Old 10-18-2011, 07:29 PM   #1
robert16
robert16 is on a distinguished road
Default 1999 Saturn SL2 Transmission leak
Alright friend just sold me his 1999 Saturn SL2 automatic the only problem is it has a small transmission leak. And I am afraid of it getting worse, is there anything i can do to fix it? He told just to put more transmission fluid in every couple of weeks.
Should I just buy a new transmission or?
Sorry this is my first car so I wanna take of it.
Thanks for any advice.
Add to robert16's Reputation
Rate the quality of this post and help robert16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robert16 is offline   Reply With Quote
Old 10-18-2011, 07:54 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: 1999 Saturn SL2 Transmission leak
Have you found the source of the leak? It could be as simple as not having tightened the filter enough. The PSI on that filter is high and needs to be tightened very well.
New owner As of 01/01/18: 225,000 Miles
As of 05/10/18: 48,065 Miles
Old 10-19-2011, 01:21 PM   #3
adventureoflink
adventureoflink's Avatar
or perhaps the filter is some crap aftermarket brand; for this reason most people prefer OEM, WIX, and/or Baldwin filters for the transaxle.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 10-20-2011, 01:19 AM   #4
robert16
I'll try replacing the filter, and update you on the leak.
Old 10-20-2011, 11:35 AM   #5
campus189
campus189 is on a distinguished road
campus189's Avatar
1997 SL1
Also check transmission lines where they go into transmission and radiator.
Look and see if they are leaking around the connectors.
Can you see where it is dripping from ?
1997 Saturn SL2 144,000 Miles
1997 Saturn SL1 254,000 Miles
1997 Saturn SL1 157,000 Miles
1996 Saturn SL1 97,000 Miles
Also known as FiremanCV on YouTube
Add to campus189's Reputation
Rate the quality of this post and help campus189 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
campus189 is offline   Reply With Quote
Old 10-20-2011, 03:01 PM   #6
If your friend cannot tell you for certain that the fluid and filter have been replaced within the last 30,000 miles, this would be a golden opportunity to change them. It's easier than an oil change, and will rule out one possible source of the leak.
Add to madpogue's Reputation
Old 10-20-2011, 08:43 PM   #7
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2003 VUE 2.2L
I would agree, mad, except for refilling. It takes forever to refill the tranny fluid. I have not tried a vented funnel yet.
OP - during your fluid change, clean-clean-clean up all around the tranny then keep a close eye for the leak. The new, red fluid will be easy to see and trace to its source. It might be an axle seal or the fill plug (along with the aforementioned filter).
shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 10-20-2011, 08:48 PM   #8
PurdueGuy
PurdueGuy's Avatar
1999 SC1
don't just replace the filter, see if the fluid is coming from that area first. If your problem is a bad diff pin, it's silly to replace the filter, as the leak would be coming from nowhere near the same area. Look for the source, then take action.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 10-24-2011, 02:23 PM   #9
robert16
I replaced the filter because it was terrible it was covered in dried oil and was disgusting so we replaced that, But after that the radiator hose broke and when we ran the car it was just dumping out all of the coolant, so I cut a little piece off and it seems to of fixed it.
The leak looks to have stopped but I put a piece of cardboard under the car over night and in the morning I looked and it had some spots of transmission fluid? What else might be the problem?
1998 Saturn SL2
Date purchased: 10/22/11 104.000 miles for $1,250.00
Old 10-24-2011, 03:29 PM   #10
dcp
dcp is on a distinguished road
dcp's Avatar
might be the seal around axel
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 10-24-2011, 03:31 PM   #11
dcp
dcp's Avatar
might be the seal around axel,where it goes into trans.
Old 10-24-2011, 04:01 PM   #12
almoore
almoore is on a distinguished road
1994 SC2
The dif pin leak is tricky.Purdue Guy is right,clean up the area.If you have leakage out of the inspection plate area ,it may be the dif pin. As the dif pin slowly pulls out of its carrier,the end of the pin scratches the aluminun case. The leak may start out slow ,but the end result is always the same.Richpin has a good video on dif pin inspection.
"No good deed goes unpunished"
Add to almoore's Reputation
Rate the quality of this post and help almoore reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
almoore is offline   Reply With Quote
Old 10-24-2011, 08:17 PM   #13
2NDSOUT
2NDSOUT's Avatar
1999 SL
This might be something out there, but worth a thought too... check the trans bell housing bolts and make sure that they are tightened. Believe it or not; I had the auto trans housing bolts come loose once, and my Saturn mechanic had to retighten them. I had a slow leak from the bolts being loose... this was in my 94 SC1.
Just a thought.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 11-18-2011, 03:51 PM   #14
robert16
I added Bars Stop Leak but that hasn't seemed to work either :/
1998 Saturn SL2
Old 11-18-2011, 09:21 PM   #15
ShawnV
ShawnV's Avatar
2003 VUE 2.2L
I would not use stop leak in your tranny! I would drain that out right away.
Clean the trans and lines, then let the car warm up. Shut it off and look for your leak. Once you find it you can take actions, like Purdue said above.
Old 01-16-2012, 01:48 AM   #16
robert16
I cleaned it and it seems to be coming from the sensor that is in there. Its like dripping Tranny fluid.
1998 Saturn SL2
Old 01-16-2012, 01:49 AM   #17
adventureoflink
which sensor?
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 02-25-2012, 03:20 AM   #18
robert16
Originally Posted by adventureoflink View Post
which sensor?
not sure, it looks like a sensor sticking out, and just seems to be covered in transmission fluid. Ill try to get pictures when i go under again.
1998 Saturn SL2
1999 saturn sl transmission problem Prejerism S-Series General 11 03-19-2010 07:55 PM
1999 SL1 SOHC oil leak and burn buildup greasemonkey26 S-Series Tech 9 02-24-2010 04:35 PM
Steering Rack Leak - Diagnosis 1999 SW2 bdog S-Series Tech 12 07-27-2009 07:07 PM
By pass module for 1999 saturn sl-2 manual transmission... prabhakarglv S-Series Tech 4 02-08-2009 04:06 PM
1999 Saturn SC1 Auto Tranny Leak...Please Help mtsumedi S-Series Tech 3 09-29-2007 11:37 AM
