Old 06-29-2011, 11:02 AM   #1
pyroom
pyroom is on a distinguished road
pyroom's Avatar
2004 VUE 3.5L
Default AWD vs FWD Transmission?
Does anyone know if there is a difference between the two transmissions? Would I be able to swap out my AWD transmission with a FWD transmission and still have AWD?
Thanks!
2004 Vue 3.5L AWD
Add to pyroom's Reputation
Rate the quality of this post and help pyroom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pyroom is offline   Reply With Quote
Old 06-29-2011, 02:23 PM   #2
fastmofo
fastmofo is on a distinguished road
fastmofo's Avatar
Default Re: AWD vs FWD Transmission?
awd to fwd swap = no more awd
2006 Pontiac Torrent
2011 Dodge Durango Crew
Add to fastmofo's Reputation
Rate the quality of this post and help fastmofo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fastmofo is offline   Reply With Quote
Old 06-29-2011, 09:37 PM   #3
far2grumpy
far2grumpy's Avatar
Thanks!
I'm tempted to say basic transmissions are same but AWD trans has Honda transfer case (TC) to adapt to drive-shaft. This is semi-complex appearing piece of machinery. The file is just over the limit for posting but I can email if you'd like to have.
The specs also indicate the FWD trans requires 1/2 quart more ATF than the AWD. Not sure where the extra fluid is "stored" but we do know the TC (or PTO - if you prefer) holds several ounces of entirely different lube.
Old 06-29-2011, 09:53 PM   #4
XRL
XRL's Avatar
2004 VUE Red Line
It may appear that way at first, but it's really quite simple.
You see, first the one thing spins, and then that causes the other thing to spin, which then in turn spins another thing and so on and so forth, and then the rear wheels spin.
See, simple.
Add to XRL's Reputation
Old 12-28-2011, 10:25 AM   #5
jcc007
jcc007 is on a distinguished road
2006 ION-2 Quad Coupe
What type of Transmission fluid does the 2003 Saturn Vue v6 FWD, take? Also how much fluid? Im researching on how to drain and refill my transmission fluid since the vehicle has 183,000 miles on it and probably has NEVER seen new fluid in it.. Again I have the FWD not the AWD. I just need to know what kind of fluid it needs and how much and is a scan tool recommened when I change the fluid in it. Thanks.. JCC
Add to jcc007's Reputation
Rate the quality of this post and help jcc007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcc007 is offline   Reply With Quote
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 08:28 AM
Transmission cooler/radiator replacement when transmission is bad? infinitewisdumb S-Series Tech 2 04-16-2010 08:59 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
'95 Transmission Operation Debrief: Transmission stuck in 2nd gear rc1488 S-Series General 0 01-12-2008 12:28 AM
Transmission Fluid flow from Transmission into the radiator ? Luke S-Series Tech 5 11-10-2005 10:52 AM
