Old 09-01-2011, 12:12 AM   #1
tallman54
tallman54 has a spectacular aura abouttallman54 has a spectacular aura about
Default Horn replacement ...need advice, thanks
Our horn on the '00 L-1 is dead. Bought a 2 connector replacement (what was on the shelf - Wolo "Loud-One) at AutoZone
figuring I just need to snip the 2 wires on the car and connect to the leads on the new one. Then I was told there was a post somewhere on the 'net saying this isn't quite so easy and that the 2 wires on the car aren't the standard pos and neg leads, one is the pos for the horn and the other is a pos also - it passes through the connector somehow and goes to something to do with the air bags. The person who told me this isn't sure where he read it at and isn't certain now that it applies to an older L series. Ughh. Before I go snipping wires, can anyone tell me if this is true or not ? Search hasn't turned up the answer.
To be clear, I'd like to simply snip the 2 leads that go to the stock horn and attach them to the pos and neg terminals of the new one (much like hooking up a standard speaker). Is this correct ?
Thanks !
Add to tallman54's Reputation
Rate the quality of this post and help tallman54 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tallman54 is offline   Reply With Quote
Old 09-12-2011, 12:36 PM   #2
tallman54
Default Re: Horn replacement ...need advice, thanks
Replaced the horn yesterday, no problems. The only point I would add is that if you peel back the outer black water proofing 'tape' (?) carefully, you won't need shrink tubing as it stretches right back down the wire easily. I snipped the wires at the connector, stripped the end bare, crimped on the new connectors, bolted the assembly back in and that was that.
*I should add that the advice for how to go about 'testing' to see if there was power at the horn by using 2 sections of paper clip - one pushed into the end of the + and - on the clip and then clamping the probes to the paper clips, worked out well also. Much easier than trying to hold the tips of the probes in the tip of the horn wiring end/clip itself (holes are too small for a standard tester probe).
Thanks again to those who responded for my call for help. Its such as simple job once you are sure whats what.
Old 09-12-2011, 12:42 PM   #3
tallman54
For members advice for the above see:
"Re-stated:Are the 2 wires that..."
I posted originally on 09/01/11.
Old 09-26-2011, 10:52 AM   #4
Tercero
Tercero is on a distinguished road
Tercero's Avatar
1997 SL1
Hi Tallman.
I have a '97 Saturn Sl-1. My horn stopped working in the spring, and the airbag light is on. The clockspring is good and I'm guessing the horn is dead. Did you have to remove the light to replace this?
J
Add to Tercero's Reputation
Rate the quality of this post and help Tercero reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tercero is offline   Reply With Quote
Old 09-26-2011, 05:47 PM   #5
Tercero
Tercero's Avatar
1997 SL1
Never mind. I pulled the light, got a replacement from the autowreckers,....and it's still the same. It's probably the clock spring. Screw it. Time to get a steering wheel puller and yank this puppy.
Old 09-29-2011, 07:38 AM   #6
tallman54
Sorry I didn't see your question sooner. I pulled the plug/connector from the horn, stuck 2 halves of a paper clip into the 2 slots in the plug and used needle nose to wrap other end of paper clips around the probes of my multimeter, set it to test for continuity and had my son 'beep' the horn at the steering wheel. I got a 'beep' on the mutlimeter which indicated (full continuity) and so it was the horn that had failed and not the wiring/circuitry. I bought a generic horn from Auto Zone, swapped it out and everything works fine. Had the problem been any more complicated then this, well, I'm afraid I would have been lost.
Horn Replacement OEM or ??? Growser S-Series General 20 11-28-2009 09:27 PM
Horn replacement Brad_bb S-Series Mods 26 05-03-2009 11:34 PM
98 Saturn Horn replacement mariopalumbo S-Series Tech 9 05-08-2007 04:29 PM
1997 sc2 horn replacement dsdSC97 S-Series General 8 04-03-2004 08:10 AM
'96 SL2 horn replacement? alacrity024 S-Series General 10 12-18-2003 12:07 AM
