#1 | ||||
![]() Since I installed some new wheels recently, I decided to take a video of how to complete the matching procedure.
TPMS Sensor Matching Process Video: http://youtu.be/XQ9FSQUdnHQ Each TPMS sensor has a unique identification code. Any time you replace one or more of the TPMS sensors or rotate the vehicle’s tires, the identification codes need to be matched to the new tire/wheel location. The sensors are matched, to the tire/wheel locations, in the following order: driver side front tire, passenger side front tire, passenger side rear tire, and driver side rear tire using a TPMS diagnostic tool. See your dealer/retailer for service. The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire’s air pressure. When increasing the tire’s pressure, do not exceed the maximum inflation pressure indicated on the tire’s sidewall. To decrease the tire’s air-pressure use the pointed end of the valve cap, a pencil-style air pressure gage, or a key. You have two minutes to match each tire and wheel position. If it takes longer than two minutes to match any tire and wheel position, the matching process stops and you need to start over. The TPMS matching process is outlined below: 1. Set the parking brake. 2. Turn the ignition switch to ON/RUN with the engine off. 3. Press and hold the Remote Keyless Entry (RKE) transmitter’s LOCK and UNLOCK buttons, at the same time, for about five seconds to start the TPMS learn mode. The horn sounds twice indicating the TPMS receiver is ready and in learn mode. 4. Start with the driver side front tire. The driver side front turn signal also comes on to indicate that corner’s sensor is ready to be learned. 5. Remove the valve cap from the tire’s valvestem. Activate the TPMS sensor by increasing or decreasing the tire’s air pressure for about eight seconds. The horn chirp, can take up to 30 seconds to sound. It chirps one time and then all the turn signals flash one time to confirm the sensor identification code has been matched to the tire/wheel position. 6. The passenger side front turn signal comes on to indicate that corner sensor is ready to be learned. Proceed to the passenger side front tire and repeat the procedure in Step 5. 7. The passenger side rear turn signal comes on to indicate that corner sensor is ready to be learned. Proceed to the passenger side rear tire and repeat the procedure in Step 5. 8. The driver side rear turn signal comes on to indicate that corner sensor is ready to be learned. Proceed to the driver side rear tire, and repeat the procedure in Step 5. 9. After hearing the single horn chirp for the driver side rear tire, two additional horn chirps sound to indicate the tire learning process is done. Turn the ignition switch to LOCK/OFF. If no tires are learned after entering the TPMS learn mode, or if communication with the receiver stops, or if the time limit has expired, turn the ignition switch to LOCK/OFF and start over beginning with Step 2. 10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label. 11. Put the valve caps back on the valve stems. ... Mike -1991 Turbo SL2 - Gone, but not forgotten. 11.809 @ 116.488 mph www.differentracing.com -2000 Saturn SC2 -2001 Chevrolet Suburban -2011 Rally Yellow Chevrolet Camaro 2SS RS
#2 | ||||
![]() ![]() ![]() Join Date: Mar 2010
2009 AURA XE
![]() Very well done. But I have to admit I'm just too lazy. I just marked the original location on the wheels themselves & called it good. Hopefully that system will incorporate self-tracking of wheel location someday.
We haven't heard from you for awhile. Hope all is ok.
#3 | |||||
![]() Quote:
I've been busy latley. I usually do a lot of my posting from work and things have been busy. ... Mike -1991 Turbo SL2 - Gone, but not forgotten. 11.809 @ 116.488 mph www.differentracing.com -2000 Saturn SC2 -2001 Chevrolet Suburban -2011 Rally Yellow Chevrolet Camaro 2SS RS
looking for video on input shaft nut procedure | jamesirs | S-Series Tech | 4 | 10-06-2010 11:59 AM |
Tpms | bj6395 | Aura General | 14 | 11-24-2008 01:46 PM |
ECM reprograming | jonsq54 | Vue Mods | 16 | 05-01-2007 07:44 PM |
Reprograming a remote | ImpalaSS | Vue General | 3 | 11-29-2005 06:44 PM |
REDLINE ecu reprograming? | punisherken | Mods and Performance | 3 | 09-19-2005 08:48 PM |
