Old 08-29-2011, 07:49 PM   #1
Really??
Really?? is on a distinguished road
2008 VUE 2.4L
Sad 2008 Vue 2.4L Thermostat Error Code
Hey all!
My 2008 Saturn vue has given me an error code that says the thermostat is not closing. Do I need to replace the part or can it be fixed? If it needs to be replaced is this something I can do myself.
Thanks!
Add to Really??'s Reputation
Rate the quality of this post and help Really?? reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Really?? is offline   Reply With Quote
Old 08-30-2011, 01:02 AM   #2
Default Re: 2008 Vue 2.4L Thermostat Error Code
Not closing suggests the t-stat is running the engine cooler than normal. Other than posting the code so its clear what the error is and not misinterpreted, t-stats aren't adjustable - just replaced. If its accessible, mounted on the engine block t-stat housing that feeds hot coolant to the radiator, then it should be easily replaced with hand tools. Draining the coolant and possibly replacing it might be worth it if its time for coolant replacement too.
Old 08-30-2011, 07:06 AM   #3
far2grumpy
far2grumpy's Avatar
Originally Posted by Really?? View Post
Hey all!
Thanks!
I've posted service manual extract to replace 2.4 cooling thermostat.
The task appears to be in DIY category ... repost if you decide to proceed and would like to see the prerequisite files (coolant drain & fill and battery tray remove).
Old 08-31-2011, 11:39 AM   #4
Really??
2008 VUE 2.4L
Thank you for posting the service manual. It looks easy enough if I had enough resources available to me. I will call a friend with more tools than I for help. If he can help then I will ask for the other service manuals. Thank you!
Old 01-22-2014, 05:03 PM   #5
Rrrs1975
Rrrs1975 is on a distinguished road
Can you give me the manual to drain the coolant please? The link on the other post will not allow me to pull it up. Thank you in advance!
Add to Rrrs1975's Reputation
Rate the quality of this post and help Rrrs1975 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rrrs1975 is offline   Reply With Quote
Error Code PO 442 slv01sc2 S-Series General 29 08-24-2013 06:31 PM
error 45 code just set, now what? :) hiii98 S-Series Tech 10 09-07-2008 10:00 PM
Error code Scottb Ion Tech 3 10-04-2007 06:31 AM
Error Code 442 jmmccutc S-Series Tech 3 10-19-2006 01:56 AM
Error code 26? What does it mean? HELP SyNNeR Miscellaneous Tech 1 05-21-2002 07:24 PM
