Old 08-14-2011, 05:06 PM   #21
Default Re: My Saturn SL2 engine build & modification pictures
99-02 TTY rod bolt 21008005. GM parts direct is the cheapest at 1.21 ea in a pack of 8 for 9.68 + shipping.
Saturn OEM Parts Source
GM Parts Giant- http://www.gmpartsgiant.com/
GM Parts Direct- http://www.gmpartsdirect.com/
Get Saturn Parts- http://www.trademotion.com/splash/in...?siteid=214643
Your local dealers - http://www.partsvoice.com/
33ft-lb is the torque spec for the 91-98 rod nut. I would expect that 30->32ft-lb would be more than adequate for a recycled rod bolt. With the inherent inaccuracy of almost all prosumer torque wrenches I would stay away from the TTY spec as if you overshoot failure is highly probable. Not a disaster if the failure is immediate but a delayed failure is a mess.
Old 08-15-2011, 05:31 PM   #22
1998saturnsl2
1998saturnsl2 is on a distinguished road
1998saturnsl2's Avatar
I really appreciate you helping me with the bolts. I buttoned everything up under the hood today & was successful in firing up the fresh motor. She kicked over in about 2 cranks.
Runs pretty dang good, just gotta let the computer re-learn everything.
File Type: jpg 286215_10150343533472790_566017789_9617255_2883024_o.jpg (87.1 KB, 46 views)
Eh...don't worry about it...It's a saturn :]
Add to 1998saturnsl2's Reputation
Rate the quality of this post and help 1998saturnsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1998saturnsl2 is offline   Reply With Quote
Old 05-10-2012, 06:33 PM   #23
1998saturnsl2
I am planning to do a couple modifications over the summer, including widening the throttle body and intake manifold, lightened flywheel, headers, and ignition stuff. I might even throw in some flat faced valves to up the compression a "little tincy" bit. Keep in touch yall!
Old 05-10-2012, 11:46 PM   #24
td1238
I like it except the white over the Saturn emblem. I like the shiny aluminum with red Saturn badge better. Looks great otherwise, though. How is the engine paint holding out? All of the stuff I have used stated all of this high-temp ceramic crap, and after a few years started flaking off. Other than powder coating, I'd like to try epoxy paint. That stuff holds tight to appliances. Not sure how it'd handle engine heat.
The pre-cat heats faster than the main cat, being closer to the engine. It minimizes emissions when the car is first started. OldNuc likes to think that it heats the O2 sensor faster, but it's not there for that purpose. That's what the heater is for. My O2 sensors heat in a matter of a few seconds, and the front one doesn't have a heater. When I had a heated one installed, though, it went into closed loop almost instantly, and my car doesn't have a pre-cat. Read anywhere else, and you'll find that they're for start-up emissions, not O2 sensor heaters. LOL!
Add to td1238's Reputation
Engine Build dcc81187 S-Series Mods 5 10-04-2010 01:20 PM
Pictures of my latest build (I'm bored) Tycho Mods and Performance 11 09-26-2004 08:26 PM
Easy modification... unapproved by Saturn hunterj792 Vue General 19 05-06-2004 08:18 PM
Saturn Vue intake Sensor Modification Orest Vue General 1 05-29-2003 05:11 PM
engine build lumpyguy Mods and Performance 3 02-05-2003 06:52 PM
