Old 12-12-2011, 03:11 AM   #1
emsvitil
emsvitil has a spectacular aura aboutemsvitil has a spectacular aura aboutemsvitil has a spectacular aura about
emsvitil's Avatar
Default DRL only work sometimes....
DRL (daytime running lights) only work some of the time.
Light switch is on auto.
Kinda random, I usually don't notice; but my sister was driving on a section of road that required lights on at all times and got pulled over for no lights.......
Don't have a clue where to start to debug problem.
Ed
Add to emsvitil's Reputation
Rate the quality of this post and help emsvitil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emsvitil is offline   Reply With Quote
Old 12-12-2011, 04:15 AM   #2
Default Re: DRL only work sometimes....
Being inattentive to driving lights is one thing when all it takes is simply pointing the front against the back of anything; another car, wall, fence, etc., to attempt seeing the reflection of one's headlights. A person can always step out of the car to check for headlights if in doubt..........and turn them on manually.
I wondered when people will become complacent with DRL's............
My nephew insists on carrying a huge sound system in the rear of his car so he removed his spare tire. Guess who he called to bring his spare when a flat happpened?
Daytime running lights depends on several circuits and one of them is the photocell covered with a round shaded lens on top of the dash. Is this covered or broken? Next is the DRL relay that can be swapped with another one nearby. The last would be the parking brake lever if left one detent before a full release - the p-brake switch is used as part of DRL controls. The only thing to disable DRL's completely and easily is for one headlight to burn out. If your DRL's use high beams during the day and one lamp burns out, the DRL circuit would blink the DRL indicator several times then stay off. At night, if one low beam lamp burned out the DRL circuit wouldn't work but should turn on the remaining lamp. If the light switch were turned to the first detent, side marker lights, then the DRL circuits are bypassed altogether and no low beams are turned on until the light switch is turned to the second detent to turn them on.
DRL's don't fail as they cannot control a burned out lamp. Depending on DRL's for everyday use is one thing but there will always be a manual mode to over ride automatic controls that some forget to use when needed.
Old 12-12-2011, 04:28 AM   #3
emsvitil
emsvitil's Avatar
Hmmmmmmm
Parking pass placards are sometimes randomly on top of the dash.....
Hope that's the simple solution.
Ed
Old 12-12-2011, 11:17 AM   #4
far2grumpy
far2grumpy's Avatar
Originally Posted by emsvitil View Post
Hmmmmmmm
I can't make a case for a covered auto light sensor. If covered - AHL will be ON when ignition is on ... assuming lighting switch is to AUTO.
A total absence of lights (when other conditions are met) indicates the AHL circuit is satisfied with lighting level and something is flaky with DRL circuit.
Fdryer mentions the usual suspects and you could advise sister to monitor the green DRL indicator. If its on - DRL should be on. If DRL indicator blinks, it could be an intermittent lamp, resistor or interconnecting wiring.
I don't spend much time on forum but answer private messages (PM email my phone). Include email address if you need pdf extracts. Don't use visitor message - I forget to check those.
will this work? nriebel Ion Tech 2 03-28-2011 10:45 PM
98 SL2 wont start, horn wont work and key fob wont work blade1981m S-Series Tech 4 08-29-2010 11:07 PM
To work...Or not to work...At a Saturn Dealership? koasterking General Saturn Discussion 11 08-09-2007 08:12 PM
Will It Work? w-in-ga S-Series Tech 7 04-13-2007 11:47 AM
will any of this work? SatAttack L-Series General 12 03-29-2007 08:59 PM
