Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 08-28-2011, 08:33 PM   #1
zeissheadreggie
zeissheadreggie is on a distinguished road
Location: East point, GA(3 clicks outside of the atlanta city limits)
2005 VUE Red Line
2000 L-Series 3.0L Sedan
Default What causes a catalytic converter to go bad?
Hey everybody! I'm assuming that position(bent over and ankle grabbing) $1679.00 to replace the cat converter.(bank1, left). Did this at Midas Muffler for $804.00 a few years ago, so you can guess that I'm not a happy camper! I've switched from 87 octane to 93 octane, kept this vehicle tuned up, and the vehicle fails the annual emission test here in the People's Republic of Fulton Co. Ga. Several people I know are also having this expensive and unpleasant experience. Is it this ethanol crap or a history of cheap premium fuel? Angry and broke!!!
Add to zeissheadreggie's Reputation
Rate the quality of this post and help zeissheadreggie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zeissheadreggie is offline   Reply With Quote
Old 08-28-2011, 08:54 PM   #2
HerBabyTruck
HerBabyTruck is on a distinguished road
HerBabyTruck's Avatar
2005 VUE Red Line
Default Re: What causes a catalytic converter to go bad?
If your vehicle requires regular, the changing to a higher octane will do nothing, other than lighten your wallet. I've only had 1 go bad and that was caused by the inner wall of the head pipe collapsing due to corrosion and plugging it up. It was covered by the 8 yr. 80,000 warranty on emission equipt. From what I've found the ethanol does not cause a problem with them. Some parts store fuel additives are bad for converters as is excessive heat and excess fuel going out the exhaust. So if your vehicle is running rich (bad injectors, bad O2 sensor, etc.) that would be damaging to the converter. Maybe your emission station has a deal with the repair shop to say your converter is bad and doesn't pass so they make money replacing good parts??? The only other thing would be physical damage from hitting something, that could cause the catylist material to break up and plug it. If you haven't tried, do a Google search and see what comes up. Good luck
HerBigTruck = SILVERADO HD K2500 8.1 Allison
Add to HerBabyTruck's Reputation
Rate the quality of this post and help HerBabyTruck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HerBabyTruck is offline   Reply With Quote
Old 08-28-2011, 09:18 PM   #3
XRL
XRL's Avatar
2004 VUE Red Line
I'm sure the ethanol isn't good for them (it's pretty much bad for every part on the car it touches).
That seems like a lot to change the cat converters, and very strange to have them fail. Especially seeing as there's 4 of them. 2 in the exhaust manifold, and 2 in the J pipes.
I'd wager to say there's something fishy going on.
Add to XRL's Reputation
Old 08-28-2011, 09:53 PM   #4
zeissheadreggie
2005 VUE Red Line
Default
As for the price, I'm told the front everything from the front of the system has to be replaced. Midas muffler appears to either improperly install this thing wrong, or not replace the O2 sensor, but it's all got to be replaced! If I feel like I'm getting screwed, it's a very good chance that I am getting screwed....
Catalytic converter The Student S-Series Tech 6 02-07-2009 01:55 PM
catalytic converter packer_rich Vue Red Line 1 12-21-2008 07:09 PM
catalytic converter RichSoucie Ion General 1 07-01-2005 04:54 PM
Catalytic converter? KJB Vue General 5 07-14-2004 12:18 PM
Catalytic Converter Evil_Oppie Ion General 6 07-14-2004 12:40 AM
