Old 11-03-2011, 04:26 PM   #1
RougeRed
RougeRed is on a distinguished road
Default 2001 SL2 No spark from the coil
Not getting any spark from the coil, replaced the coils and ignition module and still nothing. Replaced the CPS and still no fire. Checked all the fuses, and still nothing.
Any ideas why i'm not getting fire? Could it be the PCM?
Add to RougeRed's Reputation
Rate the quality of this post and help RougeRed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RougeRed is offline   Reply With Quote
Old 11-03-2011, 04:28 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: 2001 SL2 No spark from the coil
Can you give any other recent maintenance/history done?
New owner As of 01/01/18: 225,000 Miles
As of 01/23/18: 43,635 Miles
Old 11-03-2011, 04:33 PM   #3
PlasticCarsRock
PlasticCarsRock's Avatar
Are you getting fuel? If it's the PCM (most likely a wiring problem of blown fuse--PCMs rarely fail) it will often cut off the fuel as well.
As I'm guessing you already know, the CPS/CKP is the most common cause of this type of issue. While unlikely, it is possible that the replacement was already defective (particularly if you got it new, from a parts store, instead of an OE quality one from a junkyard). Where are you checking for spark? The "correct" place to check is between the coil towers, with the plug wires removed (checking at the other end of the wires is less reliable, particularly with a waste spark system--the spark must return to the coil, not to ground).
Double check the PCM fuses (there are two). Don't just look at them, check them for continuity with a multimeter or test light. If it's a PCM fuse, there will be no fuel, in addition to no spark.
Old 11-03-2011, 06:17 PM   #4
RougeRed
I am getting fuel, and I recently (2mos) replaced the starter and battery. I'm checking for spark between the coil towers. The CPS I purchased is new and to the best of knowledge is a functional part.
Any other ideas?
Old 11-03-2011, 06:33 PM   #5
RougeRed
Also, I replaced all relevant fuses just to be sure.
Old 11-04-2011, 04:56 AM   #6
Its not likely to be both fuel and ignition issues at the same time unless the pcm fuse is blown. There are less than a handful of members replacing a failed pcm and most do so out of desperation when it was mostly due to everything related to the pcm.
1-Are you sure the cps is fully seated and not leaving a gap that creates a new dead engine condition?
2-Check for spark again at the coils by leaving the plug wires off while someone cranks the engine while you observe for spark. Most loss of spark issues are cps faults while the rest are ignition control module failures. No one has posted about two coil failures but its always possible.
3-Fuel and pressure checked at the fuel test valve by seeing fuel spray when the valve stem is depressed?
Old 11-04-2011, 09:48 PM   #7
td1238
Also check for voltage at the ICM.
Add to td1238's Reputation
Old 01-30-2012, 04:28 PM   #8
Mary's Vue
Mary's Vue is on a distinguished road
Mary's Vue's Avatar
What was the fix??
Add to Mary's Vue's Reputation
Rate the quality of this post and help Mary's Vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mary's Vue is offline   Reply With Quote
Old 04-19-2014, 07:12 PM   #9
tbbusiness
tbbusiness is on a distinguished road
I have the same problem on a 1995 SL2 and need suggestions. My 1995 Saturn sl2 DOHC died when I was pulling up to a stop sign. It is getting fuel but no spark. Battery is new and cables are clean. No fire at the computer. Everything else works. Fuses and relays good. Replaced CPS, computer, coil packs, spark plugs and wires. Compression 150,120,150,150 so I know it is not a timing belt. What else can I do?
Add to tbbusiness's Reputation
Rate the quality of this post and help tbbusiness reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tbbusiness is offline   Reply With Quote
Old 04-19-2014, 07:21 PM   #10
"Getting fuel" as in wet spark plugs or just fuel spraying out the fuel test valve? With a new crank sensor and still no spark, did you replace the ignition control module? The icm is the part the two ignition coils plug in to.
Old 06-25-2015, 09:28 PM   #11
adstatus
adstatus is on a distinguished road
Did this problem ever get resolved? I have the same issue with my 2002 SOHC SL1. New coils, new plugs and wires, new (junkyard) icm, new CKP. Voltage test at the ICM is 11.87 V and there is continuity to ground. Using a noid light I have verified that I am getting injector pulses at the fuel injector, thus suggesting the new CKP is working.
Would love to know if anyone solved this and what the solution was.
Add to adstatus's Reputation
Rate the quality of this post and help adstatus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adstatus is offline   Reply With Quote
LW300 spark plug and coil pack replacement Zummo L-Series Tech 0 02-13-2011 02:21 PM
No spark at the coil Procraftmike S-Series Tech 5 08-06-2009 09:41 PM
No Spark at Wires? Changed 1 Coil Same Problem Gumart1 S-Series Tech 35 01-01-2009 01:36 PM
Visible Spark from Ignition Coil gcurtis358 S-Series Tech 9 07-15-2005 11:59 AM
coil pack1/4 no spark trav89 S-Series General 5 04-22-2005 07:09 PM
