Old 06-16-2011, 12:30 PM   #1
chrisk
chrisk is on a distinguished road
Default coolant level sensor
Hello, I have a 2007 Saturn ION with ~81 K miles, recently my coolant indicator flashes on the dash readout, but my temp guage is always fine and floor boards aren't wet at all and i havent noticed any leaks anywhere, when driving for a few minutes, and goes away after a couple of seconds. I did have to add a little dex cool 50/ 50 to the expansion tank, it was a little (not much) below the cold fill line. And the coolant indicatior is still coming on. I have read online that the coolant level sensor might be bad and want to check this. I have 2 questions
1. Is the coolant level sensor the electical connection located on the bottom from of the resivoir tank?
2. I also noticed an electrical harness comming from undernath and behind the resivoir tank that is monted to the front body (directly behind the right front light assembly, under the hood) of the car, but nothing is plugged into at all? Is this just an extra connection for an extra acccessory? I really don't see anything that looks like it should be plugged into it?
Thanks in Advance for your help.
Add to chrisk's Reputation
Rate the quality of this post and help chrisk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chrisk is offline   Reply With Quote
Old 06-16-2011, 05:37 PM   #2
jball
jball is on a distinguished road
Dizzy Re: coolant level sensor
I had the same problem on my 2004 Saturn Vue with 57,000 miles. I had to replace the recovery tank, since the coolant level sensor was located inside the recovery tank. This design did not allow the sensor to be replaced without replacing the recovery tank. Please check to see if the coolant level sensor can be replace with replacing the recovery tank.
Add to jball's Reputation
Rate the quality of this post and help jball reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jball is offline   Reply With Quote
Where is my coolant level sensor (not in tank) mrclean92124 S-Series Tech 28 06-05-2009 12:40 AM
coolant tank level sensor 93SC2'in S-Series Tech 1 09-06-2008 12:38 AM
Resistance of the Low Coolant Level Sensor? TIMSPEED S-Series Tech 7 12-18-2007 12:33 PM
Engine coolant level sensor slim1996sl2 S-Series General 4 02-25-2006 11:51 AM
Coolant Level Sensor RalliArt16 S-Series Tech 1 08-27-2005 12:21 AM
