Old 10-23-2011, 02:54 PM   #1
Joey c
Joey c is on a distinguished road
Default Drivers side water leak
The drivers side floor is soaked on my 2007 ion, so much that it corruded the wiring to the throttle positioning sensor, anybody got any suggestions where the water is coming from
Add to Joey c's Reputation
Rate the quality of this post and help Joey c reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Joey c is offline   Reply With Quote
Old 10-23-2011, 04:14 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Drivers side water leak
Sunroof?
Add to 2006 ion2's Reputation
Old 11-10-2011, 01:01 PM   #3
jess1979
jess1979 is on a distinguished road
I also had this problem on my 04 Ion QC. Turned out that the drain for my sunroof was plugged with gunk. I ended up pulling off the plastic fender well thing and snipping the end off the rubber grommet that holds the end of the drain hose. The drain hole is tiny originally. I snaked some weed eater line through the drain hose from the sunroof through the end where the grommet is. No more water coming in the car. It took about 1/2 hour total to do the driver's and passenger's side of my car. Hope this helps!
Add to jess1979's Reputation
Rate the quality of this post and help jess1979 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jess1979 is offline   Reply With Quote
Old 11-10-2011, 01:39 PM   #4
2006 ion2
2007 ION-2 Sedan
do the back, too. they come out through the trunk sides.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 11-10-2011, 01:46 PM   #5
jess1979
thanks. I will have to get to that yet. Right now the check engine light is on and the tech that flushed the radiator for me ran the code and found the pigtail on the evaporator valve canister is broken. Blah! The neighbor owns a junkyard. I'm hoping I can sweet talk him into getting the part out for me. The light has been on forever though. It seems like something is breaking or needs to be done every month on this car. It's an 04 Ion 2 QC 5 speed with 74K. I bought it brand new. I just keep reminding myself the repairs and maintenance are better than a car payment, at least I know this vehicles history, except the first 12 miles.
Old 11-10-2011, 02:16 PM   #6
2006 ion2
2007 ION-2 Sedan
evaporator valve canister? never heard of that one
2007 Saturn Ion 2
Old 11-10-2011, 03:15 PM   #7
jess1979
oh I meant canister vent solenoid. Duh! Sorry. Try to figure out issues with the husband's jeep and my car. My brain is getting fried.
Old 04-26-2012, 10:15 AM   #8
yomama604
yomama604 is on a distinguished road
2004 ION-2 Quad Coupe
I have the same problem. Anybody have a picture or instructions for removing the " plastic fender well thing". I tried cleaning the drain hose with string triimer line but I think I made it worse. Should I be able to see the string come out the end?
Thanks
Add to yomama604's Reputation
Rate the quality of this post and help yomama604 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yomama604 is offline   Reply With Quote
Old 04-27-2012, 09:36 AM   #9
yomama604
I answered my own question.. poured some water in the drain that was working and noted where it was coming out of. Now I need to figure out how to remove the fender liner without breaking the plastic clips. Any suggestions?
Thanks
Old 04-27-2012, 03:35 PM   #10
yomama604
I need to try before I ask. Took a closer look and noticed the clips are slotted. They came out pretty easily by inserting a screwdriver in the lost and pushing up.
I was able to move part of the fender liner out of the way. half way up the fender closest to the door is a 'nipple', I reached in and squeezed it a bit and a ton of liquid poured out. Please no comments :-)
I could not actually see it but I felt around and I think I got what ever was blocking it taken care of. Tested it a few times after putting everythign back and water flowed beautifully.
Hope it lasts
Old 01-20-2015, 10:20 AM   #11
dffr1
dffr1 is on a distinguished road
On my '04 Ion3 with sunroof - found one tube clogged and the other very slow.
Tried to take a pic but they did not come out very well.
There is a hole on both front corners ( could not see the back - they may have a hole also ), first tried bike brake cable but it was not flexible enough, then someone mentioned weed whacker line and that worked great. Poured some water in and the drivers side did not drain at all -- the pass side a little. Ran the line down forcefully, then used canned air. I taped the straw end of the straw to create a seal and force the air down.
After that both sides drained great - put quite a bit down to clean any loose debris.
Moving forward I will do this every other year or so. Plan on keeping the car a while - the only problem we have had is the lock cylinder, that was finally replaced on a recall.
Add to dffr1's Reputation
Rate the quality of this post and help dffr1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dffr1 is offline   Reply With Quote
Drivers side coolant leak saabed S-Series Tech 8 11-18-2012 10:22 PM
Water Leak on Drivers Side Floor SilentJ20 2008 Vue 2 11-12-2010 12:23 PM
'95 Saturn SL2, radiator leak on drivers side DWVANDY S-Series Tech 11 01-28-2009 11:04 PM
Coolant leak on drivers side of 2000 SL2 sdgengineer S-Series Tech 10 12-16-2008 11:41 AM
drivers side door leak on '94 SC1 SLM crew chief S-Series Tech 2 02-18-2003 02:07 AM
