Old 11-06-2011, 05:06 PM   #1
mesns
mesns is on a distinguished road
Default High Beams
I just noticed that the right side high beam does not work. The mechanic says that there is a flap which has to move out of the way but it is stuck in place. The whole assembly has to be replaced at a cost of more than $300. Apparently that action would be needed if a low beam simply failed... Any suggested way to fix a low beam? I ain't about to fix a high beam.
Add to mesns's Reputation
Rate the quality of this post and help mesns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mesns is offline   Reply With Quote
Old 11-06-2011, 05:23 PM   #2
Haps
Haps is on a distinguished road
Haps's Avatar
2008 Astra XR
Default Re: High Beams
The high beam and the low beam use the same bulb, like your mechanic said, using a shutter, to shut off the top half of the beam in order to turn it into a low beam.
If the low beam were to fail, it would be caused by a bulb failure (in turn causing your high beam to fail too, since it's all through a single bulb) and is easily remedied by changing the headlight bulb just the same as any other car.
Add to Haps's Reputation
Rate the quality of this post and help Haps reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Haps is offline   Reply With Quote
Old 11-07-2011, 03:10 AM   #3
furious_cruzer
furious_cruzer is on a distinguished road
furious_cruzer's Avatar
1999 SC1
go to the junkers and replace it, dont try and repair it
1999 Saturn SC1 5-Speed on 17's with 2x12's and DDIN dvd with 2x Headrest LCD
Add to furious_cruzer's Reputation
Rate the quality of this post and help furious_cruzer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
furious_cruzer is offline   Reply With Quote
High Beams go out rlstutzman Ion Tech 2 11-24-2009 11:14 AM
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 11:06 AM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 04:10 PM
high-beams MaliceRacing Mods and Performance 6 11-23-2001 11:15 AM
HIGH/LOW BEAMS GOTTAGO S-Series Tech 17 01-02-2001 10:03 AM
