Old 09-19-2011, 10:19 AM   #1
HelpMe
HelpMe is on a distinguished road
Default sc fuel pump
can a 95 sc fuel pump be used in a 93-94? i got on rock auto and if you look up a fuel pump for a 93 sc1 you get e3909m part number, which in the notes says only 93-94. but you look up a 95 sc1 you get a e3905m. what is the difference and if you were to run a 95-96 pump what would the car do?
Add to HelpMe's Reputation
Rate the quality of this post and help HelpMe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HelpMe is offline   Reply With Quote
Old 09-19-2011, 02:03 PM   #2
TomM96
TomM96 will become famous soon enough
Default Re: sc fuel pump
Hi Help-
not sure what would happen . There are differences in the specified output pressures of various year pumps. Most are close enough that the FuelPresureRegulator would probably handle it. Mebbe look at Haynes manual to check pressure specs.
Add to TomM96's Reputation
Old 09-19-2011, 02:32 PM   #3
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
Buy the correct year. If I understand correctly this is for an SC1 SOHC which pre 95 is throttle body injection. Using a MPI versus a TBI pump may not work properly.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
I don't have a fuel pressure gauge, is there a way to check problem fuel pump without dddaaa S-Series Tech 6 08-06-2011 02:09 PM
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 11:34 AM
Help! Changed fuel pump, Now my fuel gauge is stuck on full! jimbo1490 S-Series General 5 06-14-2009 04:59 PM
Is it the Fuel Pump or Fuel Pressure Regulator? JasonJ L-Series Tech 2 02-24-2009 04:04 PM
FUEL PUMP or FUEL SENDING UNIT?.. saturn94v S-Series Tech 6 07-27-2008 09:40 AM
