Old 07-19-2011, 09:45 AM   #1
gpkarr
gpkarr is on a distinguished road
Default Won't start acts like dead battery
2007 Outlook wouldn't start. Acted like dead battery. Installed new battery. Started fine with new battery. Two days latter after sitting engine turned over real slow caught then died. Loaded on roll back and took to dealer. After one day at shop they could not find anything draining battery. They said it starts fine now. Anyone have similar experience? Did you find anything wrong?
Ocean Mist XR AWD
Grey Leather Premium Seating
Sun Roof Towing Package
Add to gpkarr's Reputation
Rate the quality of this post and help gpkarr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gpkarr is offline   Reply With Quote
Old 07-19-2011, 04:21 PM   #2
lsuduke
lsuduke is on a distinguished road
lsuduke's Avatar
2010 Outlook XE
Default Re: Won't start acts like dead battery
There is a tech bulletin out about the dash turning on if the wrong program is in the computer and kills the battery. There is another issue that the a/c can continue to run , and the dealer can shut that off. Search here and if you don't find anything you can go to www.saturnoutlookforum.net, lots of Lambda (Outlook, Traverse, etc) infor there. Good luck.
Add to lsuduke's Reputation
Rate the quality of this post and help lsuduke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lsuduke is offline   Reply With Quote
Old 08-10-2011, 11:38 PM   #3
Doug C
Doug C's Avatar
2008 Outlook XE
Idea Re: Won't start acts like dead battery
There was a TSB mentioned in a thread awhile back I think this is the one, http://www.saturnfans.com/forums/sho...ain%2C+outlook
A friend of mine who also has a Outlook had a battery problem a couple yrs bk., and his SaturnDealer (still 'roundatthetime) swamped out the battery possibly upgrading something in software too (i think) He has not mentioned any problem since ....
good luck,
doug
Add to Doug C's Reputation
Rate the quality of this post and help Doug C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-16-2011, 08:22 AM   #4
GJG1971
GJG1971 is on a distinguished road
2007 Outlook XE
We had a similar issue with our 2007 Outlook. After several trips to the dealer they finally found the driver door switch was sticking causing the battery to drain. Everything has been fine since they replaced the door switch. Just my .02 worth.
Add to GJG1971's Reputation
Rate the quality of this post and help GJG1971 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GJG1971 is offline   Reply With Quote
2007 Aura XR won't start (sporadic problem, not a dead battery)) TN1 Aura General 15 07-12-2015 07:57 PM
SL1 wont start, acts like no gas Toocool S-Series Tech 27 02-12-2010 09:04 PM
Dead Battery steveluvs3 Aura General 76 02-25-2008 12:27 PM
95 SL2 no start when hot (dead battery symptoms) skijay S-Series Tech 9 10-20-2005 06:43 PM
Vehicle wont start... Is battery dead? marmaduke L-Series General 4 10-17-2005 08:26 PM
