#1 | ||||
![]() Join Date: Sep 2011
Hello is there a average amount of milage a well maintained saturn sl will last?? I currently have a little under 120k how long do most of them last? 150k? 170k??
#2 | ||||
A lot more miles! The number one causes for "death" of a Saturn are probably failure to maintain oil levels and/or accident. Well over 200K miles is not uncommon among folks here (my '95 is at about 166K).
The real question is what criteria do you want to use to decide when it is at end of life? Cost to repair based - relative to some "book value"? Cost to replace with equivalent transportation? Insurance compaly guides?
#3 | ||||
![]() Join Date: Sep 2010
1998 SL
I know this isn't exactly answering your question, but my 98 SL has 147k and runs great, there's others here with way more miles, and original too.
... "Not for human consumption!" - Peas in the Pod http://www.facebook.com/#!/pages/Peas-in-a-Pod/160649663950771
#4 | ||||
![]() Join Date: Feb 2008
2002 SL1
we've got guys on here going over 400k. Im not sure at what point you need to replace the head, but yeah, you can run these things until you get sick of them
... '02 SL1.414213562^2, Deebs ftw
#5 | ||||
Awesome good news so i have the 97 sl1 and i heard they have head problems im assuming when it goes the symptoms will be the same as a blown head gasket? oil mixing with coolant and smoke out of the exhaust?
#6 | ||||
1998 SL
They're known for blowing their heads or gaskets.
I had a 96 sl1, only bought it for a parts car, but ended up using it as a field car, took it 2 miles across a field to our campsite on fam property. Anyways, we got it knowing it blew smoke. It started, blew smoke for maybe 5-10 minutes out the tailpipe, thought it was the trademark Saturn burning oil thing. It wasn't. I read up, did a compression test, and the 3rd cylinder was blown. Never found out if top or bottom end, I kick myself for junking it, would of loved to tinker with it and find out for sure, but we needed the room. It ran poorly, but still ran at normal speeds. We ended up putting 700 miles on that summer with it dying like it was. If yours is already doing this, you may have a problem. If not, just drive it, and maintain it. Obviously keep that oil topped off at all times! It really does take alot to kill a Saturn,lol! ... "Not for human consumption!" - Peas in the Pod http://www.facebook.com/#!/pages/Peas-in-a-Pod/160649663950771
#7 | ||||
![]() Join Date: Jan 2009
I got my first saturn with 17k miles, and now have 250k on my 97 SL1. I only replaced items like the alternator, water pump, ECTS, thermostat, belt tensioner, and other small maintenance items.
Changed the oil every 3,000 miles, and it did not burn any until around 230k. Checked it once a week. Changed the trans fluid at 125k and again at 200k (automatic). Was a 97 SL1, and never had the head crack on it. Never had the radiator crack or leak either. Oh yeah, if you didn't know, the 97 has a slight issue with the fuel pump, in that if it does not start up right away when cranking, just put your key to the run position, wait a couple seconds, then try to crank it. I had to do this every time it sat more than half hour or so, because the fuel rail would lose pressure due to the weak check valve. (not worth replacing it, just deal with it). Reason I stopped driving it is the wheel bearing started going out, and I picked up a 95 SC2 which I rebuilt the engine and have been driving ever since. My 97 been sitting for the past couple years and I still can't bring myself to get rid of it.
#8 | ||||
Look at the odometer in post 767 on this thread (car with original engine, trans, and timing chain)
http://www.saturnfans.com/forums/sho...115829&page=39oooh, that's one of the combinations I want.... a '95 SC2 in good mechanical shape, so I can swap in a manual trans from a SOHC car - better mileage and working cruise. ... ...Wait, what, I actually won that eBay auction? Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p And now (7/2010), a Craigslist 1997 SC2 5 spd
#9 | ||||
![]() Join Date: Nov 2010
Location: Pacifica by San Francisco – 5sp – Engine rebuilt with the help of people here at 177K to deal with 300mi/qt oil consumption. Engine runs beautifully. Now at 192K with syn oil.
If the car is taken care of by the book, meticulously, it will go well beyond 200k without issues.
Slipping up on its care a half dozen times over 16 years seems to get the car to a common 170-180k miles. For some reason 170k miles seems to be a common point when something notable will need to be done.
#10 | ||||
![]() Join Date: Jun 2009
1998 SL1
98 SL1 340,000 miles
DD... Wanted: Dealer items (frames/ key-chains) Current 05 Vue 3.5 87k :) 98 SL1 260k m 08 Outlook XE 20k a Past 98 SW2 160k 96 SW2 114k 98 SL2 115k a RIP :( 95 SL 175k m 03 Vue I4 160k m
#11 | ||||
![]() ![]() ![]() Join Date: Apr 2009
97 SL2 with over 190k miles
![]() also, keep in mind that all the oil burning kills cats... ... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive & Well 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, prolly needs front driver strut
#12 | ||||
![]() Join Date: Feb 2010
1996 SW1
2002 SC1
I need to update my sig...The SC1 is at 263000 now. Of course the engine has "only" about 181000...
... '96 SW1, 200000 miles "Little Red Wagon" '02 SC1, 268000 miles, "Blue Basketcase"
#13 | |||||
I think Luke is at #2, but 5 months since he updated his miles
#14 | ||||
165K miles and still runs like new - getting roughly 39 MPG from 80% HWY miles.
Items replaced: Oil Change (42 times) Air Filter (4 times) Battery (3 times) PCV (3 times) Tires (3rd set) Serpentine belt (twice) Coolant (twice) Plugs (twice) Wires (once) 02 Sensor (once) Thermostat (once) Water Pump (once) TPS (once) Shocks - all four (once) Upper Motor Mount (once) Fuel Filter (once) Everything else is original, including every single light bulb! I'm getting itchy to buy a new car, but my car shames me into keeping her. ... 2002 SL2 Manual - new in November, 2001 Sticker: $13,995 As of 03/13/13: 179,571 Miles
#15 | ||||
The only valid answer to your question is "as many miles as you want to".
Everything that spins can be replaced if it needs it.
#16 | ||||
![]() Join Date: Jul 2004
Luke is the mileage king and I won't catch up but I have just under 300K on my '99 SC2. I am meticulous about the oil changes and keeping up my general maintenance. Runs like a champ.
#17 | ||||
![]() Join Date: Aug 2011
Well I have 196,800 miles on mine atm.runs like a champ I still get around 30-32 mpg on the hiway,doesnt burn to much oil.I hope to get another 100,000 miles on it at least.I will get rid of my 97 sl2 when it rusts away.I luv my Saturn,altho I do pick up a lot flack from certain ppl over it,I just laugh while they fuel up their big SUV's.
#18 | |||||
![]() Join Date: Jul 2001
1995 SL
I tell people my Polish hybrid is more cost effective than their Japanese hybrids. (blank look) Their Japanese hybrid cost $25,000 and gets 48mpg(Prius) by burning a combination of gasoline and electricity for the goal of minimal fuel usage. My Polish hybrid was practically free (except DIY rehab costs) and gets 40mpg by burning a combination of gasoline and engine oil for the goal of minimal dollar usage!
#19 | ||||
1999 SC1
I've got 266500 on my s -series. I also am running the original clutch.
#20 | ||||
![]() Join Date: Jan 2013
1999 SL
My 99 Saturn sl1 is at 460,000 kms. That's almost 286,000 miles. I am really excited to see when it hits half a million kms. I will be disappointed if it doesn't reach it. I have very high expectations now that it has lasted this long.
It has had the usual things wear out but nothing major ever. I am on my fourth wiper motor but even that isn't major although a nuisance it was. I get great gas mileage which is good because I travel 160 kms every day for work. It will be a sad day when I have to retire my Saddie. Right now I am having issues with warning lights and have to get it looked at later today. I am hopeful that it isn't anything serious since it still seems to be running like a charm. Wish me luck and good luck with yours. They really do seem to last forever! Cindy
| Thread Tools | |
| Display Modes | |
| Our FOUR Saturns average 115,000 miles apiece BUT.... | Arnel | General Saturn Discussion | 7 | 07-18-2007 03:43 PM |
| Average Gas Mileage on the L-Series | cagirl765 | L-Series General | 14 | 08-11-2004 09:21 PM |
| Average Miles Per Gallon ??? | 04Vue | Vue General | 3 | 12-29-2003 08:50 AM |
| Average Miles Per Tank - 92 SL1 | SyNNeR | S-Series Tech | 5 | 04-18-2002 09:37 PM |
