Old 08-13-2011, 09:22 AM   #1
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Default WARNING - Engine Cradle Corrosion
I have a problem with corrosion at the right front corner of the engine cradle/front subframe on both of my 2000 L-Series cars. The wagon has perforation in the bottom surface just behind the body mount and deterioration of the body mount. The sedan has corroded about 1/2 to 2/3 of the way through the ~2mm thickness of the metal in exactly the same spot. Inspection shows that the corrosion is from the outside. The cause appears to be from the plastic shroud that is fastened to the underside of the cradle around the frame mounting. This can hold dirt, leaves, slush/salt, etc. against the subframe. The remainder of the cradle has some rusty spots near where the brackets are welded on, but these are all just on the surface, no penetration.
Saturn says these cannot be repaired and must be replaced by a new factory part. I have located and purchased a good used engine cradle that I intend to install in the wagon. BTW, on www.saturnparts.net the cradle for the automatic is listed as "discontinued". My Saturn dealer (yes, still open and doing service), confirms this. The cradle for the manual and automatic TX models are listed as different parts, with the manual being available for ~US$800 at saturnparts.net. My dealer would want ~C$1500 for the cradle if it were available. Such is the pricing of auto parts in Canada, hello internet.
I recommend that all L-Series owners remove the shroud from the right front wheel well that covers the bottom part of the engine accessory drive belts and inspect the engine cradle/subframe for corrosion. DO NOT reinstall the cover, as this is what causes the corrosive environment.
I also approached one of my regular repair shops about this. They offered to obtain a "reconditioned" cradle. I assume that this is a used one, weld repaired, sandblasted and painted. This would come with a warranty.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-15-2011, 02:05 PM   #2
KLS1P
KLS1P is on a distinguished road
2004 L-Series 3.0L Sedan
Default Re: WARNING - Engine Cradle Corrosion
Good info. Can you post some pictures?
Add to KLS1P's Reputation
Rate the quality of this post and help KLS1P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KLS1P is offline   Reply With Quote
Old 08-20-2011, 08:57 PM   #3
born again
So I cleaned up the used subframe I found and purchased. Unfortunately, it isn't much better than the one I need to replace. I also had a crawl under my '99 Saab 9-5 Wagon, which has an almost identical frame. It is relatively spotless. This could be from the oil that leaks from the oil cooler or it could be different steel. See the pix. I need to get it patched/welded.
Old 08-21-2011, 05:54 AM   #4
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
2001 L-Series 2.2L Sedan
ouch, a good shop can do a decent reinforcement if they want the money and have the time. I'm glad I ripped that plastic off when I got the car. make sure the replacement isn't tweaked from being weakened.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Add to Robman's Reputation
Rate the quality of this post and help Robman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robman is offline   Reply With Quote
Old 08-21-2011, 03:06 PM   #5
Jonnyferrari
Jonnyferrari is on a distinguished road
Jonnyferrari's Avatar
2000 L-Series 3.0L Sedan
I definetley have similar corrosion, possibly worse. Is it that dangerous just to leave it?
[Sold] 2000 Saturn LS2 premium package; 120k
Add to Jonnyferrari's Reputation
Rate the quality of this post and help Jonnyferrari reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonnyferrari is offline   Reply With Quote
Old 08-22-2011, 10:20 AM   #6
Robman
Robman's Avatar
YES! that will weaken the sub frame and your front end will go to shhhht.
Rob
2001 Turbo L200
1997 F150 XLT
Do It Yourself
Old 08-22-2011, 09:22 PM   #7
Jonnyferrari
That could explain some of the noises...lol. Well I can't afford to fix my car and since I am not on welfare, and don't want to become a leach, I guess I'll drive it till it dies.
Old 08-23-2011, 02:11 PM   #8
Harry
Harry is on a distinguished road
Harry's Avatar
2001 L-Series 2.2L Wagon
Bloody hell! Our 2001 LW200 just started making weird noises and the steering went wonky and the flippin' cradle is rusted out. As you say, there aren't any around. I thought GM was supposed to support their ended car lines for a while as part of their gov't rescues...
With it being such a systemic problem GM should pay for it. The dealer has offered us $300 to buy the plastic panels off it! Or I can take it to a place where a guy can try to custom weld something, not guaranteed, over $1000.
Such a great car for over 10 years, now suddenly it is dead. They can't even find a good one at a wrecker. Every one they check has the same systemic problem.
Anything that can be done???
Add to Harry's Reputation
Rate the quality of this post and help Harry reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Harry is offline   Reply With Quote
Old 08-24-2011, 10:45 AM   #9
Robman
Robman's Avatar
start looking at cars from the South.
Rob
2001 Turbo L200
1997 F150 XLT
Do It Yourself
Old 08-30-2011, 07:49 PM   #10
Harry
Harry's Avatar
GM was no help but the welding shop that the local Chevy dealer recommended says he can fix it so I told him to go away. He's going to remove all the rust, fix the engine cradle and the exhaust, give it an undercoating. Hopefully it lasts a few years at least... will keep everyone posted on how it goes.
Old 09-03-2011, 08:04 PM   #11
Harry
Harry's Avatar
Frank Dube welding in Kitchener did a great job! Good to have the LW200 on the road again, hopefully for a long time. 519-589-6637 if anyone else needs their cradle welded.
Old 09-03-2011, 10:19 PM   #12
Frostman
Frostman will become famous soon enoughFrostman will become famous soon enough
2002 L-Series 2.2L Wagon
1993 SL1
Thanks for posting, will have to investigate mine and see how it looks. Didn't see anything bad when I bought it last year.
Add to Frostman's Reputation
Rate the quality of this post and help Frostman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Frostman is offline   Reply With Quote
Old 11-12-2011, 01:58 AM   #13
Corvettemustang
Corvettemustang is on a distinguished road
I just had my subframe rust out also. It seems that everyone who has their subframe rust through has it rust in the same area on the passenger side. My mechanic was able to find a nice used subframe in Wisconsin. It cost me about $1000 for all the work.
Add to Corvettemustang's Reputation
Rate the quality of this post and help Corvettemustang reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Corvettemustang is offline   Reply With Quote
Old 04-02-2012, 10:30 PM   #14
rcockrum
rcockrum will become famous soon enough
I have access to a completely rust free sub-frame out of a 2000 with a 3.0 auto. Not sure where this car came from, but it is in pristine condition. Kind of out of the ordinary for this part of the country (South Dakota). Let me know.
Add to rcockrum's Reputation
Rate the quality of this post and help rcockrum reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rcockrum is offline   Reply With Quote
Old 04-04-2012, 07:13 PM   #15
MikeNW
MikeNW's Avatar
1997 SL
I have made many trips to Pull A Part in Mobile AL, there are usually several S-series there (I snagged an S- series subframe already) but have seen only one L-car on the lot. I wish I could figure out a cost-effective way to harvest southern car parts and transport them to the north.
08 Burgman 400
Add to MikeNW's Reputation
Old 06-19-2012, 11:23 PM   #16
DaveJohnson
DaveJohnson is on a distinguished road
1997 SL1
I have a 1997 Saturn SL1 sedan 1.9L. 105,000 miles
Just discovered out that the cradle (mounting bracket that holds the control arm) busted while I was on the road. I limped it home and took a good look at it. I attached a picture, but you can see where the bracket (part of the cradle) is busted, which caused my front driver side tire to go at an angle.
"WARNING - Engine Cradle Corrosion" can't be more right on. If you want or own a Saturn, that's a "must check" before you buy. I had mine for only 7 months and luckly only paid $1,000 for it.
Also the Crank Position Sensor went out while at work and a day off of work and several trips to the parts store got that up and running again.
Sold my car to the scrap yard.
Good luck all you Saturn owners.
Add to DaveJohnson's Reputation
Rate the quality of this post and help DaveJohnson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DaveJohnson is offline   Reply With Quote
Old 01-01-2013, 08:57 PM   #17
Jonnyferrari
So my frame is worse than this. I don't know how to put this other than: Should I be worried?
Engine Cradle Sisko690 S-Series Tech 13 11-01-2012 06:11 PM
engine cradle SL2LOVER S-Series General 1 08-03-2010 06:25 PM
Engine cradle harley2003 S-Series General 3 03-14-2010 11:12 PM
92 SL2 Engine cradle help! mile2885 S-Series Tech 5 02-02-2007 05:31 PM
Engine Cradle Qlara Miscellaneous Tech 6 08-13-2004 08:13 PM
