Old 11-03-2011, 07:19 PM   #1
jim7489
jim7489 is on a distinguished road
Default Tach going up and down
My 07 vue V6 just started sounding like I have an exhaust leak. At the same time at low speeds the tach goes up and down and it seems to shift funny. at high speeds it runs fine except for the exhaust noise.
Add to jim7489's Reputation
Rate the quality of this post and help jim7489 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jim7489 is offline   Reply With Quote
Old 11-03-2011, 09:21 PM   #2
Bismarck318
Location: Heart of the Rustbelt, AKA The Angry White Planet Ohth
Default Re: Tach going up and down
How many miles?
I had oscillations of around 50-100rpm (a blip about once every 3-4 seconds) when holding the accelerator steady in the 20-40 range... a transmission fluid change (or 4.5 qt displacement) cured this. (be sure to use a Honda Z1 approved fluid) Dealer could not find this problem & denied it existed.
You may be developing Torque Converter issues or the PCM may need a reprogram under the recall.
I recently had my exhaust fixed, was a gasket (possibly manifold) & not a pipe, but became very loud.
Add to Bismarck318's Reputation
Rate the quality of this post and help Bismarck318 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-06-2011, 09:21 AM   #3
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Originally Posted by Bismarck318 View Post
How many miles?
My '04 3.5L that I just purchased with 179k on it has/had this problem. I read several threads over the net about the torque converter issues. I found out about a little bottle of "magic" that seems to have solved the problem. I'm going to have to find out exactly what that stuff is. I had a garage suck out some fluid and put this stuff in. It seems to be about 99% better.
I was planning to have it flushed and add a bottle of Lucas, but the transmission shop I talked to wasn't sure if it has a serviceable filter, and advised against it if that's the case. So, until I find out about the trans filter, I'm not going the flush route.
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 11-06-2011, 05:14 PM   #4
Bismarck318
No serviceable filter in the 3.5. Lucas should not void out any warranty or create issues if you should decide to use it.
A change of fluid stopped my oscillation issues, but did not stop the low end rough shifts.
Old 11-08-2011, 09:07 AM   #5
RedGeminiPA
2004 VUE 3.5L
Thanks for the info. The fluid is still fairly pinkish, and I know the dealer I bought it from didn't change it. They don't even change oil, lol. Would you advise against the flush with such high miles? I've had a few vehicles flushed before, but never with such high miles. Would it be better to just do the drain and fill a few times as mentioned in a couple of threads?
Old 11-09-2011, 09:39 AM   #6
XRL
XRL's Avatar
2004 VUE Red Line
Definitely drain and fill on the Honda transmission.
When I did my drain & fill on my Vue, it made the 1-2 shift much smoother. If you're getting tach oscillations, that's a sign your fluid has been bad for a while, and you're damaging your TC.
Add to XRL's Reputation
Old 12-15-2011, 04:11 PM   #7
jfisher99
jfisher99 is on a distinguished road
2004 VUE 3.5L
I bought an 04 Vue a few weeks ago and had this exact same problem. At low speeds and in a numerically high gear, it was like the trans could not find the proper gear to be in. It would go in and out of two different gears constantly. Luckily I was able to get an extended warranty thrown in and it's currently at the Chevy dealership I bought it from getting the torque converter replaced.
The dealership also tried denying any issue at first, but once I told them it only happened once the car was fully warmed up, they quickly were able to duplicate the problem.
Add to jfisher99's Reputation
Rate the quality of this post and help jfisher99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jfisher99 is offline   Reply With Quote
@#($!%&@)#(&$% tach wtf1995 S-Series Tech 3 12-15-2010 07:48 PM
need help with my tach col3man S-Series Tech 4 07-31-2009 06:52 PM
Tach Orthus S-Series General 4 03-23-2006 07:38 AM
tach rpm at 75 mph saturnPr!de General Saturn Discussion 17 12-04-2002 07:19 PM
tach anti honda Miscellaneous Tech 2 11-30-2002 02:02 AM
