Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Tech
Old 10-03-2011, 04:22 PM   #1
bill4949
bill4949 is on a distinguished road
Default thermostat problem
My coolant level indicator went to 259 degrees. before i could get heat. once the heat came the therostat went down to 190's. I think I have a problem with the thermosta not sure can there be any other problems.
Bill
Add to bill4949's Reputation
Rate the quality of this post and help bill4949 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bill4949 is offline   Reply With Quote
Old 10-06-2011, 01:34 PM   #2
ToledoEngineer
ToledoEngineer is on a distinguished road
ToledoEngineer's Avatar
2008 SKY Red Line
1992 SL1
Default Re: thermostat problem
I had a simliar problem a few years back. See thread below.
http://www.saturnfans.com/forums/sho...d.php?t=150261
It ended up being fixed under a Tech Service Bulletin and Warranty. My problem was that two check valves had failed, iirc.
"Education is the progressive realization of our own ignorance"
1992 SL1: 149k miles
2008 Sky RL: 35k miles
Add to ToledoEngineer's Reputation
Rate the quality of this post and help ToledoEngineer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ToledoEngineer is offline   Reply With Quote
Old 11-22-2013, 05:00 PM   #3
3275mbrown
3275mbrown is on a distinguished road
I have a 2007 Sky Red line.
I never had an over heating issue until recently.
I can run the car for hours on back roads and highways with normal temperatures.
Once I push the gas pedal down to the floor to excellerate the cars temperature will go to 258 degrees. If I let the car cool down completely then restart it will resume normal temperatures.
I thought it might be a stuck thermostat. Has anyone else seen this before?
If so email me at 3275mbrown@comcast.net
Add to 3275mbrown's Reputation
Rate the quality of this post and help 3275mbrown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
3275mbrown is offline   Reply With Quote
Thermostat/Antifreeze problem MCJONES S-Series General 4 08-17-2011 04:19 PM
Heater Problem Thermostat ebristol S-Series Tech 13 02-11-2007 02:28 PM
Thermostat problem? Mooncet S-Series General 16 01-14-2007 08:42 PM
Possible thermostat problem? TvSteve S-Series Tech 6 01-22-2005 02:46 PM
Thermostat wasn't the problem? emptypockets S-Series Tech 11 12-22-2004 05:21 PM
