Old 09-28-2011, 09:01 PM   #1
nature noggins
nature noggins is on a distinguished road
Default All checks out well but car won't start
My future son-in law has a 97 Saturn sc2, standard transmission. All has been fine until a few weeks ago when the car suddenly wouldn't start. it just clicked. After a few tries it started. When he got to my house we threw the battery charger on it. It showed a slightly weak battery so we left the charger on all night. The car started fine the next day. Although he hasn't driven much in the past few weeks all seemed fine. I took it to our local Autozone today and they checked the battery, starter and alternator. All was fine with all three. He said the wiring between also checked out fine. When we left, we stopped to get gas and the problem started again. A slow crank with no turning over. A second effort started the engine.
When we got home I checked the battery connections and they were clean. Where the ground connects to the frame it was a bit rusty so we took it off and cleaned it thoroughly and reconnected it. When we tried starting the car it just clicked and wouldn't turn over. 3 attempts and no luck.
The dude at Autozone said if it happens again we should check where the flat silver ribbon ground connects to the frame. I couldn't find any such beast but checked every wire I could find for corrosion or loose fitting. No problems that I could see.
Any suggestions?
Add to nature noggins's Reputation
Rate the quality of this post and help nature noggins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nature noggins is offline   Reply With Quote
Old 09-28-2011, 09:18 PM   #2
Default Re: All checks out well but car won't start
A battery over fours years old can be suspect if its a low priced one with a low warranty; something like a 3yr battery warranty will fail close to three years, 4yr battery dies at 4yrs, etc.. If the battery cables are clean and free of any corrosion then the starter is next.
An original starter and how many miles on this car? Over 100k miles and original tends to point to a worn out starter although some get past 150k miles+ (all highway mileage). Short trip driving many times a day will shorten the life of a starter. Unless you're skilled at starter disassembly, you won't know how worn the wear items are - starter brushes and starter solenoid contacts. Some have had excellent luck disassembling their starter only to find a very dirty set of heavy duty electrical contacts that were cleaned up and allowed it work as good as new.
Old 09-28-2011, 09:42 PM   #3
off-track
off-track's Avatar
I agree with FD!
Sounds like a classic starter going south to me but, if the battery is old that can confuse the issue. The engine grounds are on the top of the transaxle bell housing.
http://www.youtube.com/watch?v=Zjstj9kWos0
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 09-29-2011, 07:18 AM   #4
nature noggins
Question Re: All checks out well but car won't start
There are 136,000 miles on the car and I'm not certain if the starter is original. I went out this morning to work on the car. I turned on the lights and cranked it over. The lights didn't dim so I know it's not the battery. The car started right up. I tried starting it numerous times and it started each time with no problems.
As mentioned in the original post, the Autozone guy put his sensor on the car and tested the battery, starter and alternator and all checked out fine. So the battery, starter and alternator are not the problems.
Any other thoughts?
Old 09-29-2011, 08:05 AM   #5
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re:rushes All checks out well but car won't start
Next time it happens, tap on the starter with something. That will reseat the brushes, which is a symptom of a starter going bad, as fdryer and off-track have already diagnosed. I would have more faith on info. obtained on this site than a diagnosis from Autozone, which tends to be too generic.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 09-29-2011, 08:11 AM   #6
td1238
New brushes are available from NAPA, but must be ordered from Virginia, but they're inexpensive.
The solenoid is also available, and I believe it costs around $35.
...Or you can go the fast but not so inexpensive way of entire motor replacement.
If you do rebuild the starter motor, be sure to clean all of the connecting straps and their respective terminals (nuts and bushings).
Add to td1238's Reputation
Old 09-29-2011, 11:30 AM   #7
nature noggins
Happy Re: All checks out well but car won't start
Thanks everyone. I'll tell my future son-in-law to tap the starter (I'll have to show him where it is as he is not car savvy) next time it happens and I'll look into fixing it for him when I find more time.
Thanks again everyone!
Old 09-29-2011, 12:22 PM   #8
porphyre
porphyre has a spectacular aura aboutporphyre has a spectacular aura about
2001 SL2
Nature - I've got an 01 SL2 w/ 135,500 miles and just replaced the starter. Exact same symptoms... would start fine most mornings (sometimes a weak start, though) but randomly stopped restarting when hot. IE, at gas stations, short trips to the store, etc.
My particular car went from always starting (but sometimes starting weak) to being dead as a doornail in about 7-10 days.
Watch the Richpin starter removal video on Youtube.
Also get a 20"+ breaker bar to remove the top starter bolt. And PB Blaster.
Good luck. Starter replacement isn't hard, but it sure sucks.
Add to porphyre's Reputation
Rate the quality of this post and help porphyre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
porphyre is offline   Reply With Quote
Old 09-29-2011, 10:04 PM   #9
off-track
off-track's Avatar
Just save some time and replace it now. It will get worse. Not a big job, just awkward with the top bolt. Better to swap it when it's still starting than be stuck in the middle of nowhere when it finally gives up the ghost!
http://www.youtube.com/watch?v=U6awyslXkeI
Added OEM CC
Old 09-30-2011, 05:58 AM   #10
saturn94v
saturn94v is on a distinguished road
saturn94v's Avatar
1994 SC1
Battery, Battery , Battery. First, make sure you are working with a STRONG, fully charged Battery!
Starter, Starter , Starter !
Check those connections between Battery & Starter. Have friend turn key to start while you test voltage at starter.
If voltage is good; check starter ground;
Starter brushes could have "flat spot" at that age. Hit it with a hammer while friend is cranking. Doesn't all ways work. But if you are 100% you have good voltage to starter and good ground...you'll need a new starter.
ASE Technician
94 SC1 1.9L SOHC
GM Blue Green
278,429 miles
32+/- AVG/MPG
Add to saturn94v's Reputation
Rate the quality of this post and help saturn94v reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn94v is offline   Reply With Quote
Old 10-02-2011, 12:56 PM   #11
nature noggins
Ordered a starter today and will get it in this week. Thanks everyone for the help.
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 10:27 PM
Jay Leno Checks Out the 2008 Saturn Astra Charlie Astra General 3 05-10-2008 11:05 PM
2003 Vue VTI AWD - questions in Trans Fuild Checks/Changes 03_Vue_VTI_AWD Vue Tech 3 10-14-2007 05:25 PM
Buying Used: Salvage/Rebuilt, accidents, & air bag checks rtfm17 S-Series General 4 10-13-2007 10:26 PM
