Old 08-09-2011, 05:29 PM   #1
spike552
spike552 is on a distinguished road
Default TCM reprogram?
ok i have a 2005 saturn ion 2.2L and were pretty sure the TCM is goin, what i need to know is if i purchase a used one from ebay from a chevy cobalt which looks exactly like whats on my saturn, do i have to have some gm certified tech program it, or does the programming only pertain to a new in the box tcm.
Add to spike552's Reputation
Rate the quality of this post and help spike552 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spike552 is offline   Reply With Quote
Old 08-09-2011, 08:56 PM   #2
satlite440
2001 SL2
Default Re: TCM reprogram?
tcm will have to be programmed to your vin bro...tcm's rarely fail unless voltage spiked..why do you think you need a replacement ? do you have codes? do you have ****ing issues with your 4t45E?
Old 08-09-2011, 09:44 PM   #3
2006 ion2
2007 ION-2 Sedan
you need one for an ion, iirc. they have different protocols, even if the TCM model #s are the same. the TCM needs to be programmed to your vin, but dealers will often only program new ones bought through them, so check before buying a used one. I second the question, why do you think it's bad? these transmissions and tcms are typically solid.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 08-09-2011, 10:29 PM   #4
satlite440
2001 SL2
well for the record as a gm trans tec i feel the 4t45e is less than robust at 60k and up the direct cluch or forward cluch piston seals leak or the bushing and scarff seal in the low roller cluch wear.. the 4t65 is better and the 4t80 is the best of the old sidewinders... and once again any codes? also at my dealer we would do a reflash on a straight time only basis.. sometimes used modules don't program of cause other issues that affect other modules and we would make no garuntee of it... and if the underlieing problem is still there it will return as all you have done is replaced the watchdog and not caught the burgler..... gen 3 ecm/pcm/tcm modules are very robust and we have a very low fail rate like less than 3% of a platform/car line in the feild if some shop is telling you this you need another opinion.. run don't walk bro...
Old 08-10-2011, 12:07 AM   #5
spike552
well i jiggle the tcm i get a code, i reset code and jiggle tcm again i get a code, did that bout 8 times lol, and yes the wires and connectors are all intact. The retard portion of this is the fact that i get DTC that arent related to the actually problem. So it doesnt really matter where i get a tcm from cuz it has to programmed by a gm tech, and i will call before buying one thnx.
Old 08-10-2011, 05:25 AM   #6
2006 ion2
2007 ION-2 Sedan
sounds like the TCM, or maybe even the ECM's connector the TCM plugs into. the harness plugs into the TCM, then the TCM plugs into the ECM.
and satlite440, I have to disagree. you may see a high failure rate in a heavier car, or more extreme conditions (mountains), but between the forums ions and cobalts see a relatively low failure rate of the transmission. on ions the CVT is the one to watch out for, otherwise the 4 and 5 speed autos are pretty bulletproof. including the "cluches" and seals.
2007 Saturn Ion 2
Anybody reprogram ecu for better everything via MacG S-Series Tech 4 07-04-2011 10:22 AM
ECM reprogram???? jhsteel82 Astra General 7 07-22-2009 09:07 PM
reprogram o4 key fob gaurdien Vue General 4 11-01-2007 08:41 AM
reprogram fed_up S-Series Tech 10 04-26-2007 06:55 PM
Reprogram BCM TiffsCar Ion Tech 2 02-12-2007 03:50 PM
