Old 09-17-2011, 03:44 AM   #1
Cartell
Cartell is on a distinguished road
Roll Eyes Turn signals & hazards intermittent in 91 SL2
Hello,
I can see from browsing here that the electrical parts are very different for each model, and before I take the car to the garage wonder if you could point out what parts they might quote for for my year.
91 SL2 turn signals became more cranky each time I drive. Ok in startup, then blink only once or twice or not at all while driving. Reading the forums, I notice other people mention hazards. I've never used mine, but same with them: ok on startup, but when turns don't work, neither do hazards.
I don't see a hazard light fuse in the diagram, just a turn fuse. Is it called something different? Just by looking, fuses all look same to me.
Is this more likely to be a hazard switch or steering wheel problem, do you know? Are hazards/turns connected in this model? Hopefully not steering wheel, as that sounds very expensive.
Add to Cartell's Reputation
Rate the quality of this post and help Cartell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cartell is offline   Reply With Quote
Old 09-17-2011, 09:51 AM   #2
Default Re: Turn signals & hazards intermittent in 91 SL2
The HAZARD fuse is in the underhood fuse box. But that's not likely the problem, as it's involving both the turn and hazard. They are connected (of course, they use the same bulbs). They also use the same flasher module, which is located on the back side of the interior fuse box. You take off the kick panel on the driver's side to access it. That's your most likely suspect.
If it is the switch, it's behind the steering wheel, not in it. It's one big part, called the Lever Combination Switch, that includes everything on both stalks. Actually not that hard to remove; you remove the steering wheel (puller tool available at your FLAPS for free lending) and an electrical part called the clockspring. Not having an air bag simplifies things some.
But check out that flasher module first. A junkyard replacement would be an easy/cheap way to "test" it.
Add to madpogue's Reputation
Old 09-19-2011, 12:14 AM   #3
Cartell
Thanks very much, madpogue, that's very helpful, and I've printed this out for the garage. I understand what 2 things they'll check now.
I would give you points, but the forum says I need to "spread it around" before giving you points again...
Turn signals not working. Hazards work cwills2 L-Series Tech 17 03-20-2016 07:37 PM
sc turn signals and hazards wont work faf112 S-Series Tech 4 03-20-2016 06:07 PM
Turn signals don't work, hazards do a7x_audiojunkie S-Series Tech 2 06-03-2009 04:03 PM
94 SL2, hazards disable turn signals My Range S-Series General 3 11-21-2005 05:53 PM
turn signals and hazards just stopped working renadena S-Series General 6 05-14-2005 03:14 PM
