Old 10-29-2011, 10:36 PM   #1
pyroom
pyroom is on a distinguished road
pyroom's Avatar
2004 VUE 3.5L
Default Transmission Cooler
I'm looking at installing a transmission cooler on my 3.5L Vue, would something like this be overkill?
http://www.amazon.com/Flex-lite-4120.../dp/B00029J3WK
Does our transmission have a thermostat?
2004 Vue 3.5L AWD
Add to pyroom's Reputation
Rate the quality of this post and help pyroom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pyroom is offline   Reply With Quote
Old 10-30-2011, 07:41 PM   #2
djb383
djb383 is on a distinguished road
djb383's Avatar
Default Re: Transmission Cooler
Looks very similar to the Perma-Cool I instaltled 5 years ago.
Add to djb383's Reputation
Rate the quality of this post and help djb383 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djb383 is offline   Reply With Quote
Old 11-01-2011, 06:07 PM   #3
far2grumpy
far2grumpy's Avatar
IMO - following thread is one of better ATF cooler discussions - the cooler appears to be a perfect fit and I've always thought the external filter information is most informative:
http://www.saturnfans.com/forums/sho...d.php?t=150013
I've searched the 5AT diagrams for a thermostat (oil cooler bypass) - without finding evidence of one. I monitor ATF temp with ScanGaugeII and notice ATF generally warms along with engine coolant ... almost like it was designed to do so.
Old 11-01-2011, 08:42 PM   #4
djb383
djb383's Avatar
Default
Originally Posted by far2grumpy View Post
...........I monitor ATF temp with ScanGaugeII and notice ATF generally warms along with engine coolant ... almost like it was designed to do so.
Are u running an auxiliary cooler in addition too and after the factory cooler?
Old 11-02-2011, 09:26 AM   #5
far2grumpy
far2grumpy's Avatar
No, I don't have an aux cooler. I depend on the SCII to keep track of ATF temp when towing either a small boat or utility trailer (<1500 lbs).
Old 11-15-2011, 05:40 PM   #6
pyroom
pyroom's Avatar
2004 VUE 3.5L
So I did the Scangauge thing, and I have not seen the temperature go past 120. I think I'll wait until summer to install a tranny cooler, since the heat is not nearly as bad as I thought. I was hoping this might help to prolong the torque converter issue.
How to do it in case anyone is interested: http://www.saturnfans.com/forums/sho...d.php?t=156068
2004 Vue 3.5L AWD
Old 11-15-2011, 09:36 PM   #7
far2grumpy
far2grumpy's Avatar
I expected some really big ATF temps but they just don't happen. I seem to recall reaching 205 F once while stuck in stop-and-go at Omaha. Outside air temp was near 100 and coolant temp was up to 210.
Once I had some speed - ATF dropped back to coolant thermostat country (180 F) and actually dropped to 160ish for rest of trip.
Old 11-15-2011, 10:24 PM   #8
pyroom
pyroom's Avatar
2004 VUE 3.5L
just came across this:
http://www.youtube.com/watch?v=gS-Qh...layer_embedded
7 years later, they still haven't fixed it?
2004 Vue 3.5L AWD
Old 11-15-2011, 11:21 PM   #9
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Any idea where that temp sendor for the ATF is that the ScanGauge is picking up? If it's on the inlet- 205 probably isn't good. If it's in the sump- 205 isn't that great. If it's at the outlet- it's probably still a little high.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 11-16-2011, 11:47 AM   #10
pyroom
pyroom's Avatar
2004 VUE 3.5L
It's in the sump
2004 Vue 3.5L AWD
Old 11-17-2011, 09:41 AM   #11
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Well, if you guys have ever been curious as to why the Honda ATX fluid only lasts 25,000 miles, here's a chart that seems to jive with what F2G posted above:
After loosing an ATX transmission due to overheating and spending way more money than I should have to "fix" it, I've installed aux coolers on every ATX equipped car since then- my Explorer has 2.
Not a Saturn.
Transmission cooler: before or after stock cooler? PlasticCarsRock S-Series Tech 15 08-27-2011 05:01 PM
Transmission cooler/radiator replacement when transmission is bad? infinitewisdumb S-Series Tech 2 04-16-2010 08:59 AM
Transmission cooler? Allwhitevue Vue General 9 08-09-2007 11:32 PM
3.5L Transmission Cooler GearGuy Vue Tech 14 02-10-2006 01:33 PM
transmission cooler shaner123 S-Series General 13 01-17-2006 10:04 AM
