Old 10-26-2011, 02:38 PM   #1
LIGuy
LIGuy is on a distinguished road
Default Replaced O2 sensor.....code reset?
Have an '06 Ion-3 with Check Engine lit and a P0135 code (pre-cat O2 sensor heater). After getting a $244 estimate from Mr. Mechanic, I bought an OEM replacement online for $29 and put it in. Fingers are crossed. Question: is a hard code reset needed (scan tool or battery disconnect maybe) to extinguish the light, or will sufficient drive cycles do the trick? If so, what's the drive cycle regimen needed to please the computer?
Thanks in advance. :-)
Add to LIGuy's Reputation
Rate the quality of this post and help LIGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LIGuy is offline   Reply With Quote
Old 10-26-2011, 03:16 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Replaced O2 sensor.....code reset?
A code scanner or the right number of cycles are needed. The number of cycles depends on the specific code, as does the definition of a cycle.
Add to 2006 ion2's Reputation
security code reset Rhoads62 S-Series Tech 16 06-02-2016 04:56 AM
P0141 Code, Replaced the O2 Sensor and still throws it? saborstorm S-Series Tech 1 09-06-2009 04:39 PM
Vehicle Speed sensor replaced and still throwing code. Triggamane S-Series Tech 11 05-17-2009 03:06 PM
Saturn SL1 Code Reset Javert1997 S-Series General 7 12-28-2005 05:21 PM
PCM reset after EGR valve replaced? Doug_E_95_SL2 S-Series Tech 1 01-11-2001 08:09 PM
