Old 08-09-2011, 09:35 PM   #1
savior27
savior27 is on a distinguished road
Default My 02 sl2 with vue cluster
Hey guys. I have been lurking here for awhile and wanted to show you some ideas I used from different members.
First, I did the blue led mod with the original cluster but it still looked bland to me so I ordered an ebay glow gauge set for a 00 sl2. I installed the glow gauges in the stock cluster which looked nice but the needles were hard to see at night.
After a few days I ordered a cluster for an 04 vue and when it arrived I modded it to my liking...
After removing the Vue's gauge faces and cutting out the parts that needed to go back in the cluster I installed the glow gauge set from the original cluster and wired the controls. I also added a blue led to the odo.
I really like the look of the gauges now, and the illuminated needles really set it off! I would suggest this mod to anyone, I give it a 4 out of 10 on difficulty if your mechanically inclined.
Oh the instructions that came with the glow gauges said to install them over the factory ones but I found that the warning lights looked like crap that way, That is why I removed them and cut out the black areas and reinstalled them.
Add to savior27's Reputation
Rate the quality of this post and help savior27 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
savior27 is offline   Reply With Quote
Old 08-09-2011, 09:59 PM   #2
Redhotftw!
Redhotftw! will become famous soon enough
Default Re: My 02 sl2 with vue cluster
sweet.
i always wondered how the OD would light up with a blue LED.
what size bulb did u use for it?
1998 "Red Hot" Sc2
Add to Redhotftw!'s Reputation
Rate the quality of this post and help Redhotftw! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Redhotftw! is offline   Reply With Quote
Old 08-09-2011, 10:31 PM   #3
savior27
Originally Posted by Redhotftw! View Post
sweet.
I used a B8.5D from superbrightleds.
Old 08-09-2011, 11:15 PM   #4
Redhotftw!
Ok.
so its the same as the lights I used for my cluster.
of course, the od light in mine burned out days after i put my LED cluster back in lol.
did you use one of the 360 degree ones?
1998 "Red Hot" Sc2
Old 08-09-2011, 11:20 PM   #5
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
I've head the B8.4D base fits better, instead of bulbs being loose.
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
Add to simkid5614's Reputation
Rate the quality of this post and help simkid5614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
simkid5614 is offline   Reply With Quote
Old 08-09-2011, 11:24 PM   #6
Redhotftw!
i pulled the bulbs and installed them in the factory saturn base instead of using the base they came in.
1998 "Red Hot" Sc2
Old 08-10-2011, 08:00 PM   #7
savior27
Yeah they did seem a little loose fitting but did work well. It took a minute to figure out the polarity and find the sweet spot that made them light.
I used the standard bulbs not the high power ones.
Old 08-10-2011, 08:06 PM   #8
simkid5614
simkid5614's Avatar
I just don't want them to bounce on our bumpy roads and boop. light out.
Old 08-10-2011, 08:16 PM   #9
Redhotftw!
thats why i used the bases from the factory....
1998 "Red Hot" Sc2
Old 08-10-2011, 08:29 PM   #10
savior27
I thought about using the factory bases but I was afraid that I would damage the led by pulling it out of the base it was in.
Here are a couple of shots with the glows on at night and my Ebay 7 inch touch screen.
Old 08-10-2011, 10:35 PM   #11
Redhotftw!
just be gentle. they come apart way easy compared to the bulbs in the factory ones.
1998 "Red Hot" Sc2
Saturn Ion2 Cluster Swap with Redline cluster chanoir Ion Mods 12 02-19-2014 09:16 PM
Vue Cluster to '02 SL1? homba S-Series Tech 9 10-05-2012 06:32 PM
cluster romeo21 S-Series Mods 10 07-26-2009 01:50 PM
IP Cluster saturncrzy S-Series Tech 8 03-01-2009 02:51 PM
Cluster? LED? Not sure iori276 Ion Tech 6 10-28-2007 11:45 PM
