Old 10-31-2011, 02:13 AM   #1
pdagsm77
pdagsm77 is on a distinguished road
1992 SL1
Dizzy Need HELP how to remove this EGR
Like the picture
I try to remove this EGR and clean it,
but I got a problem on it.
There is a frame blocked, and I cannot take the frame off.
My vehicle is 1992 SL1
Help me please, with picture is better.
Thanks
Add to pdagsm77's Reputation
Rate the quality of this post and help pdagsm77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pdagsm77 is offline   Reply With Quote
Old 10-31-2011, 02:19 AM   #2
holydiver
holydiver is on a distinguished road
holydiver's Avatar
2002 L-Series 2.2L Sedan
Default Re: Need HELP how to remove this EGR
That frame needs to come off. The EGR won't come off with the frame on. Why can't you take the frame off? It's probably held on somewhere. Take a flashlight and look in the dark areas and follow the frame down. Once you get that frame off and all the nuts/bolts are off it, you may have to tap the EGR out with a small mallet.
BTW, welcome to the forums.
-Robert
'96 Saturn SL2 5-Speed, 141k, Rebuilt Engine (My Toy)
'96 Saturn SL2 Automatic, 187k (The Project)
'02 Saturn L200 2.2L Auto, 119k (Dad's Car)
Add to holydiver's Reputation
Rate the quality of this post and help holydiver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
holydiver is offline   Reply With Quote
Old 10-31-2011, 02:33 AM   #3
pdagsm77
1992 SL1
I search around there for a long long time,
but I still cannot remove the frame.
I had touched something like a nut,
but it covered with that frame from three ways.
I have no idea to find a tool to remove it,
because that is in very narrow place.
Old 10-31-2011, 11:57 AM   #4
1sksc2
1sksc2 has a spectacular aura about1sksc2 has a spectacular aura about
in that case, i would just cut it off. and go find another one at a junk yard to replace it. if it really needs it
Add to 1sksc2's Reputation
Rate the quality of this post and help 1sksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1sksc2 is offline   Reply With Quote
Old 10-31-2011, 12:19 PM   #5
^ ^ ^ take a look at the OP's location - Taiwan. Guessing there aren't a lot of junkyards with 92 SL1s there
Old 10-31-2011, 02:27 PM   #6
spacemanspif
spacemanspif will become famous soon enough
spacemanspif's Avatar
Are those studs removable? They have the male torx at the tip like the motor mount studs. If you don't have the tool, put a narrow set of vice grips on the torx spot and see if you can pull the studs out and slide out the ERG. If it were my car, i'd get rid of the ERG. I can't imagine that the smog laws in Taiwan are very strict...
-Mike
1995 SL2 5spd - Stock/MP2 trans swap - 258,XXX miles - 38mpg @ 65mph
1987 Monte Carlo SS - 5.3/4L80E swap - 13.92@103mph - 19mpg @65mph - needs POSI
Add to spacemanspif's Reputation
Rate the quality of this post and help spacemanspif reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spacemanspif is offline   Reply With Quote
Old 10-31-2011, 05:12 PM   #7
spacemanspif
Looking at this again...can those EGRs even be cleaned?? Looks like a the diaphragm type that my V8 Chevy used to have. Nothing to clean, diaphragm either held vacuum or didn't. When it stopped working you plug the vacuum supply and bolt on a block off plate.
-Mike
Old 11-01-2011, 03:32 PM   #8
1sksc2
my bad. didnt notice where he lived.
best way to remove gas? megaman8x S-Series Tech 3 07-19-2010 11:05 PM
can you remove BLAZEBOI S-Series Mods 10 05-26-2009 03:18 PM
how to remove... ycpguy89 Ion Mods 1 10-08-2008 12:39 PM
Remove DRL from 98 SL1 TCPMeta S-Series Mods 15 09-11-2008 12:36 PM
remove pre-cat? '97 SC2 fetchitfido S-Series Tech 0 09-03-2008 10:51 AM
