Old 10-06-2011, 08:29 AM   #1
chainsaw064
chainsaw064 is on a distinguished road
Default Car running rough, replaced EGR
First time posting here. thanks to everyone who helps.
I was given a 2001 SC2 with 266k miles. This car runs great with the EGR disconnected. I was told to check the oil every 1000 miles, no smoke from the tail pipe or any leaks it just burns oil. I get 30 mpg. When I connect the EGR the car runs like a dog.
Yesterday, following another tread here. I replaced the EGR, CPS (this was fun), ECTS with any change. Where do I go from here?
Thanks
Dave
Add to chainsaw064's Reputation
Rate the quality of this post and help chainsaw064 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chainsaw064 is offline   Reply With Quote
Old 10-06-2011, 12:59 PM   #2
ehunter
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
Default Re: Car running rough, replaced EGR
What do you mean "disconnected"?
Do you mean only the wires disconnected or do you mean you unbolted it and blocked the holes off, and remounted the device back on the car?
Add to ehunter's Reputation
Old 10-06-2011, 05:31 PM   #3
chainsaw064
This would be with the connector disconnected. With it disconnected I get the P0405 code. I came home from work this evening and tried the two quarter trick blocking the EGR, with the connecter plugged in. I got the P0405 code right away, and it ran terrible.
Dave
Old 10-06-2011, 09:57 PM   #4
ehunter
So the car runs great with the EGR wires pulled, and poorly when connected and the results were the same when you bought a replacement EGR.
Hmmmm If we are playing stump the chump, you got me...
Maybe some of our more senior experts like Oldnuc, Mad or Fdryer can advise.
Old 10-06-2011, 10:16 PM   #5
td1238
If you put in a brand new EGR valve, and the engine works poorly when it's plugged in, and well when unplugged, then there is likely a fault in the wiring. Could also be a faulty valve sensor, but unlikely. You can test the valve sensor (center three terminals) with an ohmmeter. Measure between the center and each adjacent terminal, one at a time. Move pintle. Resistance should change smoothly and start and stop in the same place repeatedly.
If the fault is in the wiring, you can check the wiring by connecting it to the EGR valve. One end of the three center terminals should measure +5 volts. The other end of the three should measure 0 volts. The center terminal should vary as the pintle is moved.
The outer two terminals send voltage to the valve solenoid coil. Voltage should be 0 at both at idle. Voltage should increase at one as the valve is opened to varying degrees while cruising, and only while cruising.
Add to td1238's Reputation
Old 10-07-2011, 07:06 AM   #6
chainsaw064
what do you mean by moving pintle?
Thanks
Old 10-07-2011, 09:12 AM   #7
td1238
The EGR valve contains a movable device called a pintle. This device performs the valving action.
Engine replaced, new one not running right jaymz8584 S-Series Tech 9 10-12-2010 02:06 PM
Rough Idle when warm - ECTS has been replaced maasdad S-Series Tech 7 09-27-2008 09:26 AM
Replaced clutch hydraulics, shifting still rough macbox S-Series Tech 42 08-27-2008 12:09 AM
Replaced ECTS-Almost running right... kt97sl2 S-Series Tech 3 08-25-2008 10:08 PM
95' SC1, Running rough, help Dreamimage S-Series Tech 7 12-10-2007 11:26 PM
