Old 08-12-2011, 02:27 PM   #1
Thresher
Thresher is on a distinguished road
Default 2002 SL2 high idle
I have a 2002 SL2 with a high idle warm or cold (1400 - 1700 RPMs). Initially I had a code 301 (cyl 1 misfire) and a 507 (high idle). I have changed plugs, wires, PCV, new ignition module, and cleaned the throttle body and IAC so you could drink fine wine from them. Lastly I swapped the coils and the code 301 disappeared (crazy, huh?). The 507 hangs around like a bad house guest. From previous threads I was informed to look for a vacuum leak around the intake manifold, but found nothing. Does anyone have a guess or should I move to a new state that does not require an emissions test?
Thanks.
Add to Thresher's Reputation
Rate the quality of this post and help Thresher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thresher is offline   Reply With Quote
Old 09-22-2011, 12:04 PM   #2
chad53916
chad53916 is on a distinguished road
2002 SL
Default Re: 2002 SL2 high idle
Did you take some brake cleaner (with the little red tube) and douse the area around the intake manifold on the passenger side of the motor? I've got a 2002 SL that had the folded gasket, high idle and code for misfire. When I sprayed, the engine stumbled a bit. Good luck!
Add to chad53916's Reputation
Rate the quality of this post and help chad53916 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chad53916 is offline   Reply With Quote
Old 09-22-2011, 12:13 PM   #3
Greg1
Greg1 is on a distinguished road
Greg1's Avatar
1997 SW2
The folded gasket problem is usually associated with the SOHC engines.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-23-2011, 10:52 AM   #4
matthew810
matthew810 is on a distinguished road
2007 ION-2 Quad Coupe
I am certainly not an expert but I had high idle problems which caused overheating in traffic in my 98 SL2 and it all ended up tracing to bad oxygen sensors. I think it was just the one by the cat converter but I replaced both. Solved my problem. Maybe yours is the same.
Add to matthew810's Reputation
Rate the quality of this post and help matthew810 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
matthew810 is offline   Reply With Quote
High Idle Speed 2002 SL1 journeyman615 S-Series Tech 9 10-20-2014 02:20 PM
SL1 2002 High Idle w/ SES codes SL1Queen S-Series Tech 1 06-12-2011 10:36 PM
2002 SC2 High Idle problem danhammer S-Series General 5 03-01-2011 09:43 PM
2002 SL2 High Idle banditkaine S-Series Tech 12 03-13-2008 05:25 PM
2002 AWD V6 high rev at idle Uzzi Vue Tech 13 03-28-2006 07:08 PM
