Old 07-13-2011, 10:30 AM   #1
1997 Saturn SC1
1997 Saturn SC1 is on a distinguished road
Default 1997 Saturn SC1 TAAT Transmission
I have a 97 saturn sc1 my problem is it dont shift sometimes when hot slips in 3rd i dont think i even have a 4th i have a sohc engine but once i hit 3rd it slips out of gear and i can unplug one of the 4 connectors from the ecm once i get in 3rd gear and it drives fine but i have to stop the car and put it in neutral or turn it off and plug the plug back in the ecm to reset the ecm pcm or whatever is being reset. ive tested the valve body with the cover on all solenoids read 5.5 ohms on the money ! I went to the local u pull it tested the valve bodies on 2 cars there and they both hit 5.5 ohms on every solenoid.
Im wondering if im not testing them right as in are they hot enough maybe ?
Add to 1997 Saturn SC1's Reputation
Rate the quality of this post and help 1997 Saturn SC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1997 Saturn SC1 is offline   Reply With Quote
Old 07-13-2011, 08:39 PM   #2
1997 Saturn SC1
Default Re: 1997 Saturn SC1 TAAT Transmission
tomorrow im going to check the input shaft nut
Old 07-13-2011, 08:45 PM   #3
1997 Saturn SC1
one more thing is in order to get reverse i have to goto neutral fist and 3rd for drive i assume this is a linkage problem right ?
Old 07-14-2011, 01:07 AM   #4
1997 Saturn SC1
I have bought a acctual service manual in pdf format for this car it gives all codes and very detailed info as to how to rebuild rewire remove and replace anything and everything on the 1997 to 2002 S series its 228MB if anyone needs it or a specicific piece of info pm me
Old 07-14-2011, 11:34 AM   #5
campus189
campus189 is on a distinguished road
campus189's Avatar
1997 SL1
Is it really hard to shift?
If so , you can remove the linkage to see if it's the cable
With linkage removed you will be able to go through all the positions easily.
Good luck
1997 Saturn SL2 144,000 Miles
1997 Saturn SL1 254,000 Miles
1997 Saturn SL1 157,000 Miles
1996 Saturn SL1 97,000 Miles
Also known as FiremanCV on YouTube
Add to campus189's Reputation
Rate the quality of this post and help campus189 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
campus189 is offline   Reply With Quote
Old 03-07-2012, 02:35 AM   #6
1997 Saturn SC1
Ok heres more detail first off park is always park when want to put it in reverse i may have to go to neutral or reverse to get it to shift into reverse i have to go to 3rd to get it to go in drive 3rd is always drive its an automatic and the shifter part shifts easy i had thought it may be the computer somehow but its not ! now im looking for a compatable trans to replace it with My car is a 97 SL1 or SC1 Single OHC 1.9L auto trans that was just more info but the other trans problems still remain
Old 03-07-2012, 07:59 AM   #7
Chazberry
Chazberry's Avatar
You might want to focus on the Neutral Safety Switch.
Add to Chazberry's Reputation
Old 03-07-2012, 09:06 AM   #8
1997 Saturn SC1
k thnks will look at it today . any advice on what cars i can get the transmission out of ? i have a 97 sohc so mp6 tranny what year sc1 is the exact transmission ?
Old 03-07-2012, 09:28 AM   #9
Chazberry
Chazberry's Avatar
See this thread on testing that switch . . .
http://www.saturnfans.com/forums/sho...3&postcount=41
These sites will be helpful . . .
http://www.saturnwiki.net/index.php/...e#Transmission
http://www.differentracing.com/tech_...gearratio.html
Old 03-09-2012, 05:04 PM   #10
1997 Saturn SC1
Ok i went to my local u-auto-pull-it got a ecm/pcm for a 97 dohc with AT and my tranny shifts great now ! engine is a lil rough though at low idle
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 08:28 AM
Taat Transmission problem re hum funnyfarm S-Series Tech 9 09-04-2009 07:36 AM
TAAT transmission (or not) k1rod S-Series Tech 4 10-23-2008 12:14 PM
TAAT transmission eXmortal S-Series Tech 18 05-15-2008 08:57 AM
looking for an exploaded view of a Saturn Taat transmission. mordo2 S-Series Tech 13 09-01-2006 11:48 PM
