread out. Seems like a more efficient use of the lens area.
EDIT: After looking at that site, I will definitely be using them in the future.Thanks.
Anyone ever convert their dome light and map lights to LEDs? DJboozeAlot S-Series General 18 02-16-2016 07:42 PM
Side Marker Lights kevdogg311 Aura General 2 10-01-2010 07:00 PM
Side marker lights star1701 Aura General 0 05-04-2008 09:01 PM
Ever tried to convert your lights? freakerz S-Series Mods 31 07-23-2004 10:15 AM
Side marker lights RojoVue Mods and Performance 7 09-17-2002 07:41 AM
