Old 08-30-2011, 07:13 PM   #1
RobertGary1
Default Plastic valve cover bolts arer bolts are different size than aluminum cover bolts
I think I've found this out the hard way. I've been struggling with valve cover leaks. When I bought my aluminum cover it did not come with bolts so I've been using the plastic cover bolts. Today I took off work to try to get caught up with all the work my SC2 needs (thankfully new stuff started to break as I drove so there is still stuff). I went out to PnP and took some bolts off an aluminum cover. Looking at them closely the collar on the plastic bolt is much longer than the collar on the aluminum head bolt. Its long enough that I suspect it was bottoming out before max squeeze was achieved on the gasket. I've got my fingers triple crossed that I won't guzzle oil tomorrow.
-Robert
Old 08-30-2011, 07:59 PM   #2
Default Re: Plastic valve cover bolts arer bolts are different size than aluminum cover bolts
Yes, the plastic shoulder bolt assembly is different than the aluminum cover bolt. I thought that was mentioned in the cover conversion thread.
Old 08-30-2011, 08:02 PM   #3
2NDSOUT
2NDSOUT's Avatar
1999 SL
The Aluminum Cover bolts are Torx Head bolts while 2nd/3rd gen cam cover bolts are standard 10MM bolts.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 08-30-2011, 08:23 PM   #4
RobertGary1
Default
Yea, that part was obvious. What was not obvious was that the difference effects the bolt's performance. BTW someone is going to go to PnP and wonder who the AHole was the took the bolts but left the cover.
Old 08-30-2011, 08:58 PM   #5
Those bolts are expensive so they go fast. And they are a different height than the plastic cover ones.
Old 08-30-2011, 09:17 PM   #6
RobertGary1
Default
I actually called the dealer to ask about price but 95 showed 2 styles for aluminum covers (or so the parts guy claimed). Honestly the PnP is less than 10 miles but my days are so booked that I try to avoid them simply because of the time required.
Old 08-30-2011, 09:36 PM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
The parts guy is wrong. 1994 had two different styles.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 08-30-2011, 09:45 PM   #8
RobertGary1
At PnP they were $1.35 each. It was 99c plus tax and environmental fee.
Old 08-30-2011, 09:52 PM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
They actually charged you for them? At the PnP's around here, you show them the bolts, they look at you and point towards the exit.
Mike
-2000 Saturn SC2
DOHC valve cover bolts (aluminum cover) VUEmaniac S-Series Tech 3 02-08-2011 10:54 AM
Needed: valve cover bolts! joshuh S-Series Tech 4 05-10-2010 08:05 PM
Valve Cover Bolts gregaroo329 S-Series Tech 1 12-04-2007 06:43 PM
3 or 4 bolts near spark plug holes on DOHC aluminum valve cover David 93 SL2m S-Series General 2 04-01-2006 05:44 PM
valve cover top bolts leak... LI 350 Miscellaneous Tech 2 08-05-2001 01:13 AM
