Old 11-10-2011, 08:10 PM   #1
99GreenySC2
99GreenySC2 is on a distinguished road
99GreenySC2's Avatar
Default Trans Swap Concerns
So i am planning an auto to manual swap soon, but i have come across a concern.. i have a 99 SC2, and i am swapping the trans from a 97 SC2, i know already the PCM wont work from the 97 so i am most likely going to flash mine or buy the proper year manual one..
My main issues come as the Neutral Safety Switch, Reverse Switch, and Wiring Harness difference between the auto and manual?
Can anyone shed some light on this?
99 SC2 164k
Its got issues -_-
Add to 99GreenySC2's Reputation
Rate the quality of this post and help 99GreenySC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99GreenySC2 is offline   Reply With Quote
Old 11-11-2011, 08:43 AM   #2
Default Re: Trans Swap Concerns
Just about everyone that's done the swap could. 1000's of us, lol
Shove a 30a fuse in the NSS plug, splice the reverse light sensor into the square plug (wire colors depend on year). PCM's are plug & play so it'd probably be cheaper to find a '99 5spd in a junkyard then having a dealer reflash yours for $100+.
If you want a proper clutch safety switch like most other 5spds then you'll need it & the wiring from a 5spd, though a brake light switch would probably work just as well. You'd wire it to the NSS plug instead of shoving a fuse in it.
Old 11-11-2011, 09:27 AM   #3
Brake light switch would NOT work. It's at the TOP of the travel, and closes when it's NOT pressed (when the pedal arm moves away from it). Clutch start switch is at the BOTTOM of the travel, and closes when it IS pressed (when the pedal arm pushes it).
The world got along without clutch start interlocks for decades. I keep them connected on my wife's 3/4-ton trucks, because they're three tons each, but I've jumpered mine on my SW2. If you're willing to be conscientious and you know anyone else driving it will be, just skip it.
Add to madpogue's Reputation
Old 11-11-2011, 07:55 PM   #4
99GreenySC2
I'm going off the how to from different racing, and maybe i missed it... but i am going to put the 97 trans into a 99, the reason i am opting for flashing the PCM is because my dad works at a Cadillac dealership so i wouldnt get charged most likely...
As far as the wiring goes, can either of you put up pictures to show me what you mean?
99 SC2 164k
Its got issues -_-
Old 11-11-2011, 07:59 PM   #5
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
HA. I forgot you dad would have a TechII at his disposal. Yeah, +1 for reflash, haha
'02 SL1.414213562^2, Deebs ftw
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 11-11-2011, 08:20 PM   #6
99GreenySC2
yes yes hah
99 SC2 164k
Its got issues -_-
Old 11-12-2011, 06:03 AM   #7
Best pic you'll ever get (from hein on 6s)
Even if the colors don't match up perfectly, their position on the connector is more important.
Old 11-12-2011, 08:46 AM   #8
99GreenySC2
i see the fuse, and i see the green and pink wires cut and wired up to something else, but i am not sure where all that comes from? is it already in my car or do i need it from a different one?
99 SC2 164k
Its got issues -_-
Old 11-12-2011, 12:09 PM   #9
The reverse light switch should be on the transmission already ($20ish part if it isn't or is broke) and the connector needs to be cut out of a 5spd's harness. The rest you already have.
Old 11-12-2011, 12:27 PM   #10
AlexofNazareth
2002 SL1
i see how it goes. Nick, IM me if you still dont get it
Old 11-13-2011, 10:42 PM   #11
99GreenySC2
i am still confused a little bit... okay the hex sensor i cut off the 97's wiring harness since it goes into tranny, gotcha... but where would the plug for the 30 fuse be on my harness? so i can check and see if its there or not...
99 SC2 164k
Its got issues -_-
Old 11-14-2011, 05:37 AM   #12
Plugged into the autotragic, on the back side. I believe it plugs into whatever the AT uses as a gear selector which you can see by the 1 sliding cable connected to the transmission, still on the back side.
The ONLY thing you don't already have is the reverse light switch and the pigtail that goes to it, which you have to cut off a 5spd and splice into your harness.
Old 11-14-2011, 01:41 PM   #13
99GreenySC2
so i would need to get under the car to find what i'm looking for..
the NSS and pigtail, is that the sensor? my brain is just taking its sweet time to grasp this crap hah
99 SC2 164k
Its got issues -_-
Old 11-14-2011, 02:00 PM   #14
AlexofNazareth
2002 SL1
No nick. You remove the intake tubing, and the reverse light switch(the hex sensor) can be seen on the top of the trans. The NSS is the neural safety switch that you're not going to put inyour car.
Old 11-14-2011, 02:41 PM   #15
Originally Posted by AlexofNazareth View Post
The NSS is the neural safety switch...
Wow, talk about advanced.....
Old 11-14-2011, 05:22 PM   #16
99GreenySC2
alex your missing my question -_- hah
the hex yeah its on the 5sp right now, not on mine at all blah blah blah i am talking about the one with the fuse in it... where the frick is that at
99 SC2 164k
Its got issues -_-
Old 11-14-2011, 05:57 PM   #17
Range selector, that's what the silly thing's called. the black single wire plug, the long rectangular black plug you splice the reverse lights into and the neutral safety switch you put a fuse into are all plugged into it.
http://www.saturnfans.com/forums/showthread.php?t=92372 should help, I can't find pictures of it though.
Old 11-14-2011, 05:58 PM   #18
99GreenySC2
also, would it be easier on me to remove 5sp and all needed parts in and just put them in my trunk when i go to do this?? cause chances are it'll take place at a shop(of sorts), and i cannot drive the 5sp there cause its not "legally allowed on roads" at the current time, hence why i am using it for this..
99 SC2 164k
Its got issues -_-
Old 11-14-2011, 09:19 PM   #19
AlexofNazareth
2002 SL1
yeah, just drop the trans out the bottom.
trans swap 10Miler S-Series General 15 10-13-2011 09:38 AM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 04:58 PM
trans swap tech kjr S-Series Tech 3 12-19-2005 11:56 PM
Trans Swap on SC2 Rhleonard S-Series General 9 02-11-2005 06:32 PM
Trans. Swap rrharmon S-Series Tech 2 03-01-2004 08:27 PM
