#1 | ||||
![]() Join Date: Aug 2011
Does anyone know where i can find/buy an ECTS connector? I haven't had any trouble finding the sensor but I can not find the connector anywhere, mine is corroded and cracked.
Thanks
#2 | ||||
![]() Join Date: Nov 2010
Location: Pacifica by San Francisco – 5sp – Engine rebuilt with the help of people here at 177K to deal with 300mi/qt oil consumption. Engine runs beautifully. Now at 192K with syn oil.
Send a private mail to LowSaturn and ask if he has any to spare. I understand he had a whole coffee can full of them.
Or you can go to the junk yard yourself and get one for a buck. Else, see this link as Rock auto sells them : http://www.saturnfans.com/forums/sho...52&postcount=6
#3 | ||||
![]() ![]() ![]() Join Date: Mar 2007
I bought one from the dealer a few years back and it was $35 from them. Then I saw a posting on the forum talking about the computer connectors.
A two pin rectangular 0.1" spacing connector such as found on an old computer case for the front panel LEDs works well and it is really no more trouble than splicing in a new one such as from RockAuto. They work just fine as long as you put something on them to repel water. Spark plug boot or "light bulb socket" dielectric grease works perfectly. Fill the connector pocket of the sensor with it and push in the connector. Then put a fillet of grease around the connector where it meets the sensor and also where the wires go into it and you're good to go. You should put some dielectric grease on a "factory" one too (even though they are sealed), for the very same reason. Lots of people on the forum have done that. ... DIYguy Condemnant quod non intellegunt..... 97SC2 Saturn, Cruze Eco, Chevy SS P/U, Honda CT200, Honda VT1100C Last edited by DIYguy; 11-14-2011 at 12:00 AM..
#4 | ||||
I understand that some folks have used the conenctor from their inlet air temp sensor, then they improvise with the PC conenctor at that, easier to reach, loction.
#5 | ||||
![]() ![]() ![]() Join Date: Feb 2005
1999 SC1
Junkyard IAT sensor connector FTW.
... SaturnSeries.net owner
#6 | ||||
Thank you all for the suggestions, i think i'm going to stop by the junkyard tomorrow and see what they have.
#7 | ||||
![]() Join Date: Jun 2004
I purchased one from low saturn for $8 shipped and it arrived at my house 3 days later and worked perfect.
#8 | |||||
... 98 SL2 187065 miles 45.09 MP2 Swap, Gen 1 valve cover, AEM SRI If it ain't broke, fix it some more.
#9 | ||||
The TTS in autotragics is the same part as the IATS and ECTS, so if you find an autotragic in the junkyard you can get 2 connectors from one car
| Thread Tools | |
| Display Modes | |
| Part number connector for coolant temperature sensor | smp7015 | S-Series Tech | 8 | 03-07-2009 10:41 PM |
| Temp Sensor Connector Part # | Dsell | S-Series Tech | 9 | 09-05-2008 06:44 PM |
| Help: coolant temp sensor connector | tataat | S-Series General | 2 | 07-21-2005 06:00 AM |
| Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor | BigDaddyDrex1 | S-Series General | 4 | 05-27-2005 02:29 PM |
| where is the coolant temp sensor | buddyc | S-Series Tech | 2 | 08-06-2003 05:18 PM |
