Old 08-08-2011, 01:41 PM   #1
steven_1104235
steven_1104235 is on a distinguished road
Default 2002 Vue 3.0 v6 spark plug gapping
I'm planning on putting some new platinum TT spark plugs In tomorrow, I looked in my Haynes manual and the spark plug gap is only listed for the 4 cylinder and 3.5 engines. Does anyone know the correct gapping for a 2002 3.0 engine? Thanks in advance
Add to steven_1104235's Reputation
Rate the quality of this post and help steven_1104235 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
steven_1104235 is offline   Reply With Quote
Old 08-08-2011, 02:55 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2002 Vue 3.0 v6 spark plug gapping
Steven:
See attached FSM extract - you may want to wait on a 3.0 owner to confirm the gap ... seems like a fairly large spread to me.
Old 08-08-2011, 05:05 PM   #3
Originally Posted by far2grumpy View Post
Steven:
Nothing wrong with a plug gap of 0.0035 to 0.043. Set the gap to 0.040 and you are good to go. The underhood emmision sticker should have the plug gap on it as well.
Add to ssicarman's Reputation
Old 08-11-2011, 12:46 AM   #4
Saturn-Naut
Saturn-Naut is on a distinguished road
What plugs would you recommend for a L81 3.0 V6.... I'm a Nissan (NGK) Guy....The v6 had sorry ***** Bosch installed in the engine....Autolite, Ac Delco, denso, NGK or Champion?
Add to Saturn-Naut's Reputation
Rate the quality of this post and help Saturn-Naut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Naut is offline   Reply With Quote
Old 08-11-2011, 03:21 AM   #5
If OEM Bosch came with our 3.0L V6 engine to last 100k miles (mine's currently @67k) and no one's had engine failure with these plugs, why so negative about 'em? Are you driving one?
Old 08-11-2011, 08:43 PM   #6
satlite440
2001 SL2
Service Information
2002 Saturn VUE - FWD | VUE VIN Z Service Manual | Engine | Engine Controls - 3.0L L81 | Specifications | Document ID: 1208733
Ignition System Specifications
Application
Specification
Metric
English
Ignition Type
Coil Over Plug
Firing Order
1-2-3-4-5-6
Spark Plug Type
Refer to Electronic Parts Catalogue
Spark Plug Torque
25 Nm
18 lb ft
Spark Plug Gap
0.9-1.1 mm
0.035-0.043 in
Primary Coil Current Output
7-8 Amps
Properly gapping a spark plug shallow S-Series General 8 09-16-2010 09:15 AM
Spark plug gapping outofak S-Series Tech 8 10-16-2009 08:26 AM
spark plug gapping mjoekingz28 S-Series Tech 11 09-09-2009 08:02 AM
plug gapping Applefool Mods and Performance 6 03-04-2004 12:01 PM
spark plug gapping 92saturnsl2 Miscellaneous Tech 5 08-24-2002 09:13 AM
