Old 12-02-2011, 10:52 AM   #1
SaturnGirl03
SaturnGirl03 is on a distinguished road
Dizzy 03 Ion Engine light blinking/car shaking
Hi, my saturn ion's engine light started blinking and car was shaking and was loud with a gas smell coming off it. Mechanic replaced ICM and spark plugs and something about the exhaust? Got it back, was running fine even though engine light stayed lit. Now it's a week later and it's doing exact same thing! Not sure what this could be, I'm no good with cars at all but mechanic isnt really sure whats going on either. Any suggestions would be sooo appreciated. I should also mention sometimes it runs fine as if it fixed itself and other times it does it...
Add to SaturnGirl03's Reputation
Rate the quality of this post and help SaturnGirl03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnGirl03 is offline   Reply With Quote
Old 12-02-2011, 11:07 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 03 Ion Engine light blinking/car shaking
you need to get the codes read. your local parts store can do it for free, unless you live in california.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 12-02-2011, 11:20 AM   #3
SaturnGirl03
He did have the codes read which lead him to do the fixes he did..but I know nothing about these things..just was trying to see if anyone else ever had this problem.
Old 12-02-2011, 12:04 PM   #4
Tubagod767
Tubagod767 is on a distinguished road
2004 ION-2 Sedan
Without the specific codes any suggested repairs would just be speculation. I have my "guesses" based upon what your mechanic replaced/might not have replaced. I personally wouldn't go back to that mechanic, especially after having "fixed" the car...yet the MIL was still illuminated. Get the codes read at a local parts store such as Autozone, O'reilly's, advance autoparts, ect...It's free, easy, and takes no time at all. Come back and post the exact codes and you will get better feedback.
Add to Tubagod767's Reputation
Rate the quality of this post and help Tubagod767 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tubagod767 is offline   Reply With Quote
Old 12-02-2011, 12:17 PM   #5
SaturnGirl03
Ok thanks for responding. Mechanic has car right now so i wont be able to get the codes on here :/
Old 12-02-2011, 12:48 PM   #6
SaturnGirl03
ok just called and asked him he said the code was po300
Old 12-02-2011, 04:10 PM   #7
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
http://www.obd-codes.com/p0300
The site doesn't mention Fuel... but any chance "Bad Fuel" might be at least part of the problem? Have you addressed anything with the Fuel Injector(s)?
Personally a big fan of using "Top Tier Detergent Gasoline Standard" Fuels when possible... also while not a guarantee using some Fuel System Cleaner Additive on occasion might help unclog a dirty Injector.
If the Plugs were original did the Mechanic say what condition they were in? (How many miles? The original Platinum plugs would be due for change out before 100,000 miles. I changed mine out just recently and they looked due... Approx. 92,000. I've heard some suggest a earlier with the Platinums while Iridiums are Good for 100,000.)
Seems silly but did the Mechanic "reset" the light? Did you at least drive out of the shop with a "clear" Instrument Panel? Or was the Mechanic still concerned there might be addition concerns?
Add to lgodave's Reputation
Rate the quality of this post and help lgodave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lgodave is offline   Reply With Quote
Old 12-02-2011, 04:45 PM   #8
2006 ion2
2007 ION-2 Sedan
you might need new ignition coils, and make sure the plugs they put in are NOT bosch brand.
2007 Saturn Ion 2
Old 12-02-2011, 04:56 PM   #9
Tubagod767
2004 ION-2 Sedan
I have a feeling the mechanic didnít replace the ICM and Coil Pack as a pair (your original post did not indicate a coil pack replacement). If you do a search for P0300 on the forum, the typical problem is the coil pack or the icm fail. Personally, I would replace all three ignition components (spark plugs, coil pack, and ICM). One faulty component can damage the others. I had the same code on my wife's '02 L200 (still the same eco tec 2.2L) and found out the hard way as well. I thought i narrowed the problem down to the coils (switching components out with my known good Ion components). All was fine for about a week or two, but then the problem came back. I then proceeded to replace the Coils/ICM as a pair and the problem has been resolved.
Old 12-03-2011, 08:18 AM   #10
SaturnGirl03
Is the "fuel system cleaner additive" something I can get at Autozone? Mechanic didn't say what condition plugs were in..112,000 miles are on it. I didn't get the car back with a clear instrument panel. He said he wasnt sure if it had fixed it or not..just drive it and see how it goes.
Old 12-03-2011, 08:26 AM   #11
SaturnGirl03
You're correct, he first replaced coil pack then found that wasn't the problem so tried doing ICM...I'm not positive on this.. (I'm sorry I'm so bad with cars I have no idea..I make my husband deal with the Mechanic the most) but I think he took the new coil pack out after that wasnt the problem? I will call today and ask him to be sure and tell him your suggestion of replacing them as a pair. This does seem like it could be a solution if I'm right about him removing the new coil pack. Thanks
Old 12-03-2011, 09:35 PM   #12
lgodave
2003 ION-3 Sedan
At 112,000 miles... Original Plugs were due. Crossing my fingers Tubagod767's suggestion will resolve your issue.
Re: "Fuel System Cleaner"
You'll find a ton of different Fuel Additives at Autozone (or any other place that supplies Auto Parts/Fuel and services vehicles.).
As I mentioned (and GM recommends) using a "Top Tier Detergent Standard" Gasoline regularly as a good long term preventative option... Otherwise, you can buy a variety of Detergent Gas Additives (from $1 to $$$$) that might help your Fuel System stay cleaner.
Old 12-03-2011, 10:52 PM   #13
SaturnGirl03
Talked to mechanic and yes he had replaced coil pack but when that wasnt the problem, returned the part. He is going to get a new coil pack in it. He also wanted me to ask in here if this car is ever known for the fuel rail rusting for injectors?? He was looking at this being another option but guess he's not sure. I miss my car
Old 12-03-2011, 11:24 PM   #14
2006 ion2
2007 ION-2 Sedan
Not sure what you're actually asking, but the fuel rails are not a typical problem, the injectors have gone bad, especially when owners don't follow gm's advice to use top tier gas
2007 Saturn Ion 2
Old 12-05-2011, 10:20 AM   #15
SaturnGirl03
Ok, we are going to replace coil pack but does this mean ICM might be bad too since it wasnt replaced at same time???
Old 12-05-2011, 08:03 PM   #16
warrenc
warrenc is on a distinguished road
I for one am not sure what an ICM is. A PCM is a powertrain control module, but an ICM would be? Injection control?
Another easy and cheap thing to do is to clean the throttle body. It can cause some misfires and set some codes if dirty.
Add to warrenc's Reputation
Rate the quality of this post and help warrenc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
warrenc is offline   Reply With Quote
Old 12-05-2011, 10:11 PM   #17
2006 ion2
2007 ION-2 Sedan
Ignition control module. No, it should be fine having only been in there a short time. The throttle body wouldn't cause a misfire. it won't hurt to clean it, but it wouldn't cause this...
2007 Saturn Ion 2
Old 12-06-2011, 05:36 AM   #18
warrenc
I would normally agree, but I've seen it happen several times on a Hyundai Accent. Starts running rough, CEL light comes on for random misfires. Clean the throttle body and all is good again. It happened about every 4-5000 miles.
Just plain strange, I agree. It wouldn't even be that dirty in there.
Old 01-16-2015, 09:30 AM   #19
Brandenc
Brandenc is on a distinguished road
Mad Re: 03 Ion Engine light blinking/car shaking
I'm having the same problem with my ion as well. Started yesterday after work. Started the car, it started shaking and check engine light blinking. Thought maybe I had some water in the fuel lines, added a bottle of heet. Started vehicle this morning, same problem. At a stop the check engine light stays on solid, upon accelerating it blinks...any thoughts?
Add to Brandenc's Reputation
Rate the quality of this post and help Brandenc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brandenc is offline   Reply With Quote
Old 01-16-2015, 09:54 AM   #20
2006 ion2
2007 ION-2 Sedan
This guy has the right idea. Reading always helps.
2007 Saturn Ion 2
03Saturn engine light blinking car shaking SaturnGirl03 L-Series Tech 5 12-06-2011 03:15 PM
Blinking engine light while going up hill mjscfrn Ion General 6 06-18-2008 01:41 PM
Service Engine Soon Light Blinking - 97 SL2 winterbutterfly S-Series Tech 2 01-07-2008 11:09 PM
service engine soon light blinking winterbutterfly S-Series General 6 01-07-2008 09:23 PM
Blinking 'Service Engine Soon' light 98greenSC2 Miscellaneous Tech 1 08-19-2004 11:46 AM
