Old 08-11-2011, 02:04 AM   #1
mmore57
mmore57 is on a distinguished road
Default 2001 SL2 Main Bearing Torque?
The Haynes Manual lists the torque for the
main bearing caps as 37 ft/lbs all except for the
No. 3 bearing cap which is listed at 10-12 ft/lbs.
Does anyone know if this is correct, or should all of
the main bearing caps be torqued to 37 ft/lbs?
Add to mmore57's Reputation
Rate the quality of this post and help mmore57 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mmore57 is offline   Reply With Quote
Old 08-11-2011, 09:00 PM   #2
off-track
off-track's Avatar
Default Re: 2001 SL2 Main Bearing Torque?
My GM SI says:
Using a rubber mallet, rap the crankshaft rearward, then forward in the cylinder block to align the thrust bearing.
Apply a light coat of engine oil on the threads and under the heads of the cap bolts.
Install and uniformly tighten the 10 cap bolts in several passes, in the sequence shown. Tighten
INTAKE
8 1 4 5 9
7 3 2 6 10
EXHAUST
Tighten the Crankshaft Bearing Cap-to-Block 50 N·m (37 lbs ft).
Check that the crankshaft turns smoothly.
Check the crankshaft thrust clearance.
Thrust Clearance
Standard: 0.05-0.2 mm (0.002-0.0089 in)
Service Limit: 0.25 mm (0.0098 in) If the clearance is greater than maximum, replace the thrust bearing
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 08-12-2011, 12:57 AM   #3
satlite440
2001 SL2
+2
Service Information
2001 Saturn SL2/SC2/SW2 | SL, SL1, SC1, SW1, SL2, SC2, SW2 VIN Z Service Manual | Engine | Engine Mechanical - 1.9L | Repair Instructions | Document ID: 880790
Engine Block Assemble
Tools Required
J 41742 Connecting Rod Guide
J 44057 Crankshaft Tie Plate Socket
SA9142E Piston Ring Compressor
Important:
The engine block requires the location dowel pins for the front cover, cylinder head, rear crankshaft seal carrier, and transaxle be installed with a brass driver. Dowel pins are installed until they bottom out in the cylinder block.
Thoroughly clean all parts to be assembled. Honed cylinders must be scrubbed with a solution of Tide® powdered laundry detergent, or equivalent and high pressure warm water prior to piston assembly. Before installing the parts, apply new engine oil to all sliding and rotating surfaces. Replace all gaskets, O-rings, and oil seals with new parts.
•Dowel pins are installed until they bottom out in the cylinder block.
•Install the dowel pins using a brass driver.
Important: Install the bearings with the oil holes in the block. The bearings with no holes must go in the main bearing caps.
•Install the main bearings.
Install the bearings in the cylinder block and the bearing caps.
Important: Inspect the alignment of the bearing oil hole to the block bulkhead oil feed hole. At least 50 percent of the feed hole must be open/exposed.
•Install the thrust bearing in the number 3 upper main bearing position of the block.
•Place crankshaft in cylinder block and coat with engine oil.
•Install the main bearing caps.
Important: The bearing caps are numbered 1-5 and have an arrow that points toward the front of the engine. No. 1 cap is at the front of the cylinder block.
•Install the bearing caps in their proper locations. The arrow on the bearing cap points toward front of the cylinder block.
Important: Use a rubber mallet and rap the crankshaft rearward, and forward in the cylinder block to ensure the thrust bearing is properly aligned.
•Using a rubber mallet, rap the crankshaft rearward, then forward in the cylinder block to align the thrust bearing.
•Apply a light coat of engine oil on the threads and under the heads of the cap bolts.
•Install and uniformly tighten the 10 cap bolts in several passes, in the sequence shown.
Tighten
•Check that the crankshaft turns smoothly.
•Check the crankshaft thrust clearance.
Thrust Clearance
Old 08-12-2011, 12:59 AM   #4
satlite440
2001 SL2
here is the pic
Main & Rod Bearing replacement? acamato S-Series Tech 24 08-03-2014 04:58 PM
Main & rod bearing photos at 200k+ miles MINICooperS S-Series Tech 3 05-24-2008 10:30 PM
torque specs for cam main caps 94503 S-Series Tech 3 02-20-2008 03:01 AM
Is it possible - Main shaft bearing kickarse S-Series Tech 5 04-23-2005 12:36 AM
02 sc1 main bearing SKILLITER S-Series General 29 02-20-2005 09:53 PM
