Old 03-12-2003, 11:22 PM   #1
DualCamCoupe
DualCamCoupe is on a distinguished road
DualCamCoupe's Avatar
Default Disc vs. Drum Brakes
So why exactly are disc brakes better than drum brakes?
Add to DualCamCoupe's Reputation
Rate the quality of this post and help DualCamCoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DualCamCoupe is offline
Old 03-13-2003, 12:24 AM   #2
Phil
Phil is on a distinguished road
Default
Discs shed heat better, so you get less fade. Brake fade is where, in repeated stops, the brakes gradually lose power. Discs are also more powerful. And they are much easier to maintain (drum brake springs were invented by Satan). And they look better through the spokes of a wheel.
But apparently drums are cheaper, so guess which ones Saturn uses in the rear?
Add to Phil's Reputation
Rate the quality of this post and help Phil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phil is offline
Old 03-13-2003, 12:30 AM   #3
silverplum
silverplum is on a distinguished road
Default
Check out this link.
http://www.edmunds.com/ownership/tec...7/article.html
Add to silverplum's Reputation
Rate the quality of this post and help silverplum reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverplum is offline
Old 03-13-2003, 09:43 AM   #4
Jeff P
Jeff P is on a distinguished road
Jeff P's Avatar
Default
The Edmunds take is interesting. For the most part, rear drums stop the car as or nearly as effectively as rear discs. From a purely objective, feet-to-stop standard. But I'd rather my car stop in 120 feet than 125 feet. Those last five feet could be the difference between hitting something and not! It's also funny because Edmunds, like all the auto reviewers, discuss braking feel a lot in their reviews. Disc brakes are far superior to drums in this respect. They engage smoothly and react to the pedal in a linear manner. They're just plain nicer from a driving standpoint. And I'd love to see the numbers as to how much it would cost to have them standard on a car. I can't imagine it would be more than $100-200 bucks.
btw my mountain bike even has disc brakes. They're awesome!
jeff
Add to Jeff P's Reputation
Rate the quality of this post and help Jeff P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeff P is offline
Old 03-13-2003, 07:08 PM   #5
ProDarwin
ProDarwin is on a distinguished road
Default
Phil is right, working on drums will make you want to kill whoever invented them. Discs are a whole lot easier to work on, and are very cheap to maintain. (I just did all 4 discs and pads for less than $110). And drum fade is horrible. It takes forever for them to cool back down.
-Travis
Add to ProDarwin's Reputation
Rate the quality of this post and help ProDarwin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProDarwin is offline
Old 03-13-2003, 07:52 PM   #6
Qlara
Qlara's Avatar
Default
Ha! I found this is ever-asking question in here.
On later Saturn cars: S-series, ION, L and even VUE they are all Drum brakes at the rear as standard.
As we all agree on Disc brake is superior (also looks better) than Drum, but it's not cost-wise for Saturn Corp. For regular commuter driving, drums work OK, so are the standard Firestone tires......
Add to Qlara's Reputation
Qlara is offline
Old 03-13-2003, 08:18 PM   #7
amazinghl
Default
Like me.. i have all wheel disc.
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 03-13-2003, 09:12 PM   #8
Phil
Default
I still wonder just how much more discs cost over drums. Assuming a full conversion (so economies of scale carry over), I doubt it is over $100, if that. An amount I would gladly pay to have rear discs. It would also be a nice point to use when making a sale.
Phil is offline
Old 03-13-2003, 09:45 PM   #9
Saturnmeister
Saturnmeister is on a distinguished road
Saturnmeister's Avatar
Default
Disc brakes are inherently better because as they wear, the pads and rotors may get thinner, but the entire pad surface remains in contact with the disc when braking; with drums, the circumference of the drums increases, and that of the brake shoes decreases as they wear, so as they wear, you have a smaller portion of the brake shoe in contact with the drum. In addition, the drums wear out of round, so your brake shoe contact is intermittent in force as the shoe rides from "high spots" on the drum to "low spots" on the drum. In addition, drum brake "automatic adjusting" features are prone to malfunction; disc brakes are self adjusting by design and require no mechanical adjustment mechanism.
Basically, drum brakes are something that should be a conversation piece in an automotive museum by now, but because the rear wheels don't bear a lot of the braking load auto manufacturers continue to use them to lower costs by a few bucks per car. It's amazing to me how they'll sink god knows how much into side curtain airbags, airbags that pop out of seat cushions, etc and then give you brakes that should have seen their last new car installations a decade or two ago. If you compare the cost of the Saturn ABS option from the model years where ABS included 4 wheel discs to those where you get front disc/rear drum with ABS, the difference is about $200. That's what they charge you, not what it costs them, so you can bet the actual cost per unit is even less. Plus, if they standardized the rear brakes as discs, they could reduce the cost even further. Over a 5 year car loan, you're talking about $3.33 plus interest per car payment. Who wouldn't pay that for better brakes when people are so bombarded with and aware of vehicle safety information?! What's $200 on a vehicle you're paying tens of thousands of dollars to buy?! It's nothing. For those who think you're getting that cost difference as a price cut, as many who defend the use of drum brakes assert, you're kidding yourselves. The price isn't being reduced, they're just decreasing their cost.
Add to Saturnmeister's Reputation
Rate the quality of this post and help Saturnmeister reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturnmeister is offline
Old 03-13-2003, 10:03 PM   #10
wolfman
wolfman's Avatar
Default
I'll add that disks are WAY easier to service , have far fewer moving parts, and are essentially "self cleaning"...
Add to wolfman's Reputation
wolfman is offline
Old 03-14-2003, 12:47 PM   #11
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Disc vs. Drum Brakes
discs dissipate heat better. you have the pads and spinning disc exposed to the air for better cooling. shoes inside a drum cannot cool off as well and will fade faster. discs are easier to inspect and service since you only need a mirror and a flashlight or simply crank the wheel and peek to see how much pad is left and you can measure the rotor thickness without taking anything apart. drums need to come off before you can look inside to measure and/or replace linings. replacing disc pads on a saturn is an easy remove one or two bolts and flip or remove the caliper job. replacing saturn rear drum linings involve springs and things. i did rear discos on my old 92 sc and now 96 sc2 both w/o abs.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 03-14-2003, 04:49 PM   #12
Qlara
Qlara's Avatar
Default
Will drums last longer between replacement, esp on the rear?
Qlara is offline
Old 03-14-2003, 05:35 PM   #13
eRic 02sc2
eRic 02sc2's Avatar
Default
dunno. my drums lasted until i had the time and $ for the rear disco then the drums went promptly into the trash can. i've never needed to replace rear lining on my old 92 sc or 96 sc2 drum (pre-disco) in the time that i'd burned through 3 or 4 sets of front pads, if that's what you mean.
eRic 02sc2
Old 03-14-2003, 10:25 PM   #14
Disc brakes provide more consistant braking as the brakes heat up or go past heat up into way to hot. Disc brakes have everything in a sandwhich between the calipers, as everything gets hots it all expands into the calipers. Drum brakes have the drum around the brake shoes. As the drums get hot they expand away from the brake shoes, the shoes will expand out as well but not as much as the heat goes into the metal drum more than the shoe material and metal part of the shoe. The drum moves away from the shoes and now you use much more of the brake pedal travel to push the shoes out to the drums before any of that movement can tranlate into braking. Also in most/many/all systems the hydralic preesure in the system has to hit a point before the valving in the system will allow pressure to the front discs. The system won't get this pressure point until the rear shoes are out against the drums. Four wheel disc you don't have this problem.
Add to ssicarman's Reputation
ssicarman is offline
Old 03-18-2003, 04:47 PM   #15
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
Default
Disc are cheaper then drums. The reason they are offered as options is that they know people will pay for the cheaper brakes; and they will ma
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline
Old 03-18-2003, 04:47 PM   #16
cloud819
cloud819's Avatar
Default
Disc are cheaper then drums. The reason they are offered as options is that they know people will pay for the cheaper brakes; and they will make more money. It doesn't make sense that they dropped disc from the S series.
They parts and labor needed to install disc brakes is quite a bit less then discs.
cloud819 is offline
Old 03-18-2003, 06:15 PM   #17
eRic 02sc2
eRic 02sc2's Avatar
Default
Originally posted by Qlara
Ha!
in other words saturn corp are cheapskates. drum brakes stink, firestone tires stink more. saturn could have commonized the rear discs instead of dropping them and drop the rear drums instead. they could have saved money on the ion by carrying over the s-series in-front-of-the-driver-where-it-belongs ip instead of developing that center mounted eyestrain.
eRic 02sc2
Old 03-18-2003, 11:24 PM   #18
McSaturn
McSaturn is on a distinguished road
Default
On the lighter side of the subject...
If you are anal about keeping you car as clean as possible ( I resemble that remark) you will be partial to drum brakes as the rear rims are always so much easier to clean and stay that way longer.
Add to McSaturn's Reputation
Rate the quality of this post and help McSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
McSaturn is offline
Old 03-19-2003, 06:18 AM   #19
muzikmann
muzikmann is on a distinguished road
muzikmann's Avatar
Location: Golden, CO - Senior @ Colorado School of Mines
1993 SL1
Default
Try these sites:
http://auto.howstuffworks.com/brake.htm
http://auto.howstuffworks.com/drum-brake.htm
http://auto.howstuffworks.com/disc-brake.htm
Jeff
Jeff Parham
1993 SL1 - R.I.P. @ 198,000 Miles
2000 Audi A4 1.8T Quattro
Add to muzikmann's Reputation
Rate the quality of this post and help muzikmann reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
muzikmann is offline
Old 03-19-2003, 04:23 PM   #20
100KSW2
100KSW2 is on a distinguished road
100KSW2's Avatar
Thumbs Down
This question of disc vs. drum brakes is very important to me. My whole family was almost killed by drum brakes when I was a kid and I don't want them on any car I drive.
I was ready to order a new SW2 in 1996 but cancelled my plans when I found out the rear disc option was gone from the S series wagons. I like the brakes (and ABS and Traction Control) on my wagon a lot. On long trips or in huge traffic jams or in rotten weather I want their maximum stopping power. Like Jeff said, +5 feet can be all the difference (and I have had a number of close calls that were just that close). If drum brakes were "just as good" then every luxury car maker in the world would be using them and not discs on all corners.
Carmakers agonize over saving nickels and dimes, so +$100 IS a LOT. Saturn isn't the only one deleting the rear discs, but Saturn is supposed to be different. I plan to hold onto my car for as long as it is repairable - or until things change on the rear disc issue. I have made this clear to sales and service and the CAC, but so far I don't see any hope of change. The only (new) Saturn available with 4-wheel disc brakes right now is the Lx300 sedan and wagon, and I don't want the steel 1/4 panels, high maintenance engine, lesser gas mileage, and questionable quality of those models.
It will be interesting to see what kind of brakes show up on the rear of the 200HP+ ION Turbo Quadcoupe.
I think in 2003 we should all be talking about why there is no stability control available on any Saturn (even though it has been available on the Focus for a couple years). The rear disc issue should have been settled years ago. The parts were already there, the development money spent, etc.
Add to 100KSW2's Reputation
Rate the quality of this post and help 100KSW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
100KSW2 is offline
Drum Brakes or Disc?? Jarryn S-Series Tech 13 09-28-2006 05:01 PM
Drum to Disc conversion Pyrate Ion Mods 30 01-26-2006 03:32 PM
converting from rear drum to disc brakes tonyb S-Series Tech 1 03-21-2003 10:16 PM
ION Rear Brakes - will it be disc or drum? VTHokie00SL2 Ion General 30 03-17-2002 03:16 PM
drum to disc evilSL1 S-Series Mods 2 03-28-2001 05:11 PM
