Old 10-11-2011, 07:18 AM   #1
Austen1023
Austen1023 is on a distinguished road
Default Sunroof Problem
The sunroof on my 2007 Aura XR works only intermittently. When it does open, it only stays open for a few minutes and then closes on its own. Anyone have any ideas on what could be causing this and/or how to fix it? Thanks.
Add to Austen1023's Reputation
Rate the quality of this post and help Austen1023 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Austen1023 is offline   Reply With Quote
Old 10-11-2011, 09:46 AM   #2
golftango
golftango is on a distinguished road
golftango's Avatar
Default Re: Sunroof Problem
Panoramic or standard sunroof?
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
http://www.flickr.com/photos/golftango
https://500px.com/golftango
https://www.instagram.com/golftango
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is offline   Reply With Quote
Old 10-12-2011, 08:55 AM   #3
Austen1023
Panoramic
Old 10-12-2011, 12:40 PM   #4
golftango
golftango's Avatar
The Pano sunroofs on the Aura/G6 were very problematic and GM dumped them quickly and moved over to the standard sunroof. Looking at this post, one member was having the same issues you mentioned, but I don't see a resolution:
http://saturnfans3.saturnfans.com/~s...d.php?t=105862
Old 10-12-2011, 06:35 PM   #5
whiteshadow
whiteshadow is on a distinguished road
well that sucks. i liked the pano roofs. granted my xr has a standard sunroof. i always thought the pano was a nice feature. glad i dont have it now if they are that problematic
07 aura xr
98 explorer 5.0
93 miata, not stock
77 f150
im not nice
number of times ban.T
1
Add to whiteshadow's Reputation
Rate the quality of this post and help whiteshadow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whiteshadow is offline   Reply With Quote
Old 10-13-2011, 07:25 AM   #6
Austen1023
Thats too bad. I really enjoy using the sunroof when it works. Thanks for the info.
Old 10-13-2011, 01:54 PM   #7
eadgils
eadgils is on a distinguished road
2007 AURA XR
My 07 XR has the Pano too, but I dont have a singly problem, other than having to adjust the panels once, which isnt that hard actually. and made any noise vanish. I wonder if there is something in the swtich or maybe see when you have the glass open and see if something is triggering the close sequence. That would be my best best. So if you can see if there is anything in your switch that would trigger it.
Add to eadgils's Reputation
Rate the quality of this post and help eadgils reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eadgils is offline   Reply With Quote
Old 07-04-2015, 01:03 PM   #8
mmtphoto
mmtphoto is a jewel in the roughmmtphoto is a jewel in the roughmmtphoto is a jewel in the rough
mmtphoto's Avatar
2007 AURA XR
old thread i know but i am having the same issue with my standard sunroof on my 2007 xr-it opens and closes ok, but it will close by itself, expecially when going down a slight incline (like the end of a driveway) and making a left or right turn. It's really weird, doesnt matter if it is all the way open or flipped up, and sometimes it closes in increments, a little at a time. Have replaced the switch with a NOS switch still in the original GM bag), and do not have a wiring diagram. I have checked grounds in the back of the car, they seem to be good using an ohm meter to check them out. Any ideas?
Add to mmtphoto's Reputation
Rate the quality of this post and help mmtphoto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mmtphoto is offline   Reply With Quote
Old 07-04-2015, 08:33 PM   #9
Try this;
Old 07-05-2015, 02:28 PM   #10
greenman
2009 AURA XE
sounds like the orange close signal wire is intermittently shorting to ground somewhere along its run.
with an email address, i'll send u the schematic.
Add to greenman's Reputation
Old 07-05-2015, 07:08 PM   #11
mmtphoto
mmtphoto's Avatar
2007 AURA XR
'sounds like the orange close signal wire is intermittently shorting to ground somewhere along its run.
with an email address, i'll send u the schematic'
message sent-thanks
Old 07-06-2015, 01:51 PM   #12
greenman
2009 AURA XE
Originally Posted by mmtphoto View Post
message sent-thanks
none received
Old 07-07-2015, 05:31 PM   #13
mmtphoto
mmtphoto's Avatar
2007 AURA XR
Originally Posted by greenman View Post
none received
sent it again, don't know what happened the first time, thanks for the follow up
Sunroof problem LIGuy Ion General 1 08-14-2011 10:54 AM
sunroof problem Drew Fiedler S-Series General 4 09-20-2007 12:28 PM
SL2 Sunroof Problem paulygon S-Series General 9 02-06-2005 05:12 PM
Sunroof Problem. Masterson Ion General 2 09-03-2004 03:59 PM
Sunroof Problem PuckNut S-Series Tech 7 04-05-2000 09:01 PM
