Old 11-22-2011, 10:30 AM   #1
infinitezero
infinitezero is on a distinguished road
Default Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission
I have a 2007 ION 2 (Manual) and just a few days ago I could not get the key to turn off and disengage. I am able to take the key out of the ignition lock cylinder and I can turn the car off, when I disconnect the cable to the ignition switch, I can also start the car.
My first question is, does this sound like a bad ignition lock cylinder or ignition switch? Secondly, does a manual transmission have a BTSI or not, if it does where is it located?
Thanks, iz
Add to infinitezero's Reputation
Rate the quality of this post and help infinitezero reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
infinitezero is offline   Reply With Quote
Old 11-22-2011, 06:37 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission
Manuals don't have/need btsi, they instead have a neutral safety switch, and I would normally say the lock cylinder, but there could be more going on than that...
Add to 2006 ion2's Reputation
Old 11-23-2011, 10:38 AM   #3
infinitezero
Could it be the "neutral safety switch"? Do you know where it is located?
Thanks,
iz
Old 11-23-2011, 12:45 PM   #4
2006 ion2
2007 ION-2 Sedan
No. if ours had one, it would be on the shifter or linkage, or transmission. Our cars have a clutch switch, which serves the same purpose in practice, but it also shouldn't cause this. Shifter sensors on manuals just keep you from starting it in gear.
Old 11-23-2011, 01:37 PM   #5
infinitezero
Got it.
I think I will take the approach of removing the ignition lock cylinder first and seeing if the tumbler plate is lose.
saturnfans.com/forums/showthread.php?t=152609
I will post my results in a few days
Thanks,
iz
Old 11-25-2011, 04:47 PM   #6
infinitezero
That did the trick!
It was the plate on the Ignition Lock Cylinder. I removed it per the direction in the link (previous post) and added a little Super Glue.
Thanks for the counsel, greatly appreciated.
iz
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 03:30 PM
2007 ION Ignition Lock Scott K Ion Tech 5 04-27-2014 06:23 PM
Ignition switch lock CFXXC S-Series General 4 05-13-2009 02:53 PM
Ignition Switch stuck in Lock position .... where have I seen this before? spriteman 2008 Vue 2 11-30-2007 04:29 PM
ignition switch or lock cylinder? kaseyskar S-Series Tech 11 09-26-2006 08:30 PM
