#1 | ||||
![]() Join Date: Nov 2010
So it turned out that the Manual Clutch Actuator started leaking so went ahead and pulled the transmission and replaced the actuator. Went to re-bleed the hydraulic system and now the pedal gets super hard to the point where it wont even go to the floor to turn the car on. Already broke 1 clutch pedal slave connection and now have to replace the whole assembly.
Trying to figure out why the clutch pedal gets so dam hard to push. Now I dont want to break a second on by doing this all over. *Checked lines for kinks etc no KINKS found *Checked for connection at resevoir etc good *Checked connection at bleeder connector to trans GOOD Dont know what else could be causing this wtf. When I bleed this thing it bleeds good no probs I get a flow of fluid from the bleeder and everything does somebody know whats going on?
| Thread Tools | |
| Display Modes | |
| Clutch stuck in my 99 Saturn SL2? Pedal still can move, but car won't start in 1st? | SeanMaster364 | S-Series Tech | 19 | 05-03-2012 11:37 PM |
| 1997 Saturn SC1: Clutch Pedal Won't Move | Chadd.Lackey | S-Series Tech | 0 | 05-01-2011 08:50 PM |
| clutch pedal hard and squeaky! | bboynowee | S-Series Tech | 3 | 12-07-2007 01:20 PM |
| Clutch fluid level, clutch pedal vibration, small leak | Heartbeat - '95 SL2 | Miscellaneous Tech | 10 | 10-10-2003 05:35 PM |
| 91 SL1 Clutch pedal becoming "hard" to push | coolgreany | S-Series Tech | 8 | 08-06-2002 07:16 AM |
